Haven't had enough morning coffee yet, didn't get my comment attached to my re-post of diyer's pic, wanted to say about that bumper skier, when I was in HS we used to call that Higgybocken, I have no idea of the origin of that word, but I suspect it was the combination of the names of a couple of characters from a neighboring small town, Higginbotham and Bockemuhl.
  • Replies 3.3k
Top Posters In This Topic
WOW does that bring back memories!! 1 time we "mushed" for about 10 miles, thru 3 cities and back
2 hours ago, diyer2 said:
Sky Infrastructure Car Vehicle Road surface
We ain't got no left lanes here..... they are full of Semi trucks passing normal people doing speed limit.  Because I respect Karnut so much I am pulling over to right when I can and they still try to run me off road. HWY speeds on two lane federal highway here is 65. I do 60 most of the time unless its really heavy traffic then I run speed limit to be neighborly.
Well gee wiz. I had a scare a few days ago. I was on some  roads outside of Lufkin. The speed limit on the two lane was 75. Too fast for on this hilly area. I was behind a tractor trailer who was struggling with the hills. I wasn’t in a hurry, I rarely am anymore. A hill comes up he’s about at 50 and a slower traffic keep right sign appears. He pulls over I edge up a little than a sign appears lane ends merge right. It really was that quick. I wouldn’t have made it. I never saw such a set up. A hellcat may have made it, it was that quick. It must be for a really struggling trucks to pull over at really slow speeds. I used to be all over these roads clearing pipelines this is new. I saw quite a few between trinity and Lufkin. Came home a different road there was some more. Short little passing zones. Let’s put it this way. If a truck was doing 60 and I floored my CRV there isn’t enough space. These are high truck traffic areas between interstates. Very bad planning. I still can’t believe it.
  • Sad 1
23 minutes ago, customboss said:
gawd that brings back memories
Some of the safety equipment for  kids have come a long way, I agree. Some of my most fond memories were knowing the risks sometimes the hard way. And doing anyway. If I suited up the way they do kids these days to ride bikes. I would have just done more dangerous stuff thinking I was invincible. I used to sled down a curve road. If you went too fast there was a pond to catch you off a cliff. Or if a car was coming there was that pond. Or you could just learn how to roll. My dad and his brothers used to sled the same hill. People aren’t as fearless these days. I don’t know if’s that’s a good thing.
  • Haha 1
19 minutes ago, diyer2 said:
Wood Motor vehicle Font Window Gas
I used to hold a knock out bar while my father handled the sledge hammer. Even worse when he held the bar. I work with my father and brothers most of my life. When I was little I thought my name was. Hey you little son of a b…., when he wanted coffee or the channel changed. I had a rough but enjoyable family.
  • Haha 1
    DaleB
    DaleB
  • Who's Online   4 Members, 0 Anonymous, 1,318 Guests (See full list)
    • Yes that's right, it's the upgrade that includes the overload spring and all that stuff.   Someday when I'm empty and going by a scale I'm going to stop in and get some weight readings.   Exactly  you should have the ability to change individual settings, in in Canada so I'm driving with kph but then I'm stuck with kpa when I want psi lol
    • You must have that upgraded gvw package which is only available or at least was in 2025 with the diesel engine for the 3/4 ton and that gave the truck physically the larger 12.0 ring gear rear diff and the 3500 rear spring pack. There is a difference in what the diff housing looks like externally as one tell tale and also your truck should have the upper overload spring pack and the frame pads that the pack goes up against.    The pressure the tpms system kicks the alarm in on a stock setting truck, that is a good question and was just from what I recall but I doubt I made any notes on it as I knew for the rear that it was not at all what I was after regardless either. Being that you have a diesel and if running on stock tires the minimum pressure on an empty truck seems to be around 50 psi from hearing of those that have weighted the front axle but the rear axle is very similar in weight to a gas truck and again a near empty truck on the rear could go down to 35 pounds at minimum. However the weigh scale is the proper way to know for sure as a guide.    As to changing the readings on the dash from metric to the US measuring system, oh yes that is done easily but what I was attempting to explain was that I can't pick and choose items I want to have in US and those I still want in the metric system at the same time as its either all or none. For example lets say you drove into Canada and switched your dash over to metric so your speedometer read in km an hour, well then your reading kilopascals on your tpms readout and your wife looks over and says what the hell is that saying in the tpms screen and you say "darned if I know, I think its Chinese" !
    • This is partly why I decided to have switched over to Amsoil SS as a way of hopefully preventing the buildup of the sludge/carbon on the pistons and clogging of the oil control rings and the carbon that would cause the compression rings to stick in their grooves as well as stay cleaner up top of the heads in the valve train in the first place, an oil that has tested better by third party testing over typical shelf oil and also doing my best to run relatively short OCI. However in saying that I don't think there is any way to easily prove the oil I was using prior allowed for a buildup at the OCI I was doing, nor in the other direction to make claims the Amsoil is keeping everything clean either. There really isn't a window into the engine is there to know anything for certain even if oil samples were taken for example that showed still healthy oil being dropped out of the oil pan other than engine tear downs that extensive and expensive testing of oils does to actually visually see what is really going on inside the engine. I wish there was some easy method of seeing what is going on but I don't happen to be aware of that if there is.
    • My truck is a ¾ ton but my placard also says 80 for the rear tires, I think I might have the upgraded suspension to the 3500 series maybe.   I put my air down to 60 and the light was still on, and there was no way I was putting over 60 psi in the rear empty and not towing because I knew the actual number Toyo gave me and I didn't wanna ruin the center of my tires!   And you actually can change it in the settings from metric or is and it will show kph or mph then when you go into your tire settings it will be either psi or kpa, but it would be nice to just change it directly on the tire psi page
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
