What a beauty.
This guy must have a really small penis..... :)
Extra large exhaust to prove that
truck looks pretty darn nice, just missing some towing mirrors and i also beleive rims are a little too big...would like less rim and more tire
These trucks with this style of lift and wheels look like rollerskates. Unfortunately this is just like the mini-truck, riceburner, donk, and diesel with huge attacks phase.
That thing will look bad F***** A$$ in front of macy's in the mall parking lot....... lol
In all seriousness though I would be willing to put money on it saying that that truck will never see any dirt / mud besides maybe driving off the pavement in to some grass for some pictures. To each their own though I guess... just seems like a waste... too expensive to take off road and I highly doubt it will tow very well either...
I coulda sworn I saw this truck with Alabama plates heading down I-285 some time a few weeks ago.
May not be the same one. He was in the fast lane passing me at like 80+ so I didn't get a good look at the wheel/tire setup, but it looked real good in person, made me feel like I was scraping the ground in my truck. :lol:
I don't generally like lifting too much in that it winds up looking like a truck on a frame with wheels underneath it. I like the "tucked" look when the tires are as big as they can be, but still mostly fit into the wheel wells.
It's great we all have choices. To each his own.
Can you imagine if we all had to drive toyduhhs?
    • First time it really happened to me was when I was 69 yrs old and I was called "Old Timer" by a complete stranger. Then in rapid succession came the aforementioned "Old Man" and my favorite of all "Pops".
    • Yea that's pretty normal to be off a few degrees.  Usually 2-4 degrees from say a weather app or thermometer.
    • I just replaced the ambient air temperature sensor.  Easy as pie. I simply had to remove about 10-12 clips on the plastic cover over the radiator and remove two T-10 torx screws on the hood release lever to liberate the cover (Amazingly, none of the clips broke.  All came out and went back in with zero problems). Once the cover was removed, the temp sensor is easily accessible. The sensor cable snakes through a few guides and can be pulled out for even easier access to the sensor. I was able to work the sensor out of the mounting hole.  There is a red sliding catch on the plug that must be pulled back to disconnect the cable.  The plug was quite tight.  I had to use a screwdriver to pry it out. I plugged in the new sensor ($6.45 from RockAuto), snapped it into the mounting hole and re-snaked the cable. I put the radiator cover back on and reattached the lever arm to the hood release.  All done!     I started up my Suburban.  The temperature read 82 °F. Other thermometers at my house read 80 °F.  Close enough.  It might be reading high as my vehicle was sitting in the sun.
    • Remember when you were 50 and they called you Old Man?
    • That one looks decent for the price   BUT..I want something that also supports OBDI/1.5. A lot of the prosumer-grade scanners don't have legacy support in order to keep costs low. I believe the Autel does if you go higher end with them.   For fun, I reached out to a local Snap-On rep because I was interested in the 2600. $1895 MSRP, says he can do $1595. That's still a lot, but then again, that's not a horrible discount for just asking out of the blue. Could probably do better if I was a regular buying off his truck, but I'm not.   Not sure if I mentioned but I didn't realize with USED scanners from Snap On that you need to make sure a) the serial number isn't flagged as stolen. On the newer ones, SnapOn can remotely disable the device if it's flagged in their system. And, customer service can tell you if it is, if you're thinking about buying used. B) Make sure it's paid off. If the seller still owes money to the truck or if they financed through Snap On, the device can be remotely disabled until the balance is paid. It's less clear if SnapOn will tell you if a balance is still owed; I didn't make it that far with the used model I was considering. I did read that SnapOn has no way of tracking any "truck financing" deals between the SnapOn rep and buyer, only if they financed through corporate. So there's that extra caution needed.   Still waffling on whether I go with a ~$500ish Autel/TopDon or spend bigger money. The value seems to be in the prosumer brands. I'm not giving them enough credit TBH, actual production repair shops use them daily BUT I'm still allergic to certain kinds of underdog products trying to unseat American companies with solid reputations. SnapOn's scanner isn't wholly made in the US, but it is assembled here and they have US support and probably the most proven/ robust legacy support.   Something to think about. Value, or principles? There's a $1k difference.
