Can the new 2017 capless gas filler be adapted to older trucks?
Aubie_01
Everytime something new comes out the nay says say it can't be done, while the doers are making it happen. Goes to show. Some people wonder around in circles wondering what the hell happened while the leaders are making stuff happen.
If the cap won't retro, nothing stopping you from buying a new fuel neck assembly with a capless fill adaptor and installing it.
There is nothing wrong with the capless system. Ford has used it on the F150 since at least 2010. A friend bought a 2010 F150 brand new, has not had an issue with it.
I am just wondering if the new system will throw a code on the computer. I think leaving the cap off of the 2014 - 2016 can cause the check engine light to come on?
What causes that is just when it's not sealed. I've bought a cheap key gas cap for my '98 and it threw the code. Put the stock one back on and no more code. So I'm sure they've designed it so it seals without an actual cap.
Personally, even if it's sealed there's nothing to keep dirt from going in the tank when you put the nozzle in. With a cap the cap is at least protecting that area so nothing can get in the tank. The door isn't sealed so dirt, dust and whatever else can easily get into that area. It would keep the stuff out until you go to put the nozzle in and then it can fall in the tank. So I'd still want a cap. Really even if you could do it, the money wouldn't be worth the 2 seconds you'd save from not having to take the cap off. The only plus is that there's no cap to lose, but I don't have to worry since I have an AMI lockable gas door so I put the cap and my keys on the toolbox.
  • 6 months later...
Does anybody know if there is a Locking gas cap for the cap-less fill system? It's designed to stop a syphon hose from getting to the gas, just want to stop other "stuff" from getting put in the tank.
Thanks,
HH
Thanks,
HH
In the owners manual baggie there is a special funnel that gets down below the second sealing flap. I suppose you would need this if you had to add gas from a gas can rather than the pump.
Thanks... I did find that funnel in the console when I got the truck. My question is regarding a locking fuel cap that fits the "No Cap" type of fuel neck as I don't want people putting anything in the gas tank. Right now all that is protecting the tank is the outside flap (which can open) and the secondary flap in the gas neck. Anybody could pour oil or sugar water or any other liquid into the neck of the fuel tank and I'd never know until it got to the engine....
Yeah... I live in Detroit so we have to think at least one step ahead of the local scumbags....
HH
I'm guessing the new capless system has a better sealing filler neck flapper valve. Probably work if the neck and door were changed, but I haven't seen the new trucks up close.
I put gas in my truck about 3 times a month, now that I have a car. At a guesstimated time savings of 8 seconds per fill up, that's 24 seconds a month, or 288 seconds a year (4.8 mins), with my expectation of keeping this truck another 7 years, that's 33.6 mins of my life. Figure it'll take me more than that to purchase and install the whole thing, let alone the cost and time in my life it takes to make the money it costs. So, I'm good with keeping my screw cap. :dunno:
HH
Were you running a locking gas cap before this truck?
    • $5.19 for regular...
    • My office is slowly filling with Blazer parts. Getting ready to do the big bang of repairs. Intake (second time), water pump, radiator, hoses, and I'm going to re-seal the timing cover where someone went hog wild with silicone. Might as well, because I don't think that's done right.   There's a local tow yard that I didn't realize also has quite the inventory of junk vehicles. This is an old school junkyard. No waivers. Cash only, you were never here if anyone asks. Don't piss off the owner, or you'll end up in the back of one of those cars, headed for the shredder. And if you see something, don't snitch. Cars stacked double high, wasps nests, trip hazards and junk everywhere. I found a few little odds/ends for my Blazer. The $20 I spent was worth the experience alone. But I was never there. What yard?   I officially love/hate this truck. It's so out of my wheelhouse, roughest vehicle I've ever owned. Every. single. repair. -is so hard-fought, everything that can go wrong, goes wrong. Currently in a hate phase, and kind of wish I was closer to sending it down the road with a lucky new owner, to be honest. Preparing for the day when I tear into this thing...lots of pre-funk with Ibuprofen.   Rock Auto sent me a bad reman rear wiper motor. It was a bear to install. The tailgate in these things has about eleventy-billion fastners and pieces and things that need to be uninstalled/moved just to access the shoddy rear wiper motor. The casing on mine was cracked clean through, btw. Nice, GM, nice. SO I got this new motor installed, hit the switch, I see it wig-wag (without the arm installed) and think I'm golden. Reassemble everything. With the wiper arm installed I gave it one final test. Time to clean up and take the other half out to dinner, collect a paycheck, right?   Nope. I hear the plastic worm gear stripping as the arm hung up. Just like my broken motor. Weak/old and shredding itself internally. I can assist the arm and the range of motion is normal, and it parks correctly. It just doesn't have the poop to actually sweep the arm with a blade on it. Oh, hell. Turned the key off and shut the shop door behind me. I get to do that over again, too.
    • A complete delete is the most thorough mechanical solution, but it is also major engine work. On a quiet truck that is still under extended warranty, opening the engine purely as prevention is difficult to justify. A plug-in disabler stops commanded cylinder deactivation, but it does not remove or repair the collapsible lifters, so it should not be treated as failure insurance. I would keep the oil full, document the maintenance, and have any persistent tick, misfire, or loss of power diagnosed promptly. If the engine eventually has to come apart, that is the logical time to compare an OEM-style repair with a complete delete. The right choice depends on the truck’s symptoms, warranty status, expected ownership period, and whether the engine already needs to be opened. We explain that decision in more detail here—full disclosure, this is our own guide: https://www.bluev8.com/blogs/news/do-you-actually-need-an-afm-disabler   One exception: some 2021 L82/L84 trucks have RPO YK9, meaning cylinder deactivation was already disabled in the factory ECM; on those trucks a plug-in disabler is redundant, although the AFM/DFM hardware remains inside the engine.
    • Brought my 2015 Colorado into the dealership to check my touch screen issues, had that ghost touch thing happening. They said I needed a new touch screen and they could either order me one for $500. The lady at the service deck was nice enough to tell me I could order a touch screen online for less, she did stipulate that the touch screen had to be factory OEM, you can't pair an aftermarket screen to my radio seeing it was 2015, it had to be a GM factory OEM only. I found a few on Amazon and Ebay by the numbers on the back of the old screen, DJ080PA-01A GM# 22740886, Some said "OEM" in the description and others just said "Replacement". Would a replacement be the same as a OEM as long as it had the same numbers on the back of the screen? In some of the descriptions they also show different brand names but same numbers, is that an issue?
    • I have both but typically use the 4 legged walker (wheels on front, ski's on back).   The four wheeler is starting to be used on "longer" outdoor walks.  The 4 legged walker is particularly helpful in practicing good walking posture.  Both of my knees are at different stages of recovery and I'm trying to not develop poor habits.  I can actually manage with a cane but it's very difficult not to favor one leg over the other.  My PT recommends I continue with my 4 legged walker for a while.  Yesterday was four weeks since my last knee replacement and I'm excited about my progress to date.  It has been a hell of a rough journey so far but it is exciting to witness  systematic and continuous improvement.  I went for years watching the decline of my "mobility".  It seems that everyday now I am alerting my wife to something I can do now that I couldn't a day or two ago!  I encourage anyone facing the prospect of knee replacement to share any concerns with others who have had the surgery.  It isn't an instant fix but rather is a considerable amount of short term pain for long term gain.  Recovery time and pain levels vary for individuals post surgery but the end results are typically very positive and I've never encountered anyone regretting having had the surgery.
