Finally got the step bar lights added. $6.00 for lights and $3.00 for a package of T taps. Already had some extra wire on hand. The lights are sold as a pair so I only used one per side. Pretty impressive little lights.
attachicon.gifIMG_20170414_191053473_zpsynpgztq3.jpgattachicon.gifIMG_20170414_195029460_zpsmpzg36fp.jpgattachicon.gifIMG_20170414_195219271_zps2fbf9iep.jpgattachicon.gifIMG_20170414_202030635_zpsbozyrg7r.jpg
Very cool. What did you tap into? Any chance you have links to the items you used?
Looks awesome!!! How do you turn the lights on? and yes how did you wire them in?
Lights were from ebay http://www.ebay.com/...=STRK:MEBIDX:IT, there are some cheaper, but this is a US seller. Tapped into the dome light wire under the dash using a T tap.
b30c79bf3b546fedf9ed73a5ae5cd096.jpg I added side clearance lights on mine!! Built all the brackets out of aluminum and also have strobes for our funeral home as well!!
  • Like 5
Did the AM/FM antenna relocation. So happy with the results and lead on the black plug that fits perfectly
What size is the plug for this mod? I need to pick one up.
I wish it was as easy as the NBS trucks. Bolt antennae down the inside of the fender and use the escalade cowl piece that didn't have the antennae. So clean looking.
Looks great
3/4", got mine at Lowe's, 2-pack, for a couple dollars.
Anyone know where to get a short antenna that has equal or possibly better reception than the long ugly stock one?
Or just use one of the round ones in the side of the bed ...
Found some strip LED lights at my local dirt Cheap. Basically what you can get from auto zone. Paid $7 for the strip $3 for a pack of quick connectors. I even stepped it up and spent another $4 on some good wire. Lol
How did you wire these up?
^what he said. Hillman company. They're located in the the hardware isle in the those blue pull-out drawers. 3/4 diameter is dead nuts a perfect fit but they don't exactly snap in place due to the way the trim piece is constructed. They come in 2-packs though so I pushed the first one in place and will see if just a "friction fit" holds it in place; especially at highway speeds. If it doesn't. I'll run a small bead of glue around the second one and try it again.....
I did my antenna mod about a year ago, didn't use glue, it's still in place. Most of my driving is highway, to/from work, and I always park into the wind. We get 30MPH+ winds, regularly, around here. Last week, the winds are over 60MPH. The winds are headwinds on my way home.
Just search the forums for under dash lighting. Very easy mod.
There's a grey wire on driver side a pillar you can tap into for them to go on with dome lights or you can go into Ignition power like I did for them to always be on when key is turned.
    DM22
    DM22
  • Who's Online   3 Members, 0 Anonymous, 2,226 Guests (See full list)
    • I thought I would use your thread and add to it as I just did my first longer drive with my truck in the last couple of days. I drove from the Grande Prairie area of Alberta down to Edmonton and most of where I drove in the city was the ring road so fairly free flowing but a bit of stop and go as well in the city. Stayed the night and returned home and not too many stops along the way each way but every restart and certainly every cold start sets it back for fuel mileage. Why I say that is I see some people will cherry pick a fuel mileage leg after the vehicle had been warmed up driveline wise before hand and its a forgiving ( easy rolling drive leg for example ) and call that their fuel mileage which can give a false perception of reality. I was not heavily loaded at all but never the less the flip bak cover, rubber bed mat, various tools etc and extra jerry cans of fuel all way up to a few hundred pounds of dead weight so its not an empty truck. The cold inflation tire pressures are set more near the freezing point so once they are warmed up driving I was showing 45 front and over 40 rear and realize high inflation pressures would help a little in fuel mileage but certainly not the ride on our crap sections of highway. The weather was good so was not raining as that can really drag mileage down, in fact I had a bit of a tail wind on average driving home. Most people on here would never have driven on that freeway to visualize it but its got a fair bit of rolling type of landscape with numerous river valleys. For the most part I had it on cruise set to 62 although kicking it off if I caught it in time before it started down shifting and self braking going down the grades. Most of the more substantial grades its shifting into 7th I believe as 8th just doesn't have it. Total distance round trip was 643 miles and my overall average and I did refuel three times in all, figured out to 17.65 miles per US gallon. My best fuel mileage section refuel within all of this figured out to 18.46 and these are all hand calculated figures. I find if anything that the trucks computer can be over optimistic, sometimes its pretty close but other times its stretching it. On paper persay in theory the truck would have just about made it on fumes for that whole drive without refueling once.    Which made me think of the topic thread of the wonder if these trucks could do 20 mpg and that is a good question, certainly would have to be on an easy going flat highway, no head wind, the right temperature, not packing around a bunch of dead weight and puttering along even slower than I was I would suspect and going steady and not stopping to smell the flowers or take a piss !. It probably is possible but not without effort to attain that with the wind resistance and weight of these trucks. Of course on my drive most people are passing me if they have the power as per loaded highway tractors, never mind a lot of speedy vehicles but the speed limit is 68 and most are at or well over that.
