advice on windshield wipers
I have a 2016 1500 silverado I don't remember the last time iv ever replaced windshield wipers does anyone have any preferences I apply rainX to my windshield 1 a month an a lot of it like 5-8 coats of rainX it works amazing so once in a blue moon I have to use wipers are the rainX once good .? I want the best wipers out there any insight to best brand would be a huge help thanks
  • Replies 45
Rain x wipers are fine. Bosch icons are the best. Keep using the rain x every time you wash the truck and your wipers will last years. I️ hardly ever use mine
I have 19k miles on my truck and they just started to streetk I use rain x every time I wash my truck and also coat the windows once a month with it and I only use rainx in the washer fluid its only when im driving slow that I need them
I haven't yet replaced the blades on my 2017 Silverado, but I've always used Bosch on my vehicle with satisfying results.
I’m at 37k and still on my factory wipers. Ice and snow will destroy them in a heartbeat.
Anything other than the bargain bin Walmart brand is fine. Bosch are the best but at the top of the price range ~20 dollars each
I just applied rain-x, and put brand new wipers this truck for the first time. I went with Bosch Icons because others on this forum recommended them. but I learned my lesson, the stupid little "push tab" or whatever the bracket is called- make sure you pick wipers that match it. its not like the good old hook models that fit everything.
I wouldn't buy the rain-x wipers if you already apply the liquid stuff by hand.
did you say you apply 5-8 coats of rain-x? doesn't 1 coat do the trick? it does fine for me.
I bought Bosch Icons because the oem ones began to streak bad. Maybe I got a bad pair of Bosch wiper blades but I'm not happy with mine. I bought mine shortly after California "winter" so the went through summer with hardly any use and they are starting to streak. Maybe I'll give them another go or switch to Rain X.
Sent from my SAMSUNG-SM-N920A using Tapatalk
My 14's developed a streak right where I would look through the windshield. Picked up a pair at NAPA and they did the same. Replaced them at the dealership.
I bought some Bosch icons. They are streaking after only a few months. I called them and they said the blades would be warrantied and transferred me to their warranty dept. I called and left message after message. Going on 4 weeks now. Zero responses. I reached out on twitter and still haven’t heard a response. So far it seems like they have zero customer support.... these will
probably be my last pair.
My tight ass couldn't bring myself to buy the Icons so went with the Michelin Stealths.  Last pair lasted nearly a year so replaced with same.  Combined with a couple of coats Rain X and Rain X Bug Wash really helps keep windshield clear drivingin the rain.
Good information.  I'm interested in trying Rain-X and wondering if there is a downside.  I usually go with whatever wipers the dealer gives me but recently tried the Michelin's.  (I am a Michelin and Costco fan :-)  I found them noisy. I will check the brand used by my dealer as I find they work well.
For the guys using rainx, do your wipers chatter when there is a light rain? Unless the rain is heavy and plenty of water, my wipers chatter across the windshield.
Wipers do all sorts of silly things if the glass and rubber are not surgically clean and in good shape. Lot's of good wipers get pitched. My 2015 has nearly 50K on the clock and the OEM's still work just fine. I do use Rain-X water repellent but 'whatever' washer fluid as the season requires.
    • Engine failure requires radiator replacement per GM if it contains an engine oil cooler.  They do NOT want them flushed.  Radiator replacement is also required for the 6.2 recall if the engine fails.   Here is the TSB the dealer is referring to - 22-NA-074 1..2    Its a slightly older version, but the current version of it covers all model years 2000-2026.  So if enough failure debris was present, it gets an oil cooler.  If that is part of the radiator, it gets a radiator.  Also, same for oil cooler lines.  Those get replaced.     Now something like a 2.7 Turbo which uses an oil to water heat exchanger for the oil cooler, the radiator would be left alone but the oil cooler would be replaced, as well as any lines.
    • Doing the right thing, replacing both valves is the way to go. The valves with the ball leak far more often than the schrader. Never cared for them. The accumulator really should be replaced if the system has had no pressure in it and it was a keeper, but since you're looking to sell it, bet you can get by. Did you pull the orifice screen and see what was there?   Shame you can't get 134a. Hopefully the previous repairs included dye.   Some of the R4s I messed with developed leaks where the line sets connected or the front seal. Had one where the HPCO was leaking. Front seal would only leak under pressure. See any obvious oily spots?   I've got nitrogen I use to test pressure and to help dry the system prior to evacuation.   Keep up the good work
    • Next time you're on a road trip to a state where you can still buy it stock up on 12oz cans, you might look into getting certified so you can buy it where you are as well. When they switched from R12 to R134a the test for certification was easy, they basically just wanted the $25
    • Getting greedy...   The AC pump has been replaced at least once per service records, and it's been recharged twice since 2018 or so, in approximately 2 year intervals between those charges.   It was done at the same shop...clearly they were enjoying the revenue of recharging the system periodically versus actually tracking down and fixing the leak. I learned that the owner was 88 years old when she passed in 2023, so maybe they assumed only a temporary fix was needed anyway.   The system is basically empty now, the compressor spins freely, so I'm guessing it "just needs a recharge".   I vacuumed it down, and it has basically held overnight. Doesn't appear to leak under vacuum, check! So it must leak under pressure. I don't have a way to pressurize the system and pressurizing it with shop air wouldn't be great for the air dryer (which is probably toast anyway?)   The dryer (accumulator? I'm not an AC expert) has a Schrader valve, but the high side has an old ball-type valve, which are notorious for leaking. It's clearly had schmutz blown out of it at one point because the line/area next to the valve is coated old black crud, which I assume is AC refrigerant residue/oil, or maybe even dirty dye. I think I'll roll the dice and replace the valves. I have a black light around here somewhere so I'll find it and shine it around the engine bay in the dark to see if there's any dye.   I can't think of another way to track down the leak other than injecting some dye (if it doesn't have any) and having it charged up. We can't buy R134a off the shelf here anymore, so I'll run it up to Jiffy Lube and have them do it. I think I have a coupon. At the very least, the charge should last long enough for a year or two, according to history. I think this truck will be long gone by then. But cold AC is a selling point.
    • Got the truck back today.  Called them yesterday to get an update, and miraculously my truck is finished?!?! The $13k out the door was complete bullshit!  Ended up being over $14k.  They added some bullshit service bulletin that I cant even find, where they replaced my radiator without telling me or asking me, and charging me for it.  Need to do more research into it, cause they leaked the first delivered radiator was ran over by FedEX.  Sounds like bullshit to me. 2.5 Months for an engine swap, which ended up being remanufactured, not new; ****ing ridiculous.  Brakes are squishy as hell, not sure if its from sitting.  Will give a couple days to see it that figures it self out.  GAVE IT BACK TO ME WITH 1 GALLON OF GAS!  Just filled the tank the day before drop off, more bullshit.  My dash cam SD card was formatted, not really much I can do about that. 3 year, 100k GM warranty at least.  Time to sell it and say **** off to GM.  Bad experience.  Cant wait for the survey email to come through.  Overpriced Raptor R, here I come!
