Best Battery for a 2014 Sierra?
Mine just died, what would you replace it with if it was you?
Thanks
  • Replies 39
I know most will say factory AC Delco which I'm not against. But, I've had great luck with Duralast especially the platinum series which I was told is like a hybrid between a normal battery and an Optima. The platinum and an Optima should be the best 2 options since these trucks have so many electronics now.
You still under warranty ? If so see if the dealer will replace it ..
No, 3 years old, 63k miles
I have my replaced my last two trucks with Duralast and never had one issue . Going to change mine soon as it seems this factory batteries are only lasting 3 years or less .
Interstate is a good battery, as is the Duralast. Surprisingly, Wal Mart sells a very highly rated battery too. Johnson Controls seems to make and distribute the best batteries.
OEM and add a nice charger/maintainer <- battery will last about 10 years. no charger/maintainer most average every 3 years.
Are you suggesting this even on a daily driver?
With that mileage, I assume yours is a daily driver? Assuming so, crazy to think the battery still doesn't last very long.
p.s. everytime I see your truck in sig pic I say to myself, man that is a really good looking truck with 10/10 stance.
A charger/maintainer will do you absolutely no good in Phoenix,AZ might as well burn 100.00 on that idea?
dealer warrantied mine, so I went ahead and had them install, and wire in a second one. If I were buying, I would do interstate, or optima.
