6 minutes ago, Beer Belly said:
It that an Air Bag I see ?.....is the new trim compatible with the Air Bag (if that is what I'm seeing ?)
Yes and yes, it's a Genuine GM accessory. The nut-plates are already there from the factory and it is held in the same way as the passenger side handle. The stock non-handle trim has a retainer lanyard to keep the trim from blowing into your face, this one doesn't as it is attached by the same two bolts as the passenger side.
Edited by SS502
On 10/2/2016 at 9:52 AM, pgamboa said:
Phillips LED Reverse and Cargo Lamps
Driver' Assist Handle
Frame Tube Plugs
Footwell LED Lighting
Cargo Net
Regarding the footwell lights, did you wire them to turn on when you opened or closed the doors?
I’m not OP, but I wired my footwell lighting to match the dome lights. He has a post on where to jump off the wire. And then ground some where. Works great!
BCM taps:
GRY-8 = Driver's mirror puddle light
GRY-14 = Driver's Door OPEN Switch
GRY-25 = Passenger Door OPEN Switch
5 hours ago, Ravenkeeper said:
BCM taps:
Thank you!
Witch led  lights are you using for the footwell
I bought a long roll of LED lights from amazon pretty cheap. I cut them into the length I need, solder the leads and then installed them. It’s been great. Just need to cover the solder points.
On 8/9/2018 at 9:34 PM, Jmiller11331 said:
fcc0c5b319fbfcfe9e3081480b6234fa.jpg added a OEM high country leather wrapped cluster visor to my truck. Alittle over $50 but close to it. I enjoy it and it lets you add whatever color leather you want.
Where did you purchase that visor?
I can add a cheap mod to this thread.
I saw some .45acp shell casing valve stem caps for sale where I got my windows tinted. I thought the idea was cool, but the .45s looked a bit much. Tried some .40S&W casings when I got home. They fit perfect! These are nickel plated Hornady Extreme Duty casings, so I’m not expecting any significant oxidation or discoloration like brass.
So far I have  -
Replaced the upper half of the mirror with Chrome pieces.
Installed the Driver Side Assist A Pillar
Installed the Round Chassis plugs modified to allow some air to circulate through the tubes.
Oilless high flow air filter.
Front and  rear Weather Tech Mud Flaps
On 12/9/2016 at 9:00 PM, iamdanieltuck said:
An oem wiring harness to access rap, battery power, crank accessory power and ground. $45 is a cheap way to insure we don't short something tapping it or catch on fire.
$45 plus shipping
you still around? i have a few questions. i pm'd you
4 hours ago, chuckworkb said:
Is there a part number for that harness?
no it was a harness a member was making up himself.
Its very straightforward to tap power out of the driver side fuse box.
    Sothpaw27
    Sothpaw27
  • Who's Online   5 Members, 0 Anonymous, 720 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
