Leaf Spring Noise
4 minutes ago, mookdoc6 said:
does not look any different than mine?  I have 2016?  confused..........
Hmmmm, the insulator between the top two springs are different than what was on my truck before even though it's the same part number.  Also, the clamp on the front of the springs are different than what was on my old ones.  The old ones had a lot of space on each side of the leafs allowing the middle leaf to get crooked and out of alignment quite a bit.  The new clamp is quite tight seeming to not allow the leafs to get out of alignment like my previous ones did.
I don't know, these are different than what was on my 2018 even though they are the same part number.
  • Replies 178
Is there a part number for these new insulators alone without the whole spring assembly?  If so, I'll just replace my insulators.  It won't take more than 30 minutes.
I bought the biggest bicycle inner tube they have at Walmart. I cut the valve out which wasted about 1 inch of tube. Then I cut the tube in 4 equal lengths. Jack the truck up from the frame just in front of the rear wheel. Remove the wheel. This allows the rear end to hold the springs apart. i put a length of tube in front of the axle and rear of the axle. The tube was long enough that there was about 2 inches of overlap where the spring pad would be. I tie wrapped the overlap over the pad at the front and rear. Did this on both sides. So far it seems to be much quieter for me at this point. We'll see how long it stays this way.
3rd attempt to fix today after telling them it was the leaf springs and them diagnosing since yesterday. I was told it’s completely normal and it was the auto locker making the noise. Told them I was convinced it was the leaf springs and wanted to try something. Clunk, clunk, clunk all the way to Home Depot to purchase these:
https://www.homedepot.com/p/303689103
Clunk, clunk, clunk all the way home. Cut some strips and inserted between the springs at the front and rear of the spring.
No more clunk. First time it’s been quiet backing out of my garage and up the driveway in months.
Thanks for the link. Picked that up from HD yesterday and installed today and all noises are GONE!!!!  No more clunking or creaking or anything. What a life saver. I was starting to hate my truck because of all the racket it was making in the ass end.  Thanks again
Great find. I just installed the bicycle inner tube in mine a few weeks ago and that seems to have helped. How are you keeping the rubber strips in place?
My bicycle inner tube.
I did exactly what you did and zip tied to the springs. I ended up putting the strips of rubber between the top and middle spring though. I left some extra rubber hanging off because I wasn't sure if there would be any shifting and wanted to make sure I had enough in there just in case. After doing this I realized I probably should of cleaned all the goopy grease the dealer put in there beforehand. Oh well, I’m not convinced the grease will last after a few washes and some winter roads. I haven't even clipped the excess zip tie yet. Looks like its holding just fine. Not pretty, but how often am I under there looking at the shear beauty of leaf springs?  [emoji6]
I like what you did there Cupton. I may give that a shot too to see if it makes it even quieter. I was surprised how much it seemed to help with the tube where I put it.
I cant take credit for it. I got the info from this thread (4th post down) from user "Paumat".  https://www.gm-trucks.com/forums/topic/203583-clunking-in-rear/page/3/#comments
Good write-up and photo's. Helped a ton! Thanks Paumat!
Mine seem to be staying in place just from the springs clamping together. I guess if I start hearing a clunk again I’ll check them.
May not be necessary to zip tie them. I dont know. I just happened to have a bulk pack of the larger ones lying around so I figured why the heck not.
 chris farley idk GIF
Wise choice on the zip ties.
Mine are just sandwiched between leafs and after a month or so I can see they’ve moved a touch.
I stopped in at Home Depot this afternoon and picked up some of the rubber material mentioned by Cupton above. I'll try to get it installed this weekend. Going to try and ride up to LS Fest tomorrow. If I don't make it up there, the rubber will get installed tomorrow.
    • Maybe, but it seems he is the only one that has backed up data to prove what he is stating. I think he is doing this more because he enjoys it and wants to get the information out to us. He's got the knowledge and access to the proper equipment and having the funds doesn't hurt.  I would love to do what he is doing and would do it if and when I hit the Powerball.  I'm not a Tribologist by any means but love to learn what I can.   I would bet there would be doubting people out there if a completely independent lab with high quality work and highly respected in the automotive industry, put out information like this.  The world can't be pleased, one just has to take the information that they are given, do more of their own research to find actual lab data to back up what they are trying to figure/find out.  Most don't bother, they just want to believe what they first see.     I don't have the minimax but my 6.2 in my 2019 Silverado with 64k miles shows excellent UOA results with 0w-20 and for my own purposes 5w-20.  Since not much of a change using 5w. I liked the data sheet information on the SS 5w-20 and figured I would give it a try.  Still the same viscosity at 100℃.   In the end we all just do what makes us happy, life is too short to get upset over trivial social media.   On a side note, I do feel GM has dropped the ball and just cares about the bottom dollar and not quality anymore.  "Like a Rock" has been long gone.  Seems "Built Ford Tough" has as well.
    • Better than stock but that's like putting lipstick on a pig
    • Hello, my 3 month old Sierra Elevation wont recognize a trailer with electric brakes? All the lights work correctly, but no power to the brakes?   This is the factory installed brake controller. If you manually push the knob, the display shows the power % but does not light up like my 2022 silverado.   I have an appointment with the dealer, but was checking to see if anyone else has seen this issue.    Thanks,
    • Been using SS 0w-20 from new, but wanted to change to the 5w-20 because I liked the data on the data sheet, to me it seems like a little better product. But as you can see, not much difference. This is also with running a mix of 10 gallons E85 to a tank topped with 93. It isn't a flex fuel vehicle so any higher I get a CEL for running lean on both banks. Yes my mileage takes a hit. Instead of 20 mpg I normally get on trips I get 17mpg. This is also using EaO17 filter.  What is amazing is I have the AMSOIL cone filter on it since I have the GM Performance intake installed and that air filter has 44k miles on it.  I just take it out and shop vac it off once a year.  I use the upholstery tool on my shop vac.  Works well.
    • So, lot's of googling and reading, and a trial fit found, that indeed they hit the newer fatter caliper. I did some re-testing today, and found just 3/16" worth of washers was enough for the wheel to spin freely. I added 2 more on each, and again it spun freely. Tested lock to lock with the 4 washers, about 5/16" not quite the 3/8" Im considering, but pretty close. No issues. I've been looking at the BORA .375" spacers and using extended lugnuts to get back lost thread due to the spacer. All the ET lugs I've seen are all .33" reach inside the wheel lug holes. For those that don't like spacers or think they're unsafe, I think it depends on what type of spacers you're using and making sure you get good quality hubcentric ones, and if you're using bolt on ones, regular mainenance, checking the spacer lugs. Not wanting or needing that much spread. Looking for the minimum that will let me run these rims and tires.  it does look to stick out a little, but I really want put these on. and use the stock all-terrains in the winter.
