Anyone know what this cubby hole is for?  or, have a good idea to use it?
The brake controller is worth $275 to GM.
A blank panel is worth $0.
A hole with a little rubber mat allows them to advertise ‘tremendous storage compared to competitors.’  That’s worth at least $50.
I had a 2wd.  Never placed a thing there.  But I’ve had my brake controller since November. Never used it yet either.
I use it for change although it's rare that anyone handles cash in a car anymore - unless you're buying weed, of course.
It is a nice use of space if you were like me and didn't place enough priority in finding a truck with a factory brake controller!  Kudos to GM for not rubbing the knowledge of missing options in our faces.  In the olden days, vehicles lacking options had obvious blanks or cover plugs/plates where knobs or features would go if you weren't so cheap!  ;-)
i keep a couple of loonies ($1 coin) in there so i have a coin for the buggy when i go to the grocery store
It's also large enough for business/credit cards. I keep my garage RFID sensor and my gas rewards card there. I never knew it could fit a dip tin though, might have to change it up and put some cope in there.
If installed, OEM factory trailer brake controller goes there
Edited by bkesting
Perfect fit
I epoxied a panel over mine and put my brake controller adjuster and LED in it.
Replaced my cubby hole cover plate with the trailer brake cover plate. Then cut out opening for my light switches. Trailer brake cover plate is flatter and accepts switches better with a "factory" like look.
  • Like 12
    Fishboat
    Fishboat
  • Who's Online   2 Members, 0 Anonymous, 516 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
