Hi everyone, new to this forum here. Was wondering if the 5100 fit on a '17 SLE? Looking at another way to level the truck rather than a traditional leveling kit.
Sure they'll fit. Trim level really doesn't matter.
Okay, was looking on 4wheelparts and they didn't list it so I didn't know if it fit or not. Thanks for the reply.
I thought about upgrading my stock shocks. I don’t know for sure which ones come stock on em. 14 Chevy Silverado LTZ. I know they’re black. Not the best shocks. But, I’m approaching 60k miles on em. Kinda getting worn out. Thought about getting the 5100s on the top setting. Is that enough to clear 295/55s or possibly 305/55s?
Not sure about a accurate answer but I have them at top setting with 275/60/20 and never had any rub. That's normal although this is the first winter with these tires and living in the Midwest were saw lots of snow. I had a constant issue with slush freezing and building up causing major rubbing when turning. Our trucks having these carpet wheel well liners really grabs and holds the road slush. I've been wanting 295/55's but I'm sure they would be worse. Going to add a spacer kit and take the Bilsteins down to the first notch. Hopefully it will result in a better ride too. These shocks are really stiff.. At least when maxed out.
I have a 2015 Z71 with the 1500's at top setting and is about 1.75" lift,  I test fitted  285 65 18 (32.6 x 11.2) which is just about the same as a 295 55 20 (32.8 x 11.6) and the fit just right.  IMO, anything bigger (305 55 20,  33.2 x 12) will look like you are trying to stuff the tire in and looks funny without at least a 2.5 or 3".  I will say that the B1500's are night and day compared the Z71 Ranchos that I replaced.
On my '08 ToyotaTundra Crew Max Limited, I had the 5100s. Added 275/60/20 KO2s. I had no rubbing at all, it was a good setup. I liked it. 10-4 on the stiffness, I had mine on the top setting too. It leveled the truck out perfectly. I really did like em. I might just add the 5100s to the rear for now. I want more of a planted feel.
Sweet, thanks for the info man. I'm most likely getting the Toyo RTs in 295/55 for my truck.
IMO, I don't think lowering your B's back down and adding spacers will make much difference since there not designed for that.  how long have you had them on the truck? may need to break them in a bit.  When I leveled my truck the first time with the Ranchos they were stiff as a board,  the B15's were much better at top setting than spacer.
I think I put them on in June/July last year. I was comparing the ride to my 2011 that I just had a Zone 2" level on. If course I had 18" wheels on it so I'm sure that helped the ride over these stupid 20's that don't belong in a truck that works for a living let alone a NHT max tow. I've noticed improvements in the pogo effect, side to side head bobble and cornering with the Bilsteins... Just wish they were a little more compliant on the stiffness.
I have read numerous instances were folks say the 5100 is less stiff on the bottom setting compared to highest setting.  Makes sense since it wouldnt be pre loaded at all.
The bilstein 5100 look a little longer than the ranchos, on the 0 setting are you guys getting any height gain? Thinking of getting them and doing either 0 or .75” . I don’t really want to go up in the back if i don’t have to that’s why I’m trying to figure out height
2017 Chevy Silverado LTZ Z71 6.2L
4.5" Zone
22x10 American Force Grips
33x12.5 Nitto Ridge Grapplers
Instagram @wildchevys
basically what i'm trying to figure out is how accurate are the predicted heights. Bilstein says the settings net 0",  .75",  1.25", and 1.85". the guys that have installed them, how accurate are the actual height gains?
I can only speak for the top (max lift) setting and it was right on what Bilstein said it would be. I'm interested in whether or not the 0 lift setting actually provides a little lift or not. I'm wanting to drop my Bilsteins down to 0 or the first notch. I have the max tow (NHT) and I've decided that after a year the ride is too firm. Compounded of course by having the stupid factory 20" wheels and max tow I'm thinking this is the worst riding combination on a K2.
Ok thanks!
