Headlight Illumination Issues
deputy
called my dealer here in the USA, classic of carrollton, and they hadn't heard of this bulletin. Is there a TSB number or what should I provide for him to find it in the database? 11th digit on my VIN is G.
  • Replies 1.9k
PIT5374
-Skeet
While I was picking up my Denali this morning from the dealer, I told them of the bulletin. The service writer pulled it right up, read it over, said he'd get the bulbs and give me a call when they were ready to do the upgrade. :)
Will report back once that is done.
Called my dealer about this twice, I gave them the TSB, and they told me it is not showing up as a TSB for my truck. 11th digit is a Z. Bought my truck 12/23/14, it was on their lot for months. Any other suggestions?
*edit: Frustrated I called the local Chevy dealer, the nice woman on the phone said it popped right up, and she's not sure why they couldn't find it...I guess my service people hate me because I want to see when I'm driving at night. Unfortunately, the Chevy dealership said I would have to pay for the service since they are not GMC.
My dealer said same thing. So im good with it. They said it takes about 2 hours to do the BCM update
""""Also called TRS to see if this would have a positive impact on the Morimoto kits""""
Good point.. what about those of us that have upgraded to HID's? will this update have a positive, negative or neutral impact?
Well dealer just called. They have me for install on 3/16. I will say that's service.
My dealer called me earlier and said bulbs are here, bring it in tomorrow. We need it for 45 min. to an hour. New bulbs and reflash.
Where are you at in PA? It might be road trip time haha
I want some reviews after. It seems the only people who had them done left this thread.
First thing that pops into my head,"Welp, my problem's fixed, bye suckers!"
Pretty much. But then that would mean this upgrade is phenomenal. Which gets my hopes up.
I went to a local dealer (not where I purchased my truck). They haven't heard of the TSB but looked it up and ordered new bulbs. My 11th Digit is a G and I bought my truck last June.
Hopefully I can get the 4x4 recall and my GPS fixed at the same time. I've only had my headlights fog up once, but I might get that addressed as well.
Well here's the thing. From what I understand, the BCM update consists of more voltage to the bulbs. I'm running Philips Diamond Vision 9005 65W 5000K bulbs that are rated for 12V. The bulbs are brighter and whiter than stock (65W compared to 55W). So then, will more voltage shorten the life or damage standard 12V bulbs? Are the Vosla bulbs designed to handle more volts? What will more voltage do to those running LED's or HID's? I'm happy with my bulbs so just wondering if I do the BCM flash what would the extra voltage do to my bulbs.
^^^ +1
Anyone know what the new voltage is after the flash? I thought I read it somewhere, but after reading through about 100 posts, I give up lol.
-Skeet
    • You have to have the last word.
    • I am sure that was quite the pass experience and not a great place to experience during the winter when the conditions are not good. I've seen video of that pass and also more detailed information and pictures about the wrecks at that one hair pin turn where tractor trailers have flown right off the cliff and I am sure from all the warning signs that you know the exact curve that was !. After all there is a reason why a song was made about Wolf Creek Pass !. By the way and I didn't realize this either when I bought my truck as its nothing I even thought of that would be programmed into the cruise control and this occurs in either the basic or the more advanced cruise that controls your distance behind a vehicle and that is the brakes going down a hill are being applied as soon as the vehicle goes a certain speed over the set cruise speed. While it certainly does force downshifts in the transmission as you found out with cruise on while going down hill, its also dragging the brakes as needed to keep the speed controlled to what the cruise was set to. For me, I find that unsettling simply because I have no concept then as to how MUCH brake input is being used a and just how hot are those brakes getting and the wear factor as well. I can see that system getting a person into trouble on long mountain grades while pulling a trailer as it would not only be standing on the brakes of the pickup without any driver input, it would also be automatically applying the trailer brakes and it could cause a run away unit by overheating the brakes. Its one thing on a shorter hill and if the driver allows it to do its thing but on a long mountain grade is where things could get so out of hand. As someone a while back on this forum said, they had someone following them at night I believe on a down grade and had the cruise set and the person behind them could see the brake lights being energized all the way down the hill. I figured when I saw your comment that you didn't know and would have no way of knowing that your truck was applying the brakes and that you would and rightfully so assume you only used the brakes when you pressed on the pedal to slow down more than the cruise set speed for the slower sharp curves. So its good knowledge to know this about the newer GM trucks, certainly when doing any descending on long mountain grades. In the future try kicking off the cruise and use the the manual mode on a pass to see what that is like as I know myself when I first experienced it I thought no way can this engine be holding me back this well and tried the same hill in manual mode and sure enough the engine was revving way up and still could not hold the trucks speed down like it could in cruise mode.    Fuel mileage, that is where a really low sleek type of car can do better at higher speeds, certainly it starts sucking fuel too but a tall pickup is pushing massive amounts of air and also allowing a lot more air under it and the tow mirrors as in elephant ears pushing through the wind  as well. Driving like grandpa is about as good as one can do when driving one of these if trying to get the best fuel economy they can. I bet these trucks would get the best mileage they can if driven on a freeway in Florida if not busy traffic at a sedate speed and that sea level elevation without hills, vastly different then Colorado !.
    • It’s over for almost 24 hours. Are you playing Eddie Haskell?
