I have a 2013 Sierra with a little over 105000 miles . Body is rust free does have some paint flaking.  In March at 100800 miles I we underneath for a gas tank  sensor.  I found a hole in the left frame rail, approximately 4 inches x 1 inch . I contacted GM . There answer was you perforation warranty expired November or 100400 miles which ever came first after several week they offered a service voucher for $100. I declined,  I am going to keep fighting.  The whole frame is in terrible condition.  My 2008 has surface rust but nothing like the 2013.
I pressure washed the underneath the other day to make a repair.  I found the rust to be much more extensive nearly 18 inches long. Disgusted with GM this is my 16th and 8 brand new GM product,  probably the last
Edited by Dusty734
Add more photos
That is some crazy rust on that frame from a 2013 with 100000 miles. Looks like it is ready to fall apart.
  • 3 months later...
I plan on using rust converter , etching primer , paint , and then spraying RP - 342 . I know from having old military surplus stuff that cosmoline is next impossible to remove without gasoline or some petroleum derivatives. I know soap , water , degreaser , or road water will remove it .
2010 Silverado, wheel wells rust coming from back side, bottom of the tailgate, bottom of the doors, paint coming off behind back bumper and bottom of the doors. I take care of my vehicles.  Very disappointed with Chevy. My Silverado has been a great vehicle except for these issues. I'll never purchase another truck from Chevrolet.
That's fine, Chevrolet could care less if you do or not.
And that, folks, is the sad truth of it. Several hundred potential buyers come of age every hour. What do they need you for?
notice how the metal scales. Welcome to the world of boxed frames.
OUCH on that frame!
I live in Ontario and rust is an issue with all the salt.
I have a 2015 and have Krown Rust proofed it once a year since i got it and it has helped keep the rust down.
6 hours ago, davevinc1080 said:
OUCH on that frame!
Is that a KTM in the back?
I check my frame & underbody spring and fall & treat as needed. I don't want this one to end up like my last one. It was an 06 & was pretty rusty underneath when I sold it.
  • 11 months later...
I stopped by a dealership to look at a 2017, 28k miles.  They wanted 30k for it.  I looked under and it was a rust bucket.  Insane.  I realized all the CPO trucks here with low mileage are from up north.  I guess they come to dealership at a good price.  I was appalled at the thought of this much rust on a 3 year old truck.
Yup... I think the city should be paying me for vehicle depreciation with all the salt used on roads. Gm doesn't want their vehicles rust free, otherwise you wont buy a new one.
I like how every year they update the TSB about defective wax coating to include the current model year.  Tells me they are real interested in fixing it. I really believe that wax coating is just to get it through manufacturing/assembly without rust.  After you have it they dont care as long as you get passed the 6yr100k.
Yikes. My 17 with 43k miles has about 10% of that rust and I live in the rust belt.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