4.5" Zone
    • tl; dr I've now reached the 6th floor of hell. I'm chronicling my journey for my morning readers.   Pulling the top of the intake apart was moderately easy but it involved a lot of parts, connections, and minutae. I was preparing for the new fuel lines to arrive ("nut and bolt kit" it's called). The fuel line connections are notched and held in place by the manifold and a metal plate with a T27 screw.   It's on the back of the intake, under the firewall, with little clearance, and two hard metal fuel lines in the way. I was using Franken-tools (weird combinations of 1/4 inch ratchet with/without an extension, with a bit holder for my T27) to get in there. One of my sockets and bits fell off and has yet to emerge on the floor. I lost a second setup and that's when I almost started throwing tools. But that was the point at which I had gotten traction on the Torx head, and it promptly stripped. No more traction.   I started humming "1-877-kars-4-kids" because I was about at that point. You know what? I'm $1500 into this thing and I can make it disappear just as quickly. This isn't fun anymore. I had spent a lot of time already "tidying" around the engine bay: Fixing all the "someone's been here before!" BS. The truck has been exclusively dealer- and shop- serviced and I'm reminded of why I never let other people work on my cars unless absolutely necessary.   Speaking of dealer service. This truck has a 1" stack of records going back to 1995. I put them all in an excel spreadsheet, date/mileage/description.   The CPI spider has been replaced 4 times in 85k miles. The EGR? Another 4. Multiple, multiple O2 sensors. One Cat. 4? Sets of plugs and wires, and I swear half the stack is diagnosis paperwork for "misfire, runs rough, extended crank, dies at stoplights".   GM was producing some proper crap back then. And it was still well within the era of brittle/crappy plastic. (Windows 95 was released the same month this truck was sold new, we HAD the technology!!)   There (was) a plastic shroud around the evaporator core and HVAC fan in the engine bay. I noticed a chunk of it missing so I poked at it some more and it literally shattered. Touched it some more and pieces were crumbling off. Had a good laugh. Clearly whatever plastic garbage they were using had broken down over 30 years and was literally turning to dust. That was a good half hour of using a shop vac to remove the rest of it.   Back to it.   I was going to give up for the evening but then decided I'm already level 10 pissed off at the stripped screw: G* D* it, give me my tools back -- and my JOY. We'll do this the hard way: The whole intake is coming off.   Blazer won Round II. After finally finding and accessing the 12 intake bolts and using a pry bar to unseat it from the heads, it popped loose in an explosion of gunk and grime raining down into open ports. Awesome.   6 times I reminded myself: Be careful of the temperature sender on the front of the intake.   YEAH, I forgot again and snapped it clean off in the removal. Add another $20 to the ever-growing list of new parts this thing is consuming.   The shame is, long before removing the intake, I had changed the oil in prep for Tuesday's momentous fuel line replacement that was going to be the magic fix and I'd have a running Blazer to tool around in this next weekend. The intake removal, including raining gunk, also gushed dirty coolant all over the valley. Of course it did. Welp, there goes another $35.   I now need an intake gasket set, bolt set, coolant temp sensor, another 5 quarts of oil, some RTV. Don't worry, I've already got 3 new jugs of Dexcool and a thermostat waiting. I'll fill it with clean water first to get it running, dump it, and then add the Dex later on in case... well, let's not go there. I'm only tearing this down once, next time the truck is going on Marketplace for FREE.   Oh, and I'm going to need vacuum hose for all the stupid connections placed at the rear of the engine which have since disintegrated. Come on, GM....tell me you don't do that anymore?   Oh, and the ears on the distributor where the cap screws down are both cracked. I mean, why not put a new distributor in it too. You get a distributor, YOU get a distributor, Everyone gets a new distributor!   This truck isn't out of the woods yet...I'm already questioning how much more time I'm willing to sink in.
    • That's interesting.   There was a factory wire-hole in the back, top of the rear cab, which had a wire for the third brakelight assembly running through it, as well as several holes (10 of them I believe) for all of the studs coming off of the 3rd brakelight assembly itself.   I sealed all of those holes with RTV/silicone as well.   I found it kind of odd, that none of those holes, were sealed with any kind of sealant by the factory - if there was any there, it wasn't very much.   That said, I've been out in heavy rain and have ran the truck through high-pressure car-washes a few times now and she has been 100% water-tight to this point.   I feel very confident in the repair, we'll see how it holds up.
    • I bought a used 2022 2500hd with 6.6L in February. In March took a 2200 mile trip towing our 6500 lb trailer. Changed the oil day before leaving and when we were arriving at our 1st destination, low oil light came on (roughly 1000 miles) it was 2 qts low. Now it towed like a dream, no issue there, and we did go through the mountains of TN, but still, 2 qts! Luckily I did purchase an extended warranty. Brought it to the dealership in April, oil change and consumption test. Brought it back last week, 1300 miles, no towing, and no oil showing on the dipstick. GM is reccomending a new engine (cheaper than them rebuilding), we'll see if the warranty company comes through.
