No the rears are a set height...not adjustable like the fronts
Correct they are not adjustable like the front but they are designed to handle raising the rear with a block at least 1" I think I read in this thread they may also work up to a 2" raise but I would double check that.
I would say yes...I can't tell u that 100% cause when I did mine I also added air bags so it seemed to lift the rear a little....but I am pretty sure it will sit the same with just the shocks
Can anyone comment on this?
Is the ride quality on Bilsteins significantly better than the Beltech's? I am looking to soften the ride on mine, particularly the rear. I'm getting annoyed by the harshness on rippled roads, manhole covers etc. THANKS
I had 5100's put on the front this AM. Rode great on the way home very happy. Just put the rears on myself took it for a ride slightly stiffer but still great and I would never go back to Stock.
Never had Beltech's, had Bilsteins on my last truck and was very happy.
The Bilsteins are much better than my Z60 set up on my 1400 mile Sierra.
Not sure you would feel that way but I a do.
So I have been reading this thread and I can't seem to find a definite answer. Can Bilsteins be ran on RC 2.5'' level front and rear? If so, what model of bilsten and what level are they set at? I have an RC 2.5 level and it rides a little rough so I am hoping to smooth it out some. I need ever inch I can get as I am running 33x12.5 on -24 wheels.
Just purchased my Full Set of Bilstein 5100's from MRT Motor Sports.Hoping it levels the truck for the most part. Now the wait begins......
Thank you for the business!! We will get these shipped out today to you, hopefully for a Wednesday or Thursday delivery.
4600s (Yellow) can be used no problem. 5100s will need to be used on the lowest setting only.
I had them sent to my friends house so that my wife wouldn't see what I got. I told her I was getting a $50 leveling kit lol. Going to install before she sees what I got. Wish y'all had Koozies to keep my beverages cold!! Or did I not see them on the site?
Ive got some gear leftover from the offroad expo left over, I will send it your way. Also just shot you tracking on the shocks!
Thanks!
Thanks!
Awesome!!! Thanks!!!!!
Very common for the 2.5" leveling kits to have a 1.5" taller than stock rear block. Stock rear is either 1.5" or 2" if a z71, you said it measures at 3" overall which sounds like the 1.5" larger rear blocks. The 5100 are rated 1" over stock, but can really go to 2" if you are beating on them offroad.
Good info , 5100's ordered!
    • I do have one of the AFM diasable box, using it for last 1.5 years.
    • I found a setup that lets me open the cover partway with racks installed, using side-rail-mounted systems for easy access.
    • Typically its said and I agree so far that the engine oil drain plug oring is not required to be changed out unless you see some damage happening to the oring as apparently the oring lasts well. The dealer I have been getting a few parts from never even stocked the oring but instead stocked the whole drain plug that comes with a new oring which for the dealer is easier because they just throw in a new drain plug if there was any question about damage on it as well and charge the customer accordingly but again only if it is needed.    Also a hint about the drain plug oring to help it last vs a risk of causing damage to it, after its been removed and wiped off or washed off ( that is a whole other topic about some solvents damaging orings because some solvent types do ) to make sure to relube the oring with a bit of new oil so that it won't "grip" on the sealing surface of the pan and needlessly stress out the oring. Its no different than putting some oil on the sealing ring of the engine oil filter. So I just grabbed a new drain plug to have on hand although more recently bought just the oring as well but as its special it costs half the price of the drain plug ... !   Since you mentioned the hate to be empty handed theme, I am not sure what you have in the way of filter removal tools as I like using the exact sized for the filter steel 1" wide band with side to side swivel handle filter removal tool, and it can be used to snug up the filter without risk of damaging a filter as well ( its probably a lisle brand I have ). The drain plug hex size is 15mm and I always like using a 6 point socket if I have a choice and with this truck I've been using just a 3/8 ratchet that has a fairly long handle. Do you have a funnel that will work to pour oil in as that is definitely the short coming bastard part about the design with that fill port on the valve cover on such an angle that no normal funnel will even work. There are adapters and things on the market that will set into or screw into that fill port, I didn't want to deal with US shipping as that is all I was seeing at the time so caved and bought a Lisle brand multi vehicle fit adapter funnel kit and it really works well but there are much less expensive adapters out there that work in conjunction with an off the shelf funnel that would do the job also. Now that I have it, I like how it works and works so slick with the shape of the Amsoil 1 quart containers I have now switched over to. Whatever you do, have a funnel system of some sort as you will be swearing if you dropped the oil and then realize you have nothing to properly pour new oil in without spilling it all over the engine !.     Other comments, quite a bit of oil flows out down the filter when its cracked loose due to the housing above the filter so let it dribble down the filter until it slacks off flow and then remove the filter to create less possible mess. It seems these engines can sit for quite a while and drip and if you have time let it sit there and drip out of the engine as much as it wants. Also a good time to grease the 9 zerks on the front end, that's my typical practice anyway to grease the suspension and steering each time I change the oil. And remember to reset the oil change minder ( not something I am used to doing with older vehicles and equipment ).
    • I really did not measure what came out. I carefully followed directions to check level after i did the spill and fill and filter change. I used 10 quarts. 9 was not quite enough. My trans temp was about 175 when I checked it. Truck sitting in my driveway very close to level where I always check oil pretty much every time for consistency. My driveway is just ever so slightly downhill to run water to the street.
    • Sounds like maybe it's announcing Navigation turns or Alerts (it mutes the music) ? When it mutes again, turn up the volume quickly and see if maybe the navigation volume is really low?
