Things I done to my truck for $50 and under, including things I already owned so I spent $50 or less to complete. You can check out my YouTube channel or instagram for more pics on this.
1. Wireless charging on front arm rest seat.
2. Footwell and steps lighting
3. Driver assist handle.
4. Led pods as fog lights
5. Led flush mount backup led pods
6. Grill flush mount led pods
7. Switchback leds on turn signals and leds for lights over the truck.
8. ANDROID TABLET Nexus 7 as head unit. Only needed paint for this mod, as I had extra head units and all the materials.
9. Bluetooth Steering wheel control for the nexus 7.
10. 30ft tow strap
11. Custom Decepticon under seat storage box with leds
12. EBay seat covers
Many more mods I can't think of right now, everything on the cheap.
Check out my YouTube channel and instagram @egroj_legnar
YouTube.com/jorge_dropkick_rangel
Edited by NitroDatsik
I'm looking at PlastiDipping my bowties, and still debating on doing my rims. Will I only need to clean the surfaces that I want to "dip" or do I need to rough it up?
Waymon, where did you get your phone holder? How did you get it to stay in the pocket?
It's just a suction cup window mount. I snagged it off of Groupon a few years ago. The suction part was junk so I cut it off.
To make it stay I trimmed both edges down to flat edges so they would wedge in the back of the pocket. The pocket is tapered. You just wedge it back there real good. Doesn't move or make noises. Took a day or so to settle in but it's solid now.
Cleaning it with soapy water then rubbing alcohol to remove any remaining oils. No sanding. Mines still perfect 10 months later
Just clean them and make sure they are dry. Tape them off nice and then spray light coats of plastidip. My emblem was about 8 light coats
What process did you use to install yours? I'm looking at doing two of these, definitely one, at 2x12.
Went to Lowes, had them cut it to length, and tossed it in the slots. Under $5 and 5 minutes.
I want to say it was 62 or 64 inches, can check if you need me to.
This looks like it on amazon. Hopkins SC-CHA Go Gear Console, (Charcoal) https://www.amazon.com/dp/B000FGEF64/ref=cm_sw_r_cp_api_EL4QybF298KZH
Found it on autozone: http://m.autozone.com/interior-organization-and-cargo-management/console/hopkins-console/266300_0_0?location=
Autozone is black in color. The amazon one is gray (charcoal)
you rock! Thanks!!
I had that in my 03 WT. however I screwed mine down to a piece of particle board and velcrod it to the floor.
If you are going to plastidip your rims make sure you watch a few YouTube videos and do it correctly. Make sure you put on several Coates. I bought a set of gm rims on Craigslist that had plastidipped but the guy put it on too thin. When I went to remove the plastidip so I could redo it the areas it was sprayed thin did not peel off. I had to use a pressure washer and paint thinner to get it off the rims.
I can measure it. My lower corners seem to be rounded in the bed, I may have to sand them some to get them to fit.
i cut the bottom corners at 45 degrees in order to get it to lay flat on the bed.
Edited by bndawgs
Ok so the new cap wasn't $50 but the LED license plate lights and High output LED reverse lights were under $50 and really bring the truck together. I'm not sure why GM cheaps out on the reverse & license plate bulbs when the rest of the truck is LED ?
Also please ignore the truck looking like a mess, roads are a mess here :(.
Painted hitch again. Did it at work with their paint. On the clock. [emoji1303]523c741f2f2e3eb432a2b75cb6ec54f7.jpg
  • Like 4
HA, I haven't washed mine since October. Dealership washes it for free each time I get my oil changed (Nov & last week), they do a decent job. Grabbing new headlight bulbs later this morning, watched one die about halfway to work tonight, and some LED exteriors.
Slow day at work? I may repaint all three of mine (2", 2-5/16" & Pintle). Why did you choose red?
    • I had skimmed through that article when you posted the link and honestly I felt rather defeated in a sense and realized that all these years in changing oil that in fact putting in what I was told was a good quality oil was probably not filtered as well as it should be although the filter put on the engine would be what ( as long as it never went into bypass mode ) would be the final filtering of the new oil that the engine components would first see, but then the filtering media itself is not up to par to what is ideal because a full flow filter would be too restrictive to filter fine enough for the engines best outcome in the long run. Only one of our tractors over the years which was a Versatile with a 855 Cummins had a separate bypass filter, some engine manufacturers did spec a partial bypass system within the main oil filter but I don't believe any other trucks or equipment I was servicing used such a filter. No doubt a product like the Amsoil bypass system is of benefit as long as nothing goes sideways with the extra plumbing and filter such as a rupture/leak that could cause the oil to pump out of the engine ( yes that Versatile had a remote canister with hoses routed to it as well ). With the idiot egr system on a diesel and as a result forcing a lot more soot into the oil, that certainly isn't helping the diesel engines cause or as you pointed out the GDI engine issue with creating more soot and aside from having a fancy secondary filtering system, changing the oil more often helping lower the total soot load.     So oil manufacturing and the end product is not something one can control and I wonder if there are specs on what various oil packaging companies produce in particle count or size. As to the filtering, if the OEM is not designing a filter size and spec that is really what it could be, they too are short changing the end user and so what is the answer. Of course as you say the oil side can only do so much if the air side isn't keeping up its end of the picture and air filters are only so efficient and if in a dusty environment such as farm or construction or driving gravel roads there is a lot of dirt to filter out and some of that ends up into the air stream.    Of course the irony in places like where I am where they dump the salt on the highways but also will mix in some calcium or outright pure calcium for problem road area's, or using calcium as dust control on gravel roads, the vehicle that gets used in that environment may rust out before a properly engineered engine and maintenance finally wears out so one has to face that reality in the rust belt.
    • Has anyone run these on their 2500?
    • have you stuck with dealer oil changes since then? I made the same switch after getting tired of crawling around under the truck, but I’ve found some dealers are way better than others about getting you in quickly. Curious if yours has been good about scheduling or if you’ve had to look elsewhere for quicker turnaround.
    • Thank you.   I am set on a 3.0 Duramax as my previous truck with a Ford Ecoboost had just as many, if not more, "common" issues.  Cam phasers, timing chain issues, 10-speed valve body and CDF drum, emissions issues, etc.  So I figured, why not get 2x the fuel mileage (these things got 27+mpg on every mixed city/highway test drive I put them through) and better towing capability with resale value to boot?   My minimum, shortest trip will be 50 miles 1-way and I regularly go out of state with a travel trailer.  I'm planning on using this for a marketing/event promotion business also, which would require regular towing of trailers for bands, DJs, sound and lighting gear, along with my personal camera gear for filming events.   Looked at other trucks in the $30k+ price range but the issues seem to be everywhere, plus too many with gaudy mods.  I'm literally sticking with RWD trucks because they tend to be actually used as trucks, vs. the 4x4 models I've seen with unsafe lifts, huge tires, and general mods that would affect reliability (I'm wondering if some of them were tuned, hence the aggressive throttle response and hard shifting).   So my goal is to find a stock, 3.0 with 1 or 2 owners, in good physical condition, and decently well maintained.  Can't seem to find that up here, everything in the $27-30k range has had multiple owners, smoke smell, issues, or body damage.  Or the ridiculously modified trucks with 80k miles for under $27k but lots of problems...
    • That’s pretty tough Grumpy. I reread the previous few posts. They all reference oil changes. Much like your last thread. In my humble opinion it keeps things interesting.
