Boosted trucks
Jb716
I have a 2014 silverado with the 5.3 have a supercharger and was tuned for 10 psi it was my DD and I raced it a total of 10 times one day I was crusing at 40 mph when I heard a pop and everything dropped looked further and seen #2 piston rod came thru the block and later in the shop we seen that #7 rod als3 blew the block out and all the other rods were broke
I have a boosted 92 Chevy, it has a 383 dart roller heads MSD and a whipple. This set up has been in 10years and 40k miles. I have the 10lb pulley on it and have a controller on it for timing and boost. I have pillar gadges to monitor lean and richness with a big green go light. If your going to run boost and not moniter in real time you could go boom. The boosted truck before that was a ford with a vortex put a 100k on it before I traded. Never had a problem. I suspect you were running to much boost on a high compression engine without safeguards.
yeah? So?
+1 and this in the incorrect forum section
^^^ +2. Why didn't you move it Ryan? I can't, not a mod.
Check again it was moved when I previously posted
Ryan
Ryan
I can't see where it came from, or at least I don't know how to look. Just figured that it fit better into the Performance Engine Tuning section since adding a blower then grenading the engine would not be a factory recall or TSB. Its all good... :cheers:
Bad tuning?
Sent from my SM-G930V using Tapatalk
Speaking of supercharged.
I ran across an article the other day about SLP now offering several stages for the 14-16 Sierra / Silverados. :)
The cool part about SLP is already work with GM. And even better part is you can get 36/36 warranty with it. :D
What are the things I found most interesting on their side as for 400 and something bucks they are offering an SLP tuning package which of course includes a tuner and an SLP tune. Up until now we've been told if we put a tune on these trucks little void the warranty. Now SLP is offering a tuner which should keep the warranty for like $449.
Hmmmmmm..... Christmas present perhaps? Heheheheeee
And make sure you look at their other packages like they have one with a CAI and Catback AND a tuner with a custom tune which is actually sort of a deal all things considered.
http://www.slponline.com/product/620068--2014-2016-chevrolet-silverado-gmc-sierra-supercharger.html
Sent from my SAMSUNG-SM-G935A using Tapatalk
Got her back up with the new 5.3 and slapped my supercharger on it on the interstate I'm getting 17 mpg
