So it begins [new house build]
TJay74
How goes the build? I used to wire houses a few years ago. Make sure you have a few dedicated quad plugs in the garage! Maybe a 50 amp welder plug too!
  • Replies 42
Waiting as of now, been hammered with rain the last 2 months so the trade contractors are held up. Hoping to break ground in the next 4 weeks if the rain will ever stop.
Several years ago, I built a large garage and put in a small bathroom with stool and sink. It was one of the smartest things I ever did. It was a very minor expense is used a LOT. I also used storage trusses and put a floor in the attic with a fold down stairway. The attic, not such a good idea. I tend to keep a lot of stuff I shouldn't, just because I have the room.
Good Luck with your build!!
yeah the nice thing about Oklahoma is we have finished garages, the builder decks some of the attic already. I will deck a bunch of it once we get into the house as I plan on taking a full week off to move in and get everything sorted.
The laundry room is right off of the garage so there will be a full sink and tiled floors to walk on.
We have been out looking at the stuff for the theater room recently, looking like that room is going to easily be a $5k-10k room at this point.
  • 3 weeks later...
Definitely looking forward to seeing it all come together.
You should look into radiant floor heating. Not expensive at all and extremely efficient. It can be used for heating purposes or even applications like snow melting. Especially if your building i'm sure you know the cost of plumbing nowadays. Copper is going to cost you 3 times as much with no difference than PEX tubing. Just some insight, good luck and enjoy!
Living in Oklahoma we really have no need for radiant floor heating, sure it would be a nice feature if money was no object. At this point we are already locked in with the changes and cant change anything else unless we are ok with paying a $500 change order fee along with the charge for the change.
I would just be happy to break ground, was told last week we are still around 4 weeks out due to weather delays.
Congrats!
Here is a little advice.
Walk the house after all major completions and break out the tape.
Plumbing
Foundation
Framing
Roof
Etc
Also make sure they keep the job site clean. I work with a designer and we do 700-1000 home and commercial designs a year and I can't tell you how many times I have walked a job site and seen water bottles and trash that I know ended up behind the dry wall. Your builder is probably fantastic, but sometimes trades can be lazy.
I will start my new build at the beginning of the year if is going to be a pain!
Here is a my floor plan. I'm actually working on the elevations tonight.
  • 3 weeks later...
I review a lot of reports where burglars are sticking a wire or some other device between the garage door frame and the garage door and disengaging the electric garage door clutch. Once this is done the garage door rolls up without any resistance. Disregard this if your garage door will be manual, but if it's electric, have the installer place a key lock and handle on the outside garage door. Most electric garages don't have an outside handle because of aesthetics, but it is added security to be able to lock the garage when taking an extended road trip. Just a lil info since you are getting a house built.
You can also add a zip tie to the mechanism so they can't pop your garage door and manually open
Ryan
I actually ziptie the release shut. When we go on vacation I also slide both locking bars out and padlock them, then once the garage door is secure I unplug the GDO. No one is opening my garage door at that point unless they hook onto it and pull it off of the house.
There's no LOCKING handle on most doors because it completely interferes with an opener's use. This is offset by the installation of door locks inside the garage. The handle at the bottom for lifting purposes is still installed on many doors (or can be installed at install time simply by asking for it). If it isn't installed, it's often left behind in the box of "extra parts". It really doesn't serve any purpose because lifting the door manually requires disengaging the mechanism from inside where there almost always IS a handle or something on the door that you can grab to raise it.
Progress pics
Stem Walls
11209474_1197882103571002_61391185376240
Plumbing is in
11921708_1201447729881106_77571148578417
11951393_1201447859881093_60904012776707
Nice thing about taking pics along the way is I know where the water lines enter and run throughout the house. Next time I go out I am going to take my concrete punch and mark the water line on the curb and the property line pin before it is lost during the grading process.
My garage door handle is on the outside and serves a purpose because it locks my garage door. A separate lock above the handle disengages the lock. I'm sure there are variations to include the "zip tie"
.....key lock and handle on the outside garage door.
That's how many doors were installed, but quite a number of years ago. It is not the norm (around here, anyway) to see them installed in that manner anymore.
    JohnRoy
    JohnRoy
  • Who's Online   4 Members, 0 Anonymous, 655 Guests (See full list)
    • Which one, the AT or AS?   Starfire is made by Cooper/Goodyear but at $85/tire I'd think I'd need to level-set my expectations that they may not even be round 😉 But you're saying they're decent?   I'm already into this thing $1506 in parts, fluids, etc. Totaled all my receipts today. $250 of that was replacing an EGR and MAP sensor that were probably fine, but I'm not going to return the parts since they've been installed. I'm cheap, but not that cheap. I use it, I keep it!   I may or may not make money if I sell the truck at this point, but, that wasn't really the point. And if I billed my time, I'd be hosed for real. My thought on the tires is I "might" put 1,000 miles on before selling it. I just don't want to put absolute junk on it, that doesn't do anyone any good. If the Solus solidly isn't junk, I'll definitely consider them.
    • I leave mine as is. I'm always a trip away from riding on unpaved roads. Dealer can clean it when they prep it after I trade it in for another new truck.
    • I have these on two vehicles and love them. Pepper is one of them 😉
    • 4WD. Far as I know it came stock with P's and not LT's. Definitely planning to put P's on it, but stock is a 109 XL load rating so I should probably stick within that guideline.   No rebates on anything I can see at the moment. Discount Tire is offering $50 off, but Pep Boys is very competitive on price, and also carries all the off-brand stuff. Les Schwab always wants an arm/leg, but they do good work.   It still has the original spare. Goodyear Wrangler RT/S, thing looks like a tractor tire LOL!! How times have changed.
    • 2020 Sierra 2500 HD (base model) gas engine 4wd.    All 4 windows roll down on their own. Happens somewhat randomly after stop and engine off - when engine turned off, when walking away from vehicle before or after locks activated. Pulled the window fuse F14 Instrument Panel Fuse Block Right; the driver's side still activates from driver's side door panel; passenger and back seat windows activate from local switches on their doors but not from driver's side group of switches. Power mirrors don't activate with fuse removed either (same fuse for both circuits). Problem not solved.    How can they even activate with fuse removed but they are all still opening and can control from each door?  When they open on their own, I can shut them from the switch in each door, but they don't stay closed.    Seems to be activated somehow with key fob; something bumping the key fob in my pocket or just handling - removed key fob and took it far enough away and now the windows stay closed. Replaced key fob batty just in case, no change.    Sounds like some kind of wiring short or maybe electronics. Dealer will first replace electronic control module without checking anything else and I anticipate problem will still exist since their troubleshooting skills are limited to "do whatever the computer says".  In any case, keyfob seems to be activating the circuitry.    Surely I'm not the only one with this issue, but I can't find anything related on the site. What do yall think?   JohnRoy
