I have 1000 miles on my lift now and the rear has not loosened up at all. The rear springs are more like steal beams with no suspension movement at all. The ride is ok on a perfect flat newer good road surface but on anything else that's a little rough the ride is nearly unbearable. I just put about 300lbs in the bed and the rear suspension didn't drop at all. The ride is a little better but still sucks. I know the 35in tires are part of the rough ride since all 20inch 35s are E load range. Will these springs always be this firm?
Probably take as many as 10k miles to break in. Do you tow? That will help break them in even more with the consistent bounce of the tongue
I tow a 3500lb boat but only 5 miles to the ramp like 3-5 times a year. I guess could take 2 yrs then as I average 5-6k miles a year
Steel dont work that way lol, they only eventually get more brittle and lose the flexibility (where you see old vehicles sag) the atoms starts to break apart and no longer holds themselves together. eventually bent to the shape it is forced in and crack.
There are 5 leafs
Edited by Payton34
Hmm that many springs, not sure if it will ever be factory ride quality.
And if you want you can just get the blocks. Cheaper and easier to install. I've had blocks for the past 90k on my lifted truck and no issues here, except wheel hop and axle wrap
Talk to me about axle wrap. I am looking at BDS 6inch with rear lifts because I am concerned about using a 5 inch block.
That's what I'm running on top of an HD leaf packing
Some of the higher performance suspensions have control arms. Some are "ladder" type bars, some are multi-link. They're all for the Same reasons.
It is actually 5 leafs not the 8-10. I got the replacement leaf springs because i hated the axle wrap I had on my old truck with a rancho lift had 5 inch blocks and add a leaf. I was told by 3 installers the replacement springs are the way to go and they weren't saying it to charge more labor because install price was same for blocks or leafs
Anyone have an opinion on which is worse between stiff springs and axle wrap? I want to order lift soon, but concerned about what way to go.
    • This video may not be the exact content for the joke thread but its a lot of laughs so here it is, I've only watched a portion of it so far but if anyone is looking for some light hearted good soap box driving action, its here. As a note in the upper left of the screen it shows the number out of 100 to refer back to any particular vehicle for comment !.    https://www.facebook.com/reel/1351928276956715
    • Did have to make 1 modification because of the WeatherTech rear mud flaps and that was needing 3 longer screws than what came with the install package. 😄
    • Picked up the liners yesterday. Installed passenger side WITHOUT any modifications. All mounting holes lined up perfectly. Rain is interfering today with drivers side. Very Happy! Will add pics when finished
    • That is a fair point, and I agree that trying to log “everything in the truck” would be the wrong direction.   There are a lot of modules and a lot of traffic. If the product became a full-truck datalogger, the amount of data would get huge very quickly, and most owners would never use it.   I think the first useful version would need to be narrow: - powertrain-side event evidence - selected high-value parameters - communication / voltage / reset events - pre/post event window - short report first, raw log only as backup   One distinction I should make is between active OBD/PID polling and passive bus capture. If you are polling PIDs through OBD, then yes: the more parameters you request, the lower the effective sample rate becomes, and you are adding diagnostic traffic to a vehicle that is already busy running itself. With passive CAN capture, the recorder is not asking all the modules for data. It is listening to traffic that is already on the bus. So it does not consume vehicle bus bandwidth in the same way that a scan tool polling hundreds of PIDs would. But your point still applies in a different way.   Even if passive capture does not add bus traffic, the recorder still has limits: - processing rate - storage rate - timestamp accuracy - decoder workload - event filtering - report size - user attention span   So the answer cannot be “log everything and let the user figure it out.” The product would need to store enough raw evidence to be useful, but only decode, graph, and present the important parts around the event.   A practical report should probably show: - what triggered the capture - how much pre/post data was preserved - which selected parameters changed - how those values compared to baseline - whether the same pattern happened before - whether any voltage, reset, bus-off, lost-message, or communication fault occurred - selected graphs around the event - raw data only as supporting evidence   So I agree with you. More data is not automatically better. The real product is the reduction from raw data into a useful event report.
