Hi Phil,
  I’ve had towing mirrors on my LTZ for the last year and finally getting around to hooking up running and cargo/spot lamps.  Please let me know how I can go about purchasing the DIY wiring from you and if this will cover what I need.
2016 Silverado LTZ - DL3 Mirrors removed
Current tow mirrors - 1A Auto 1AMRP01786
Thank you!
Send me a PM. I am on vacation until week of 1/6 but taking orders.
I have the DL8 mirrors. I’m looking to upgrade to the DL3 mirrors. Does your harness support the existing features.             ( heated, electric adjust) and does your harness support the signal light, puddle lamps and power fold and simmer for both mirrors? Thanks
Yes. As for the Dimming Function, that’s only on the driver side and requires a dimming rear view mirror and a secondary harness. Once those are added, the driver side will dim.
Thank you!
How do you like the 1A Auto brand mirrors? Any difference in quality from OE? I’m really tossing around the idea of purchasing them so I was wondering how you like them.. thanks
So changing the mirror switch will allow me to fold my mirrors? the RZY harness adds the puddle lights and turn signals? . I have the dimming rear view mirror already.
Hi Phil,
I think all i need is your diy kit. I have 15 Silverado 2500hd duramax high country.I replaced the DL3 mirrors with A1 Auto 1798 mirrors. Everything that worked before works now but of course the marker and spot lights don’t. I checked the body side of the door harness and it has pins 11and 9 that I checked with test light to confirm.  Thanks for your help.
The RZY Jumper are for 2014 and early 2015 trucks that are upgrading to tow mirrors and are missing pins 9 and 11 in the door jamb. That is all the RZY is for. GM didn’t land these circuits to the door jamb. Once these are landed, then corresponding door harnesses are needed to make the mirrors work like factory. A switch is needed if you get power Fold Mirrors and want to gain power fold.
Hi Phil,
With 01798, that would be correct. Since the High Country Truck has Seat memory, your door harnesses will be pinned to support puddle lamps and turn signals.
With my DIY Kit, it’ll allow you to modify your door harnesses to add the missing circuits.
PM me if you want to order.
Thanks!
Phil
Hey Phil, I have a 2016 crew cab Silverado LT 5.3 V8 with DL8 mirrors and I want to upgrade to DL3 mirrors. I have the mirrors and the door switch already. Do you make the harness for this conversion? I don’t have the 9,11, or 41 pin. If you do make this harness, how do I go about ordering it from you and sending you my harnesses? The video you have seems pretty detailed and user friendly. Thank you answering my questions while you are vacation,
Ah... the detailed info helps :)
For DL8 to DL3 conversions, yes, I make this harness set custom. They are $285 for the set, shipped anywhere in the US. I refund $100 if you send me your factory harnesses.
You’ll need new switch if you want the ability to fold them :). Those are $70 and I stock them.
I am taking orders while on vacation and already have a 5 day lead time on orders when I return.
PM me if you want to move forward with ordering or need more info.
After reading through 113 pages I gather that you can swap a DL8 equipped truck over to DPN tow mirrors by the plug and play method ?  Most of the topic material is centered around modifying the truck to accept DQS tow mirrors.
Yes, you need new door harness' but yes.
Yes. Depending on year, there may be an additional jumper harness for inside the cabin needed.
I am assuming the additional harness is for the reverse light and turn signal light to function?
Cargo Light and Running Light. The turn signal has always been at the door jamb. This jumper harnesses is ONLY for the cabin side of the connector. The side that goes into the cabin.
    • 87 down as low as $5.14 here... winning!
    • Progress... sort of.   Intake is disassembled, spider is out, fuel lines removed. Used a torch on the stripped screw with the lower intake off, much easier when I've got the intake sitting on my workbench, I made it talk. Walked right out with a pair of vice grips once it was nice and toasty hot.   New parts are piling up on my service cart waiting to be installed. Distributor, temperature sensor, new gaskets, fuel line kit, themostat, water neck.   My new pickle is I don't want to spend $600 on a replacement spider. I'm not sure IT is bad. I'm probably splitting hairs. Or it's $300 to send mine away and another 3 weeks of the truck just sitting. I have half a mind to assemble everything with the old spider to see if I can get away with just replacing the fuel pressure regulator to be safe. The obvious issue was the gushing high pressure fuel line which will be replaced. Getting to the spider really isn't that hard, and now I know what I'm doing , swapping it would be a breeze should it absolutely need one. Stupid, or smart?   The part that gives me pause is replacing the distributor. Well, it's already out. And I didn't mark it, whoopsie! Engine was at TDC when I removed it, I know that, so upon correct reinstall the metal tip on the rotor should point to the TDC mark on the distributor because that's where it was pointing on the old distributor. Worst case I'm a tooth off and have to re-stab it.   But then, what? I assume the truck will start. It doesn't appear the timing can be set. Here's the problem: These distributors can't be rotated but a degree or two, by design. What I read is Cam ****** needs to be -2 to +2 degrees, ideally at 0 (and checked/set above 1000 rpm). There should be enough wiggle to get that properly set, but checking the reported value is another potential issue. My Actron 9185 scanner says it supports enhanced GM PIDs and Cam ****** is one of them but it's unclear that I'll be able to correctly see it over OBD 1.5. I can see why people end up junking these things with life left in them. They're an absolute nightmare with tweener-year diagnostics/electronics and unobtanium parts.   Fingers crossed it starts and idles nicely. There can be hope, right? I'ma buy a lottery ticket the same day just in case.   Next steps..DO IT. I have not installed an intake before so I've been reading and watching a lot. Some say NO RTV except on china walls, some say DO RTV on water ports but not fuel/air intake. 1/4 or 3/8 bead on China walls? I think my strategy will be, obviously, RTV china walls with overlap on the gasket corners. Chapstick-style RTV the water ports. Leave intake ports dry. The only set of intake gaskets I could find locally are Edelbrock performance gaskets (uh...for an asthmatic 190hp V6? LOL) so we'll see how they do.   #NoToolLeftBehind. It took an hour, but my recovery mission for my deep 10mm socket was successful. It had rolled down the bellhousing and wedged itself between what I think are the fuel lines? I couldn't see it at all, but with a junk antenna I had laying around, I blindly went poking/sweeping for it, heard it clink, raised the truck, and caught a sliver glimpse of chrome with a flashlight way up there in Narnia. I had pushed it farther along the lines holding it captive, but within access of severely improvised tools, poking and cursing at it to finally knock it free to where I could get a fingertip on it to bring it home.    Not much to see.
    • Thats crazy considering im right next door (Indiana)
    • For a limited time, retail and commercial accounts receive an AMSOIL Vinyl Tool Tray with their order of $500 or more when they use code TRAY726 at checkout. The promotion runs through July 21, 2026.   Order at https://syntheticadvantage.com   Want to use AMSOIL in your business or sell at your store, apply here.  https://www.amsoil.com/business-opportunities/?zo=521390
    • It wouldn’t have happened if the government hadn’t mandated outrageous fuel mileage standards. It does very little for the consumer. It adds cost. Back during Covid there was a chip shortage. They gave a rebate for your truck if it didn’t have the chip to turn on cylinder deactivation. It was 50$ because at best you may see 1/2 a mile increase per gallon. Splitting hairs each fuel mileage trick wasn’t mandated. The government doesn’t do the engineering work and say use this until it’s already in use and they like it. The fuel mileage was mandated. And those add ons the results. There’s a mandate and they are the results.
