2 hours ago, Gearhead1000 said:
Sierra Dan, I thought they did a good job of managing the loads. Maybe a bit stiff empty but I never am so I would have bought them again if not for the premature seal leak. I think the ultimate shock would be adjustable. So I could soften it up for empty and then dial it up for loaded. But I can say they were night and day compared to stock.
Most monotubes are going to give you that "stiff" feel. But that is the beauty of them.
The stiff feeling offers that planted ride and soaks up the crap in the roads that Twin Tubes do not.
Rancho does make the 9000 adjustable shock. Not sure about the quality or longevity of them.
Dan, I can't remember, You on 3rd or 4th setting on Bilstein's??
Installed Bilstein 5100s in front/rear with 2 inch block in back. Fronts are at highest setting.
Still too much rake? I wanted to keep some rake but don't want more than factory. Failed to take picture prior to install unfortunately so I don't recall how much rake it had before.
What do y'all think?
Sent from my SM-G973U using Tapatalk
Truck looks good. You still have stock tire size? It could be the angles, because it looks level, but my eye keeps being drawn to the additional open space above rear tire in 2nd pic. The light is hitting it and you can see bed rail.
What are the actual measurements now? Front and rear?
I'm going with 3rd setting and eliminated swapping out the rear block. Hope I'm happy with selecting setting 3. Should know late Tuesday. Goal was to get nose off ground, tighten up things and put 33" tires under.
Truck looks good. You still have stock tire size? It could be the angles, because it looks level, but my eye keeps being drawn to the additional open space above rear tire in 2nd pic. The light is hitting it and you can see bed rail.   What are the actual measurements now? Front and rear?    I'm going with 3rd setting and eliminated swapping out the rear block. Hope I'm happy with selecting setting 3. Should know late Tuesday. Goal was to get nose off ground, tighten up things and put 33" tires under.
 Yes, stock wheels and tires on the midnight edition.
1.5 inches higher in rear than front. Anyone know what stock rake is? I figure I would have been within a half inch of being level using highest setting had I not changed the block. Again I'm fine with rake, just not more than stock.
Stock Rake is usually 2 1/2 "
I took measurements before dropping truck off.
Stock on a 2017 High Country with Z60 Suspension
Front 36 3/4 " ~ Rear 39 1/4"  = 2 1/2" Rake
3rd setting should put me at 38" Front ~ Rear 39 1/4 = 1 1/4 Rake.
Correct me if I'm wrong, but you appear to be holding phone level (nice wax job) Looks to me that you are setting at 38 front and 39 1/2 " rear.  Back 1/2 missing could be air pressure, angle. You sure you are on top ring up front?
Edited by Pivot
I'm pretty sure it's highest setting, but I didn't install the fronts. But I asked shop twice to confirm and they said highest.
Just tried to look under truck but it's hard to tell which ring with the boot covering the top.
There are a couple pics where you can see the ring settings exposed. I know you have 5100, but scroll down a bit on 2014-2018 mod thread and click 6112 install or toggle back a page on this thread and you'll see a thread link. 4th setting should show 3 rings exposed below collar. 3rd setting should show 2 rings.
You should be able to turn your front wheel out and squat down in front of tire on driver side and see the setting with flashlight or phone. No boot on the front that I'm aware of.
**Picture above is 6112, but good example of rings on max. Credit on pic to Doug who uses 99bluebird user name
Just dropped off my 2016 Z71 to have the 5100's installed on the front at the highest setting. I'll do the rears myself just for the fun of wrenching. Lots of reasons people here went with these shocks, but for me it was the consensus that for a level, this was the better option over spacers. Upgrade the shocks plus the additional height without the bad CV angles. I plan on getting a 3-4" lift and bigger tires (probably keep the stock 18" wheels) once we get a new daily driver for work. My truck's only got about 22K miles so I'm sure the Rancho's are still fine so it will be interesting to feel the ride quality difference. I drove a Honda Prelude for 20 years and had a 2002 Chevy 1500 for awhile to haul hay and trash. The ride quality on my 2016 Silverado seems like something I wouldn't want to make stiffer, but then again it is a truck! I bought the Bilsteins for the additional height and upgrade over stock, not because I thought the Ranchos were terrible. Hope it wasn't a bad compromise. I'll find out this week!
Ok so I effed up with prior measurement. Parked her flat and here's what I got.
