Rocker Switch Placement
Ok guys so I am relocating the passenger airbag switch. Now I want to put a rocker switch(s) in its place. Anyone know of a good way to make it look good and not redneck engineered? I’m thinking about finding a blanking plate and cutting the inside half-3/4 and sliding it in beside the switch as seen below. But I don’t know if there is a better way. And I haven’t really been able to find anything. Thanks for checking this out!
