Thanks. Are these better than the factory ones like everyone is saying? I just turned 90k and its the original one i think.
Hard to say man. They look/felt much better than the factory one I pulled out. But I found a good deal on a 2500hd like 2 weeks later and traded my 1500 in for the diesel. But in those 2 weeks I had no problems lol, so maybe someone else could have a better response
Ok. So i hope its the correct one  it was $133.34 delivered. Also hope its safe and not damaged during shipping.
On 3/16/2019 at 10:05 AM, woody6725 said:
I bought a 2014 gmc sierra a few years back. in august of 2017 my a/c condenser went bad. the standard leak that all the 2014's developed. i was still within the 3 year part of the warranty, but i was over on the mileage by about 3000. i contacted gm, and they had me take it to maroone chevrolet in pembroke pines. the repair bill came to $1000. gm agreed to pay $800, and i paid the remaining $200. i was happy with this. now, 19 months later, the new condenser went bad in exactly the same spot. i contacted gm to see if this would be covered at all, because to me they replaced a defective part with another known defective part. i was told to bring it to vera cadillac/gmc for diagnosis. they verified it was the condenser that failed and told me the repair would be just under $1900. i contacted gm to see if any assistance would be available, seeing as this is a well known and well documented defect. i was basically told too bad, the part only had a 12 month warranty. i told them to put it back together and i would be down to pick it up, because there was no way i was going to pay $1900 for another inferior part that might last another 18 months. i expect parts i get from advance auto to last longer than that. i was then charged $85 dollars for a diagnostic that i never needed, which i actually wasn't as mad about as i could've been, because when i took the truck in they told me the diagnostic was $170. i went to oreilly's and bought one for 147.99 with a lifetime warranty. gonna put it in tomorrow morning and see how that one lasts.
Well, how'd your install go?
Well,, not sure about Yustin, but I litterally just got my condenser delivered about an hour ago.  Im undecided if I wanna install it before or after I have my trans and oil cooler lines replaced. They are both leaking. Good thing I still have the powertrain warranty.
Any lawyers out there that know how we can get a class-action or recall on all 50 states for this.......
It does not seem to want to go away.......
I just dropped mine off to get it replaced - GM is working with me on the cost.... still it is out of pocket and I asked what guarantee do I have that they are not installing the defective part?
Even thought there was a technical service bulletin (TSB) for the 2016 vehicles.... why are the 2014's  and above not covered - even though they had the same part or issue?
Very frustrating......
Edited by johnnymordoc
I thought the part numbers are different for the 16+ trucks.
I also dont know why anyone would go to the dealer to have this done.
So the one from O'Reilly looks to be a quality part. Hope its better than the factory one. And comes with the trans line fittings. But doesnt come with a new gasket.
Edited by RACERX7775
Add content
New gasket for which part? The trans lines just have the retainer ring thing. And they fit real snug, so it they're offset in the slight it's annoying to try getting it all the way back in.
The A/C line gasket.
Very bottom left of my picture.
Oh ok. It's actually a really snug fit once you screw the bolt in and tighten down on it a little bit, I didn't have any problem with it leaking or anything afterwards
Im just thinking for the $3 for the gasket, ill probably just get it for insurance.
Still not sure if I should have the cooler lines replaced before or after I replace the condenser.
If you're going to do them yourself I'd do it all at the same time, if you're going to get someone else to do it I'd see what kinda labor they'd charge to throw the condenser in there too, if the price is right you'd save yourself the mf's and gd's of it all lol
The cooler lines are warranty. So that will be at the dealer. Love my 100k powertrain warranty. I dont wanna even ask about them putting the condenser in. And it looks really easy. I have my gauges and the freon and oil already.
Yea it's not bad, a guy at work literally did his the week before mine, so with him helping it took bout 2 hours, just tight in some areas
    • I started with a folding cover by BAK PAC on my 2500. It went bad after close to 5 years. Bent and vinyl coming loose. Contacted BAK and they gave me a very good discount on a Revolver. Had it a number of years. Mostly outdoor storage. Some garage storage. Vinyl started to come loose. Still under warranty so they replaced to cover. Sold the 2500, bought the 1500 and got another revolver for it. Had it a couple years now and no issues. I store it indoors. Got a bit of discount when buying it as well. If you are seeing problems, contact BAK or real truck and let them know. Customer service was pretty good. But I think they changed their warranty.
    • Its possible you never had the joy of the crappy boat launches we tend to have around here or really some of them are just grades down to the river if its a river scenario and the conditions change all the time with the river levels and silt deposits. Some of the lakes we went to years ago, there was no such thing as a cement pad that went down into the water that the trailer stayed on, it was gravel maybe up to the water line and then duck crap much beyond that so sinking the boat tires into mud. Of course some of the more established lakes had a cement bar type boat ramp but sometimes it was covered in green slime closer and certainly within the water and a two wheel drive had all sorts of fun if one had to touch that slime with the rear tires.    A neighbor of mine had made a comment years back with his chev truck that was probably about the same year as yours but a half ton extended cab 4x4 and he a a fiberglass boat with an inboard so it wasn't a feather weight and he had gone out to one of the large popular lakes in the area and don't ask me how this happened but he was in two wheel drive as he figured he didn't require four wheel drive for that boat ramp and somehow upon pulling the boat out he twisted one of his drive axles. I suspect it must have spun and then grabbed on the cement ramp and shocked it to the degree of twisting it. He would have had the standard 8.5 or whatever it was axle housing as the 9.5 ring gear like my truck has also has larger drive axles as far as I know. Anyway he was feeling a vibration driving home and had it checked out and a shop found that the tire/hub was wobbling because of the axle had twisted so in went a new drive axle. After that bad experience he said he made sure to put it into four wheel drive to lower the stress on the rear axle. Of course that is where an HD truck can handle a lot more stress and no doubt these newer half tons with their larger ring gears probably have larger drive axles as well to match vs back in the day.
    • Desirable - as in does someone WANT one, aspire to have one. Could reasonably buy any car they want and CHOOSE these instead.    I didn't watch the video, why did they win?
    • The use of absolutes like "always" to describe gear selection, and giving free advice at a boat ramp sounds like a recipe for disaster. It's a boat ramp, not a farm, for starters.   IMO gear selection should depend on the obstacle. If low range is working and this is a slower speed, controlled ordeal, I'd keep using that.
