Hey Folks, I’m searching for the power running boards to have installed on my 2017 Chevrolet Silverado LTZ. I love my truck but have no clue on how to purchase or who could install. I currently have stock all black runnng boards that came with the truck. Any information would be greatly appreciated. Thanks.
Search on Craigslist, eBay, or a user on here named Alex. He also sells LED Tail Lights.
Just wanted to let anyone know that is interested in installing these on a double cab vehicle that they will fit. I put them on mine this past weekend with a little modification they work!
As you can see, the very back bolt hole tab extend beyond the under frame of the truck, you'll need to grind this off but other than that, most of the bolt holes line up.  I had three bottom holes and two upper holes line up perfectly.  I'm going to have to use a couple of self tappers and drill out a couple of additional holes to add additional bolts, but for now, it's secure.
Edited by DBrach
Thank you for responding. Where did you get your boards from and do they articulate. Can these be purchased from dealer. Sorry for so many questions.
I bought mine locally in Dallas from one of the users on here. His name is Alex and he can get more. I dont recommend buying from the dealer because they're really expensive, but yes, they do sell them. Yes, they do articulate!
6 hours ago, 2017 Silverado LTZ said:
Was it plug and play. I watched a video and it was clearly out of my scope.
You have to buy the wiring harness from PGamboa. I also ordered a new fuse box for under the hood, and ordered a new switch panel for the center console. I can do it myself as I've added the folding tow mirrors, but PGamboa lives near me and he's offered his services for a fee.
Thanks to everyone who helped me pull this off.  After watching the videos this really wasn't a hard install.  It just took a little patients.  I ended up finding a set of steps, off an 2018 Denali, on facebook marketplace of all places.  I started to put together a parts list of all the wire, wire terminals, connectors and tools.  From there I decided it was easier, for me, to buy the chassis wiring harness and stripped out what I needed.  It was really easy once you started and all the original mounting hardware is already mounted on the harness.  It ended up looking like a stock install.  Again, thanks everyone for all your help!
Original Wiring Harness:
C41FF2C1-A279-4A54-B315-EB64D412EB4C_zps
Stripping the harness:
F76CF734-F9AD-4B6E-975E-859C3AE55677_zps
B4CD7528-8122-484B-8ECE-DE2597E3C41C_zps
Wiring harness completely stripped.  Ready for loom:
2CAC238D-163C-4FC4-B446-7B26A49F7926_zps
My 2017 Silverado LT 4x4:
29F832B8-8772-4B82-9EE2-209FF382274A_zps
C251DEDE-E4FB-411C-AD1D-004064191258_zps
25835827-F08A-4727-B040-6068F4D95EF8_zps
EE9599F9-7DFA-4C42-8275-610BB80DE692_zps
Edited by SoonerTA
Bought a set off of here, picked them up last weekend (Thanks Papa-T).
I'm going to get the chrome sprayed with bed liner spray to make them all black and then get those bad boys installed! Can't wait.
On 2/27/2019 at 4:59 PM, rah7777777 said:
Fuse box terminals - MFG P/N 13849935-L   OR  Mouser P/N 829-1384995-L
This part number seems to be obsolete now, anyone know the new number?
Are you referring to the fuse box under the hood to land the wires to? If so, here is the one I purchased: 84075773.
Thanks! I’ll have to look that one up!
For anyone looking to take the chrome piece off, this is what I found.
- there are 2 strips of double sided adhesive holding it on the frame, all the way down.
Pretty stout adhesive as well
- if the chrome piece was off completely, you’d have 2 lips on the top and bottom that would look funny I think.
- it’s not too hard to get the steps off the motor and arms so it’s easier to handle.
So im just going to have the chrome side and top all coated in bed liner spray, leaving the chrome piece on the steps but hidden under the bed liner spray (assuming it can scuff the chrome up good enough)
@pgamboa Thank you for making the video and thread.
Can you comment on what would need to be done if pins # 8 GMLAN and #39 Running board disable are missing?
I can find another GMLAN I think I can tie into, but I only have 1 Running Board Disable Signal to tap in to...
[mention=159655]pgamboa[/mention] Thank you for making the video and thread.
The disable circuit runs to the IP switch. It lands onto pin 3 of the connector. That circuit is what is needed to disable the boards if you add the IP switch
Phil does it AGAIN.
I'm a repeat customer:
1. DL3 mirror harness
2. Center console harness
3. Articulating Running Boards!!!!!!
I've been wanting these running boards since 2017 when I 1st spotted them on a High Country at the dealer. I drove up to McKinney from Houston and Phil had them installed and 100% functional in no time at all. It's always great to work w Phil and I don't hesitate to buy anything he has available!22d06ec8222f29b66596c1be3e4d2fd6.jpg37ceb2f7f434f4cce41ef597015e3fb1.jpgc9615e4d7a344ea51fc28219dc428a22.jpg4c6e0b53480fea57e706ff2f4da4260a.jpga36280cc97f45542b5ee8910e64832c2.jpg0de0a523e393d340de1bfb47d23db655.jpg
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
