How do I do this? Video (2017 Sierra Denali ultimate)
https://www.youtube.com/watch?v=G2yIBERHWMA
This guy is showing a brand new 2017 Denali with the daytime running lights blinking right at the beginning of the video. I assume it is stock. Does anyone know how to do this?
That's how they're made. I forget the actual term for it. But it'll do it if you take picture or video of the DRLs. Happens on all the 2014-2017s
Is it just the cameras frame rate causing it to appear that way?
You may be right. I just played with my truck for an hour trying to figure it out. I feel kinda silly if that the case
I'm going to go take a video with my phone and see what I get.
They weren't blinking with my Galaxy S7 taking video but I think it has a good camera and/or it's nighttime here. That definitely make sense thanks.
It's framerate. On iPhone you can change the framerate of videos so some videos will show it, others won't. Our brains can't perceive the flashing as the average human tops out at about 60fps.
Yup. This is exactly right. I work for a Display Manufacture. The output light from an LED is at a frequency (in hertz). Depending on what that frequency is, it may not be in sync with your camera's frame rate. We have to manufacture our panels so that they can be shot on camera, especially for TV show sets with our large display in the background.
  • 4 weeks later...
This has got to be a troll job, has to be.
No trolling. I had no clue. Sad part is I'm into to tech stuff. I probally own enough electronics that of i sold them i could1 buy another 2017 denali.
On anoter note I decided to do some upgrades heres the list:
-1 7/8 American Racing headers
-Air Raid CAI
-Borla cat back Dual Exit
-Custom street tune from East Coast Superchargers.
Going in the shop next week to get it all done. I'm excited
Sent from my SM-G930T using Tapatalk
-Air Raid CAI
Your money, your truck. "You will have an ultimate plus"! I still love my 4.3 and can only imagine what an enhanced 6.2 would be like!
Take a video of your computor screen or your TV and you will see the same thing! Properly explained above! Sorry No blinking light option on new GMC's. ahahah
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