Have 3 inches of rake. Ring looks to be on top setting. What am I missing? 9a2a955c0def25dfc77b8b43585af96f.jpg983a7ef3c0c7e56279a8731198ec00c2.jpg7ba773a010acfd8a4047b208acebb67c.jpg
I won't have my truck back for a few days, but I have my fronts at the 3rd setting (4th being the highest) and a 2" rear block.  I don't have as much rake as you.  Seems like your fronts are at the stock setting, maybe 2nd.
    • They are talking about adding more tax to our fuel across Canada by the labour day time frame, its the carbon idiot tax increase on top of the pile of fuel taxes we already pay thanks to the WEF dictatorship running the country. 10 cents per liter on gas and 4 cents a liter on diesel I believe is what was said. That is a huge amount of a tax increase as its another 38 cents equivalent to a US gallon of gas. The reason our fuel is higher than the states already is because of of the high taxes they have imposed on fuel.
    • This is just a thought as I can't claim this is the correct thing to do but will suggest it and you can decide if its something you would try. First round up some electrical contact cleaner spray as they at least claim its not supposed to damage the components ( brake cleaner depending on the type is a real destroyer of plastic etc ) and to use that to assist to clean out any grime from the pins as well as the mechanism by spraying and working the lever etc. Then my next thought is to use silicone spray lube and not on the pins but on the seal and the pivot assembly. It may not be possible to spray it on certain area's and have to use a q tip as Davestar mentioned to keep it from getting on the pins. Dielectric grease can be fine on some things but its easy to get too much on if not careful and then gunk things up and a possible risk of getting it on the pins or sockets. The silicone spray is able to get into a mechanical component to help lube and on surfaces its just a fine film to reduce friction such as that seal. Also it can be doused off with a good flush of the electrical contact cleaner the next time for a repeat of a "clean and then lightly lube" step process to wash off any dirt that had stuck to the exterior etc of the plug.   Free advice, yes. Good advice ... now there's the question mark !
    • Hey thanks yall for the info. It apparently was the key fob - the "reserve" key fob works just fine. Yall were all over it. Great input! JRD
    • I just bought one of these.   https://www.topdon.us/collections/diagnostic-tools/products/artidiag-pro   Yeah, it`s got a cable. $250/year after 2 years. Do I want more? Yep. But, I`m not working any more and can`t afford a whirlpool in my tool box.
    • Why don't I have a good scanner? I've always wanted one when I've needed one.   My latest reading says I don't need to do a relearn on the ckp sensor on a 1995 with OBD 1.5. The relearn is prescribed for the later-model 1995's which shipped with actual OBD II when GM completed the transition in prep for the 1996 MY. I need to confirm that. Did you know forums are disappearing? Knuckleheads on Facebook... it's not the same. It's just not.   So, scanners. Again, shooting myself in the foot for having eBayed my Snap On MT2500 "brick" with all the adapters. Not that I couldn't buy another but those are getting quite old, and mine wasn't new enough to work on 2000's vehicles.   Damn it (as I'm scanning my email between paragraphs here). Did you know there's a 2000 Jimmy 2-door on BaT that's ending this morning? It's local. I want it. 14k miles. Absolutely beautiful.   Back to scanners. MT2500's are old. Solus, now that could be a contender. There's a ~2008 Verus with a system error that's basically new in box for cheap. Hmm...I'm not sure about a scanner that runs an archaic version of windows (95 or CE, I can't tell).   I want the ability to reset and rotate TPMS, test individual modules, bleed ABS, electronic parking brake controls for servicing brakes, relearn procedures and other bidirectional controls.   Snap On does an MT2600. It's a new model as of last year, marketed as their "entry" scanner. Entry? Only where $1900 gets you through the doorway plus, I'm guessing, $1000/year if you wish to keep it current. So goes scan tools actually designed for production environments. Want decent products with excellent support, you pay for it.   Everyone is raving about Autels and TopDons and Foxconns and all these newer brands that are selling the $500 "prosumer" scanners for backyard hacks like me. They're tempting...honestly. Updates are cheaper, base prices are remarkably cheaper... And you get to deal with bugs and translation whoopsies and, well, just don't use it on anything expensive, OK? Having a dealer replace an ECU because it needs to be re-imaged after an adventure in scanning is no joke. But I think most people are getting by OK with these units.   eBay on a scratch-and-sniff pro-model oldie, a shiny new TopDon, or???   God dang it, I can't stop looking at this Jimmy. I'm ready! I'll Bring The TRailer! It's beautiful.
