LED light bar inside grill
Has anyone installed a in grill light bar (led) , and wired them to go on with there high beams on the 2017 Silverado,  DS5 high intensity LED bulbs???? Wondering if it would work out. Low beams are live-able with the aftermarket 35w . But the high beams still are terrible. No I don't want to re-wire the fog lights . I am kinda looking for distance lighting in the high beam mode. Would it be putting to much of a draw on the system, overload the wire gauge size?? Just an idea I have been kickin around
  • Replies 44
Yes, that's the only way to do it IMHO.  I don't know about the newer trucks, but on the 2014's tapping into the white wire (if I remember correctly) behind the headlights can be used as a trigger for the lightbar solonoid on its harness.  With the switch on, it'll only come on with your brights and dims quickly so you can use it on the highway without bothering anybody.
Ya thinking I might buy a bar. But the 14 has a different light than my 17 . Led . Thanks thou . Any suggestions to a quality light bar??
I think I read on here somewhere if your 17 has the active grille shutters you have to “mod” or remove it to fit a light bar behind the grille? Don’t quote me on that though...
Think your right. I just contacted Rough country , They tell me there light bar will not fit behind the grill with the active shutters,. I need to remove in order for fitment.
man.. .. to the high beams?... no thanks... i use my high's often, .. plus the output on my HID's are super bright!... actually brighter than the HIDs on this 2018 loaner i have~.. ... i have mine hooked up to a wireless harness, and i use the homelink buttons to turn it on and off~.. easy and clean looking.. no drilling or extra buttons.
  • 8 months later...
I was able to get the Rough Country LED Light Bar to fit.  I did need to modify the grille some but in the end everything fit and I still have the active shutters.
Do you have any pictures of what you did to do this? I started a thread yesterday looking for info on exactly what you have done here, looks awesome. Although your grille is slightly different than mine I’m more so looking for info on ways to mount it inside there.
Thanks, I am happy with it. I added nylon spacer between the brackets.  I got the spacers from Lowes; the picture with the white bags are the spacers and longer bolts I purchased.  The spacers were white, so I spray painted them black.  I did have to trim a small section of the shutters to allow for the bolts to fit (picture 2).  I also removed the shroud from the grille.  I tried trimming it to allow it to fit around the brackets but realized it was only held in place by six clips.  I also had to add a second hole in the Rough Country bracket that mounts to inside of the frame.  The active shutters has an alignment pin that interfered with the bracket.  I did have to cut out the vertical sections in the grille to let the light bar fit.
There is one section of the grille that is up against one of the bolt heads and I thought about trimming the grille more, but I was able to get it to fit.
Hope this helps and let me know if you have more questions.  I'll be glad to help out.
Thanks a lot! This is super helpful, going to do this in the spring picking up the parts soon. Finally some decent pictures lol.
How’d you wire it to the homelink buttons?
  • 3 months later...
looking to do this to my truck, did u have to fabricate and additional brackets?
Old thread, he may not see your question. However, I have more or less the same kit. It appears to me that all he did was add the spacers, use longer bolts and slightly mod the shutters. The brackets appear to be the ones supplied with the RC light bar.
Great innovation by Ryan.
You are correct.  I didn't need to fabricate any new brackets, just used the RC kit.  I did have to add an additional hole in the flat plate but that was all I did to the RC brackets.  Just take your time.
I will admit that mounting the flat plates isn't easy because to get to the nuts on the backside, you have to bend you arm in ways that it wasn't meant to bend.
