Towing 14k pounds?
If it was dire straights and a good friend was very desperate sure I'd do a short trip. Very slowly and carefully. But it seems like he has time to figure out an alternate that doesn't put you or your truck at risk so let him do just that
Rent or borrow a 2500 or 3500. Did you ever feel that Little Rock back and forth when you let off the gas and apply the brakes with a heavy trailer? That is what breaks parts like transmission shafts, axles, etc.. been there.
Most trailer rental stores won't rent a flat car trailer to you if you only have a 1/2 ton truck.
Its not the size of your engine that matters, it's your brakes. You could get a trailer moving with the v-6 (it would be very slow, but it would move) But the brakes on a 1500 are not designed to stop 10+ tons of moving weight (your truck + trailer)
I wouldn't worry too much about hauling it around the yard, or down a country road with no traffic. but once you enter suburbia with stop lights, kids running out into the road, soccer mom backing the minivan out into the street- you better be able to stop that thing.
Well most trailers pulling around that much weight do have brakes.
I realized yesterday I don't have a trailer brake controller though.
Check at your nearby Uhaul. They rent pickups. Including 3/4 and one ton models.
They advertise $19.95 per day. I'd assume HD's might be a little more.
+1 on the renting another truck for this task. Your max towing is under 10K lbs so its not worth it IMO. Rent a 2500 for the day and this is an easy job. $70 to rent a truck vs the damage you can cause to yours is well worth it
I loaded a 2008 Tahoe with a tandem dump trailer with 4 yards of granular 'A' here a couple weeks back. Gran A here is roughly 2,200lbs/yard with a normal moisture content. Trailer is another 2500. So yeah, I would do it, just take it easy. I hauled a 06 F350 crew cab power stroke (7,000lbs) on a 2,000lbs 20' deck-over behind my 6.2L as long as the trailer is loaded right with electric brakes and your not going through the rocky mountains or braking quickly it will be just fine. I wouldn't do it daily or you will need new leafs every 6 months. Keep in mind that if your in an accident and you are beyond your vehicle's GVWR your insurance can technically deny you.
Enterprise rents 3/4, if my buddy was in a jam id find some slow back roads and do it, however being its a dump trailer it may attract the local authorities and in NY they have really cracked down on the lawn and roof guys for bei g overweight and load securement and permits
    • It really doesn’t matter to me. Making a blanket statement that can be refuted will be. As I pointed out the information is out there. Hey google.
    • My area is one of the most affluent areas in Texas. And yet affordable housing is close by. My family business pays top wages and turnover is very low. You can’t but people in a box if you want to succeed the opportunity is there.
    • It was previously working, but the continually running compressor threw me for a loop. It wouldn't be out of the realm of possibility that a 26 year old AC system had lost some of its charge and could be exhibiting low charge indicators, so I thought I had it licked. Add some refrigerant to get the low and high pressures in range like on the old 134 systems.   I learned the continuously running compressor is normal, and that I need to know how much is in the system, as well as needing to meter what goes in. I'm only used to working on older R134a and R12 systems that aren't variable displacement. This is how we learn...LOL.   Long story short, I had a 20% off coupon for a new Jiffy Lube that opened nearby. I took it up there yesterday and they did an evac/recharge using their brand new machine from Mahle. Had a good conversation with the guy, they loved the car and I was out of there for $159 plus tax. Digitally measured charge, exactly 1.5lb of refrigerant went in.
    • In most areas of the country, wages have trailed CPI increases over time (let's say, since the 70's) and things like housing, energy, and food have vastly outpaced wages on the whole. Can't ignore that, it's very real.   That isn't to say there aren't ways to live in ways that mitigate some of that, including moving to cheaper areas of the country. In KNut's neck of the world, median housing prices in "nearby" Dallas are more like $500k. If you're raising a family and young in a successful career, your economic opportunities are probably going to be better living closer to Dallas than Cornhole. A 3 hour (6+ round trip) daily commute probably isn't tolerable for most folks. Grumpy mentioned economic migration; but we've seen what happens when people populate and grow an area. It becomes more expensive when economic opportunities come to roost.   One thing different now from back in the 70's is our quality and standard of living has changed. Healthcare is light years better, for example. But it's also much more expensive. And we have communication and information/tech tools that folks in the 70's could never imagine, and they're accessible to people of just about all incomes. Cars are light years safer, faster, and filled with tech advances. Homes are larger, more energy-efficient, and more luxurious on the whole, from starter homes to luxury homes.   Seattle was once affordable. My folks came here in the 70's with a lot of other people from California looking to escape uncontrolled sprawl, smog, and rising prices in the Bay Area. Seattle and the surrounding area has grown considerably; The home they bought for, I think it was $70k or $80k in the late 70's is now worth $1.2M today. The same house.   So while there have been obvious boosts in some areas of quality and standard of living, regarding opportunity, that's a bit more nuanced. It's really not possible for young people to get started in similar situations in areas of the country that have become "HCOL" (high cost of living). There are many more areas than before, which is to say they exclude younger workers or make their lives significantly harder. They have to commute farther and longer to afford to live in the area. They have to take outsized risk, take on more debt, significantly delay family planning. Or, they could move somewhere cheaper, but there's usually a loss of economic opportunity that comes with that. Even for the same job, it may pay a lot less in a LCOL.   What I don't like are Boomers with phones thinking they have all the answers and outright saying that if people stopped paying for their cell phone that they'd be rich. It's as stupid and misguided as people who think they'd only be rich if taxes weren't so high. Sorry guys, Elon proved you wrong on that one, I guess you're just lazy and blaming your own situation for the reason you're not wealthy. Mobile communication is basically an expectation in a modern society and workforce and it's often cheaper than having a copper landline these days, so... What's your point?
    • My 2008 started exhibiting similar symptoms, wasn't 'cold' enough. I went through a pretty extensive diagnostic process for a DIY'er with limited OBD access. System evacuation and recharge included.   Noticed one day the passenger side was cold (I'm never over there so took awhile to notice).   Pulled the drivers side blend door actuator out, disassembled it and cleaned it out. Put it back in and did some kind of reset and it fixed the problem.   Long story short, it wasn't the A/C system at fault, the blend door wasn't moving to full cold position.
