Got the handles back from paint today.
Realized you ask me a question and I never replied. About the connectors. I ended up getting enough of the brown - 3-Pin connectors to do all four handles. I went this route because I only need two wires. Problem now... I though I had the terminals for them. So I’ll sit on them for a while.
Got mine wired up today thank you for sharing
Very cool. What’s under your mirror?
Blind spot cameras.  Part of mvi 360 camera system put them on today while I had the door panels off..still gotta plug them into the brain after 5 hours of the door handles and mounting those I had enough lol
Finally got some time off to go to the shop and get the handles painted to match my truck, Graphite Metallic. Most of the body shops are closed on weekends, so this took some time to get done. $220 to get them matched.
I really like how they turned out, matches really nice, as when I bought them, they were Tungsten.
Now, just need better weather up here in PNW so I can install them. I got the missing connectors that were back ordered, got them first week of December. ec5dcc6023adcb944509d47b4895932c.jpg6290072a2b39f9e38bebdb5f2ec6dad4.jpg
Sent from my SM-N950F using Tapatalk
Did you ever install these I also have the graphite I would like to see how they look. And what's the paint code?
I've been busy with a lot of work, on top of family outing on my days off. Plus just this week the weather was ok to even really do anything outside here in PNW on a weekend.. haha
I'm also looking to upgrade my door speakers while I have the panels off, so I'm researching for speakers now as well.
For paint code, it should be GPA for the Graphite Metallic.
2017 Chevrolet Silverado 1500 RPO
http://media.gm.com/media/us/en/chevrolet/vehicles/silverado/2017.tab3.html
Oh ok that's cool, I just took my handles to the shop today they said they should done in a couple days can't wait to install them.
So what are the part numbers for these??  I saw some of the links on eBay but only saw for 2 handles?!  Guess I’m kinda confused on what is what here
Edited by MHPrior80
Either look for this part #23355922 or just search for 2015-17 Escalade Yukon LED Keyless GM Exterior Door Handle. At the time when I purchased mine, they had the complete set of 4. I bought mine from priorityautomotive2015
Edited by jpinoy
If I remember correctly, all 4 of the handles are basically the same for our trucks.  it's only on the SUVs that you need to make sure the front doors get the handles with the passive lock button.
This is correct. The rear handles will have a brown 3-Pin connector whilst the front handles will have a 5-Pin white connector.
You only need 2-wires for the Puddle Lamps (power and ground). So if you can find (2) - Pairs of either, you’ll be fine. It’ll al be custom anyway.
You will need to transfer (2) inserts off of the smaller part of the handle. The illuminated handles will all have a steel base insert (not in the handle itself, but on the smaller part). I don’t remember if it’s the rears or fronts that need to transfer.
The harnesses - no, because they are for an Escalade.
Here is my video on how I installed these. That seller sells just the handles if you want to go this route.
I show all the details here. Will work for 2014 - 2018 trucks.
    • This video may not be the exact content for the joke thread but its a lot of laughs so here it is, I've only watched a portion of it so far but if anyone is looking for some light hearted good soap box driving action, its here. As a note in the upper left of the screen it shows the number out of 100 to refer back to any particular vehicle for comment !.    https://www.facebook.com/reel/1351928276956715
    • Did have to make 1 modification because of the WeatherTech rear mud flaps and that was needing 3 longer screws than what came with the install package. 😄
    • Picked up the liners yesterday. Installed passenger side WITHOUT any modifications. All mounting holes lined up perfectly. Rain is interfering today with drivers side. Very Happy! Will add pics when finished
    • That is a fair point, and I agree that trying to log “everything in the truck” would be the wrong direction.   There are a lot of modules and a lot of traffic. If the product became a full-truck datalogger, the amount of data would get huge very quickly, and most owners would never use it.   I think the first useful version would need to be narrow: - powertrain-side event evidence - selected high-value parameters - communication / voltage / reset events - pre/post event window - short report first, raw log only as backup   One distinction I should make is between active OBD/PID polling and passive bus capture. If you are polling PIDs through OBD, then yes: the more parameters you request, the lower the effective sample rate becomes, and you are adding diagnostic traffic to a vehicle that is already busy running itself. With passive CAN capture, the recorder is not asking all the modules for data. It is listening to traffic that is already on the bus. So it does not consume vehicle bus bandwidth in the same way that a scan tool polling hundreds of PIDs would. But your point still applies in a different way.   Even if passive capture does not add bus traffic, the recorder still has limits: - processing rate - storage rate - timestamp accuracy - decoder workload - event filtering - report size - user attention span   So the answer cannot be “log everything and let the user figure it out.” The product would need to store enough raw evidence to be useful, but only decode, graph, and present the important parts around the event.   A practical report should probably show: - what triggered the capture - how much pre/post data was preserved - which selected parameters changed - how those values compared to baseline - whether the same pattern happened before - whether any voltage, reset, bus-off, lost-message, or communication fault occurred - selected graphs around the event - raw data only as supporting evidence   So I agree with you. More data is not automatically better. The real product is the reduction from raw data into a useful event report.
