Emblem not level?
  • Replies 37
i cant view this image but if its the rear emblem theres a chance that it was added at the dealership by one of the new car departments techs (my brother is one of them here in ct) and they add them on at the dealership sometimes. that could be why its crooked maybe?
Hmm looks a little off. There was someone on here with a Silverado a while back with the back bowtie that was waaay off.
It's time to get the tape measure / level out..
Unfortunate that a simple decal can be installed without any tape line...
Time to D-Badge...
Am I nuts or is my GMC emblem not level?
It is not, could see if could have it replaced under warranty, or pay to have a body shop rove and then put a new one back on.
looks a bit off. not so bad that a general passer-by would notice, but just enough to bother you every time you see it.
If you care, you should try to get your dealer to replace it. But I would not spend any money on it if they won't do it for free.
Sure looks off. I would ask dealer to fix it. I know that would drive me crazy every time I saw it. Sure dealer could fix, or debadge like another poster suggested.
can it !! and the rest of the bling on the tailgate use fishing line and or heat gun
Mine is aligned at *exactly* the same bad angle as the OP. 2015 Sierra SLT CC 5.3. Probably a misaligned placement device, or the line worker just wasn't paying attention. Who knows.
Dealer replaced my Z71 decals that were not level. They are just eyeballed and slapped on. High tech.
