7444 LED bulbs in stock taillight housings -Thoughts?
I like how the factory '14+ tail lights look and, of course, OEM light housing durability is typically superior to that of aftermarket components.
Anyway, I have considered swapping the factory bulbs to 7444 LEDs (in white or red) and seeing how well they work in the stock housings. I am expecting to need a resistor kit, as I have had to do with past LED conversions on my last truck. Thoughts? Anybody else done this?
Thanks for any input!
Wondering about this myself. I do know you have to match the color of the bulb to the color of the lens.
https://www.superbrightleds.com/cb/car.lens_color.html
"Which Color LED should I use?
For best results the LED color should be the same as the lens color or if bulb is behind a clear lens, use the appropriate color for turn and brake light functions.
As an example: a red lens will filter out all but the red portion of the light so if the light is all red, none or very little light will be blocked by the lens. The light from a White LED contains very little light in the red portion of the visible spectrum so most of the light would be filtered out by a red lens."
I couldn't get mine to work. I ordered from Super Bright LEDs and even the CANBUS wouldn't work. I returned all the bulbs. I bought the $25 bulbs since the $15 bulbs were too dim. Only one would emit while the other bulb wouldn't turn on and if I used the directionals the bulbs would go out. I am buying LED taillights for almost the same price I spent on bulbs.
I appreciate everyone's input. Craig, could you post a link to the ones you bought so I can compare to a few sets I'm looking at? Thanks!
I used the Philips led red 7443 with a resistor and they look great
Where did you order these? Links perhaps? Thanks!
I bought the LEDs at pep boys and resistor on amazon CUTEQUEEN TRADING 4pcs 50W 6Ohm LED Load Resistors for LED Turn Signal Lights or LED License Plate Lights or DRL (Fix Hyper Flash, Warning Cancellor) (pack of 4) https://www.amazon.com/dp/B00DCULNXS/ref=cm_sw_r_cp_tai_PYyBxb6R530HV. https://www.bulbamerica.com/products/philips-7443-led-red-stop-and-tail-automotive-light-2-bulbs?CAWELAID=120150920000761693&CAGPSPN=pla&CAAGID=16011777366&CATCI=pla-118898802486&catargetid=120150920000797995&cadevice=t&gclid=CjwKEAjwtLO7BRDax4-I4_6G71USJAA6FjN1zX2HqP83Yx_LnFFu0XqULIMhgmeLUSHk5zAVacXiJRoCAL3w_wcB
  • 1 month later...
Mind sharing how you wired the resistors? I have the same Philips 7443 bulbs and am having a heck of a time getting both bulbs to work without giving me the error message.
    • Late reply, but yes—it works on the SLT trim. Compatibility comes down to the plastic shroud shape behind your mirror, not the trim badge itself. On the SLT with auto-dimming, it uses a plug-and-play Y-harness off the mirror/rain sensor power, so no need to run wires down to the OBD port. If anyone's ever unsure about fitment, just drop a photo of your mirror housing and we can double-check it.   Appreciate the detailed feedback on the install! On the windshield glare—we actually took feedback like yours and developed a dedicated CPL (polarizer) filter to cut down dash reflections on sunny days. If you're still running the cam, shoot me a DM. I'd be happy to send a CPL filter over for you to test out—no charge.
    • There are no stickers in your glovebox?
    • Look at the numbers on the stickers in the door jam...
    • Yes, every time the developer updates his code, you must recompile. I will private message you with the latest because it changes pretty much with every version.
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