    • Lake Speed is drumming up business for his company just by being in the spot-light so he has a vested interest in stoking the 0W-20 fire.  IMO
    • I knew when I bought my truck that it had off road hill decent or craw control or whatever they call it and rolled my eyes at that but it gets throw on with other options my truck has, I just never had a heads up if the highway speed regular cruise setting had anything to do with the brakes and that took me by surprise. If you've ever been to the top of Pikes Peak and watched those ahead of you on the way down with their brake lights on constantly, one can guess they are probably not gearing down or not enough anyway if their vehicle will allow and a good reason their is a brake check spot part way down where they use an infra red heat gun to check how hot ones brakes are front and rear.    Your right that once one gets out of the front range by Denver and I've not been on that stretch of 285 between Denver and Fairplay myself but I know its high and Fairplay at 10000 feet, Buena Vista at 8000, it drops a bit from there but then your going back up and over the 11000 pass and Durango is at 6500 . So yes your definitely right that 6500 and a lot higher is the theme of going anywhere out in that direction from Denver but hey, the down hill sections give fantastic fuel mileage !.    I don't even look at the fuel pumps for what premium costs here, since I live on a farm and up to this point get fuel delivered I am rarely in front of a fuel pump and when I am, I am often using card lock bulk fuel stations so it tells me what the price is AFTER I buy the fuel. Looking up on gas buddy and converting to US gallons but in Canadian dollars, regular on average of the prices listed was around 5.95 and premium is around 7.00 . That was one reason I did not go for the 6.2 half ton aside from its lack of carrying/towing if one was going by the rule of using premium fuel and until recently one could only buy regular farm gas if playing the few cents off game for farm dyed fuel for a "farm licensed pickup". But yes I hear you on the fuel price difference and like the diesel theme with it often being more expensive then gas it doesn't have quite the charm to it either as it once did although right now here for some reason the price of diesel has come down more so its now inline with the price of regular gas.
    • I agree with this assessment. As you know I’m testing longevity with vehicles for the first time. I have a few vehicles I passed to kids and grandkids. We’re all past 100K miles some approaching 170K. I’m the only one doing 5k oil changes. The rest whatever the minder says. I’m the only one doing frequent transmission service. My odyssey the trip vehicle at 200K will be finished as a trip vehicle. I recently changed to high mileage oil, Valvoline. I can’t get past the fact that all manufacturers want to claim long service life. I just don’t make sense that they would go with low weight oil for mileage. While sacrificing longevity.
    • There's absolutely a mountain of profit in catering to the "I do my own research" crowd, people who are certain they know better. And I don't mean there isn't data to support that 0w40 produces less wear product than 0w20 in an engine like the 3.0 Duramax, that only feeds them the assurance they need. Again, my whole thing with oil selection is, sure, 0w40 or 0w30 produces less wear product. Are we talking the difference between the engine lasting only 100k versus 200k? Or are we talking more like, if the engine will already go 350k on a good 0w20 regimen recommended by the OE, is using 0w40 going to get us to 355k, assuming we can even get the rest of the truck to last that long, meanwhile sacrificing the first 5y, 100k in powertrain warranty. The answer isn't easy, there are tradeoffs.   I willfully use 0w20 Dexos D for this reason, knowing that a 0w40 will produce slightly less wear. I don't believe the delta in wear product is meaningful over the lifetime of the engine, and I place much more importance on driving style and overall feeding and care of the engine as a whole. It's the mentality that someone can abstain from alcohol their whole life which is an amazing boost to health by itself, theoretically. But if they're sedentary, that lifestyle choice will most likely kill them young despite their other, concerted efforts. Maybe someone doesn't drink AND they are the perfect picture of health and activity AND they use 0w40 AND they treat their engine perfectly. If living until 130 years is the goal, sure, do that. But it's going to be a really old truck falling apart around a good engine for that last 30 years, without a doubt.   I watched Demonworks' other video on the 100k+ 3.0 Duramax that had dealer 0w20 changes on what appears to be OLM-prescribed intervals (8-10k).   The QR codes are still present and readable on the main bearings. That's how little wear it has.   That's not proof that anyone else should stick to 0w20, but it's confirmation, for me, that 0w20 is perfectly acceptable to use in these engines.
    • 1Based on independent testing of OE 0W-20 in the Peugeot TU3M Wear Test as required by the dexos1 Gen 2 specification.
