2016 Taillights
Thank you. This is something we were thinking about. Just has to make sense. I will try to get some pics of my "hack job" to post for everyone.
When you bought the tail lights, did it come with the harness that plugs into the main rear junction box under the bed?
  • Replies 142
Fantastic.
Would love to see pictures of the hack job.
As I said before it would be a hack job unless you have the correct connector laying around and pinned it out, which you finally replied you did.
Yes it does come with the harness. The problem is. the harness on the LED tail light is square. Where as the plug under the bumper is more of an oval. So you cannot plug the new harness into the old obviously.
So we ended up testing each output of each wire from the harness already on my truck. Then we tested the output of each wire off the LED light. We ended up shortening the harness OFF the tailights themselves. Added a nice pinned connector. On the stock harness FROM the truck, we cut off all the OEM bulb harness's. And again repinned a nice connector to them. Then we just plugged them in.
We did wire in a resistor on the turn signal side of things as it does hyper flash and does give you a warning on the dash. That was again properly wired to our harness. There are no butt connectors, twisted wires on this. Everything is crimped, pinned, soldered(resistor wires).
We did notice that their was an extra red wire on the LED harness. When we looked at the schematic that was provided above, it appears its another ground wire. We determined that has to be something to possibly do with the new 2016 bcm module.Maybe another trigger for a warning or something? It however, does not seem to affect the function of the tail lights. My parking lights work, signals work, brake lights work, signal with brakes, lights flash properly when i lock/unlock the truck. Come on when the truck is remote started ect. Nothing seems to of been lost.
Check out my hack job guys!
Wires in my hand here are the resistor. Hadn't mounted it at that time. It to has been "hacked" together with a proper connector.
Are you going to drill the "hacked" resistor into the bed or mount it on something?
Always was frustrated with how warm they got.
It is mounted. There is a hole at the top behind the light on the frame. It is mounted inside that. Mounted to metal directly. Nothing touching any plastic. That "hacked" up good enough for you?
Far as I'm concerned, this is about as legit "OEM" install you can get.
Sure I guess it's "hacked" up enough for installing $950 worth of tail lights.
Nice install.
You're special. Maybe that's what you'd pay. I however did not. Maybe you should leave your arrogant remarks until you know the finished product. Thanks. Move on
Looks great man. I don't understand where all the hate is coming from. On other forums people get encouragement for being the first to tackle something that no one has done yet.
Are you going to reveal your source or are you planning on modifying and selling these? I'm really interested in price more than anything. Every mod has a threshold.
Good job man. As a new truck owner I appreciate this site for all the visions that you guys bring..
Sent from my SG Note 4 on Tapatalk
I'm impressed this is bugging you so much. Grow up. You want to keep saying hacked up even in response to others so I continued to as well.
I even comment it was a nice install. Oh well.
I comment $950 because that is the cost for a set that work for GMC. Chevrolet may be cheaper.
Eh. Your just one of those guys. You pre judged, and you were wrong. I like quoting you for that mere fact. Don't judge something till you know the facts. And yes you are correct on that price. I'm fortunate enough to be in the after market performance parts industry. It helps even with OEM items.
In response to your resistor mounting. I made a little bracket for it. I did not want it mounted to anything painted or plastic with how hot these things get! Took alittle finagling. But I think this will work great. Aluminum bracket so hopefully that'll help cool it quicker. All with stainless, locking hardware. Didn't need to drill any holes into the truck as there was a factory hole not in use.
You're absolutely right I was wrong! I even admitted that. I made my statement based on previous experience. You are the first exception to this being in the aftermarket performance industry.
On to the resistor. You nailed half of what I was curious about. As I said before I hate how hot they get and I see aluminum is the way to go.. have to remember that.
My other question is did you hard wire the resistors wire into your harness or are there plugs so that the tail light can still be unplugged from the truck should you ever need to do that?
    • Thanks for all that information, I might purchase one and see if it will work for me, if not they may let me return it! Yes for sure the tires are definitely within limit for my truck empty, and when I do tow I'll definitely make sure to raise the rear psi for the amount of weight that's going to be on it.
    • Yes exactly, more and more these days people/companies are afraid of liability issues so its easier just to say no rather than risk putting their neck on the line.    I will say with the Autel unit or when I used it last year on my truck, it wasn't like I could choose the 2025 model year or even the 2024 model year as that option was not there to manipulate the placard pressures but had to go back to 2023 or there abouts and then it showed up as an option, odd but that was how the software was then and I can't say one way or the other now as they throw out updates every so often. I still would talk to your tire dealer though to start with and they may do it for nothing but also they may have a comment on a better unit to purchase. All I know is that one of the large tire shops in my area happens to use these Autel units for their use and set them up to use the wifi and all of that jazz for constant updating because each tire tech has one handed to them by the shop but I just plugged it into my laptop to update it and yes if one is bought it has to be registered so you can get the link to do updates and then the unit has to be updated before its even used. I am not at all techy so it took me a bit but anyway just a heads up for anything you buy, most likely it will need to be connected to a computer to access the internet to have it updated to the latest software version before you can put it to use.   If your truck is near empty, those tire pressures you listed are a very safe upper range pressures to carry the weight, both the front and rear as I know they could be run lower yet with an empty truck. And if its a trailer and not some motorcycle your going to strap onto the front of your truck on a rack, you shouldn't have a need to inflate your front tires if your at 55 front already, its the rear ones that would need more air if you have much hitch weight.
    • Thank you, I'll check that Autel scanner out and see if it will work for me! Ya I can see GM's point of view if they lower the psi set value for someone and the person sell's the truck and the new owner puts the factory tires back on then their could be liability issues cause the psi warning light wasn't coming on when the tires were under inflated for towing their load and then it might be able to be traced back to GM lowering it.
    • I had a similar but different response when I talked to the service manager where I bought my truck in that he said GM corporate won't allow them to lower the placard pressure setting as they would get their hand slapped but that of course they have the ability to make that change. His suggestion was simply go to a tire dealer or third party shop that is willing to reset the pressures lower. However I chose to buy a tpms tool and partly based off of this very forum as it had been proven to work on the 2024 model ( Global B system ) and while I could have paid lots for a full two way diag tool, I didn't want to spend that much and bought the recommended Autel TS 508 and it will reprogram the 2025 model and assume it should do the 2026 as well. However the tool is rather proprietary to reprogramming Autel tpms sensors so that is a function I will never use, where as a real two way scanner would have many uses but also have yearly subscriptions etc where this 508 is free updates for as long as they put updates out for the unit. In any event it worked to lower the placard pressures and I often use it to adjust my actual tire pressures although will check with a mechanical gauge as well sometimes just to make sure that tires tpms sensor isn't lying to me.    My suggestion is either buy a tool that you know will work to adjust the system or start out by getting the tire shop you bought your tires from to reset your truck and if after that you still want a unit to do it yourself, get one at that point.
    • Here is an image of a quick Google search about these tires on my truck and it's exactly same psi recommendation the Toyo tires company gave me!    I'm not looking for anyone else recommended psi or anything, I'm just looking to see if anyone knew a way to get rid of the factory low psi warning light, because I'm not running high psi and ruining my tires when I'm not towing!
