So my 2015 1500 has an issue, my driver side parking light do not work. The bulbs will come on with the blinker is activated, I hit the unlock and lock button on the remote. They just won't work as parking lights. Has anyone else had this issue or knows what the problem could be?? Thanks for the help.
Dual filament bulbs, the filament for the parking light portion is blown, they’ll come on with the turn signal or when the key fob is activated because the second filament is working as it should. Replace the bulbs and problem solved.
As stated above, 2-stage bulb, one filament is blown, and the other isn’t. Simple fix.
I'll check that out, thanks. I searched for this topic and couldn't find anything so sorry for double post.
Back work, so I switched the whole headlight assembly around and still don’t work on driver side, so I’m thinking it’s a problem with the computer maybe?
