Question, what is the bulb number for the smaller bulb on the outside of the turn signal? The main signal bulb is 3157 I believe but I can't seem to find any info about the other smaller one and need to replace it.
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
