The thread here (http://www.gm-trucks.com/forums/topic/188524-dual-climate-control-for-2014-2016-silverado/)
...........in the Buy & Sell section got me thinking ............Hmmm, maybe this would work? I have a 2015 GMC Sierra SLE Reg Cab, and I thought it would be a great idea to have the Automatic Climate Control feature; set the temp and let the system figure out the rest. The seller does state it's "Plug and Play", right?
Wrong!
So I picked a head unit up off eBay for $100. I figured, what the heck! It probably won't work, and maybe all I will get is a digital temperature readout. Anything else would be a bonus.
Install takes all of 10mins.
Original Unit:
New Unit:
The Rear Connection Port:
The dual climate control feature does not work. When you change the drivers side temp, the passenger side follows suit
The Automatic Climate Control feature does not work. You still adjust temp and fan blower separately.
So all you really get is a digital temp readout. Hope this saves some of you owners a few $$$
I assume there is another controller module you would need as well, right?
Curious if the temperature reading is accurate too.
you need the temp sensor also. i researched this and it turns out that the light sensor on top of the dash is also where the temp sensor is. to mske it work you need to buy the sensor part number 13578464, this sensor has temp sensor and light sensor. It does look nice in your dash
Edited by silveradosid
Thanks! Really appreciate that. I will assume the exiting wiring is already in place haha.
Yeah, this isn't an easy swap. As Chris just said, there are other sensors and doors in the HVAC system that go along with the in dash module.
Ordered the sensor, we'll see how that goes. Don't really care about dual climate control feature, just want to have it adjust fan speed automatically. Thanks guys!
dual zone is a different airbox The A/C, fan, diverter assembly is a different component, and it's a large assembly.
The whole IP (dash unit) would need to be removed, and a different "air box" assembly installed. Supported wiring, solenoids .... Really not a home project unless you're a masochist.
Nice to have a bit more bling though.
Edited by 15silver
    • 2023 GMC 3500 HD, SLE, 6.6L Gas, 4x4, 6 Spd Options:  SLE Convenience Package; Driver Alert Package 1; Spray on Bedliner; X31 Off Road Package; TRAILERING MIRRORS, HEATED POWER -ADJUSTABLE, AUTO DIMMING, WITH TURN INDICATORS WHEELHOUSE LINERS, REAR INC. REAR AXLE - 3.73 RATIO INC. GVWR, 11,350 LBS. (5148 KG) INC. FRONT AND REAR PARK ASSIST, INC. ULTRASONIC     I have been launching my new boat and noticed some things related to the parking brake.. I usually set the parking brake (habit) when on flat ground for typical driving.    When backed down on the launch ramp to launch the boat and I place gear selector into Park, the parking brake activates automatically. My second nature is to set parking brake manually and noticed I was turing the parking brake off.  The parking brake appears to be setting itself automatically.   I looked all over my owner's manual and only found references to being on an incline and manually setting parking brake, or at times parking brake will be auto engaged, but nothing specific to my situation.    When is the parking brake automatically engaged?  Under what specific circumstances?  Can the auto set parameters be changed?     I like the auto set feature.  It would be nice if always engaged when shifted into Park and released when shifted out of Park (like my wifes 2025 RAV4).   Thanks!
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
