Hello all,
First time trying this forum. I hope someone can help with a dead HVAC control module. I believe that it started when I used my remote start to start my truck. When the truck is running by the remote nothing works on the HVAC as per normal until you insert and turn the key...at this point everything should work. The only thing not working now no matter what I do is the HVAC control. I tried resetting everything by disconnecting the battery overnight and by using the remote again in hopes that it would allow the HVAC to power up but nothing works.
Has anyone had this issue before and how did you solve it.
FYI, I know the control module is good as I tried it out with a 2017 Sierra and it lit up.
I hope his makes sense.
Thanks in advance!
  • 9 months later...
  • 10 months later...
Does anyone have a solution for this problem?  My 2019 GMC Sierra Denali HD has buttons on the climate control panel that do not light up, makes it difficult to see what does what when driving at night, they are basically invisible.  Some of the buttons have lights that work, others do not. The defrost and rear defrost lights, as well as the foot air vent buttons all are out, the others all work.
Welcome to the site.
If you are still under the bumper to bumper factory warranty, take it in and have them replace it.
It is a non serviceable part, once the bulbs burn out, you have to replace whole unit.
I had two of my LED’s burn out a few months back in mine so I had all but two working. They had to replace the whole module under warranty. In and out of the dealership in 45 while they replaced. Of course it took 2 months to get the part in from back order.
What did you order? I’m having the same problem on my 2018 Sierra.
Honestly, I don’t know what was ordered other than a replacement for the control unit.  There was no way to replace just the LED’s (according to the techs) behind the buttons so the whole module was replaced. I can try and see if I can find the work order to look for a part number.
EDIT: Can’t find the work order but looking online for my trim, with the auto dual climate, this is what they replaced.
https://www.summitracing.com/parts/ado-15-74881
Edited by Cupton
I have the same issue on my '08 GMC Sierra 2500HD Crew Cab, but mine the LEDs work fine, except for in the middle of the panel, where it shows the temps for dual controls, and what the fan speed is at.  All the buttons at top and bottom work fine, and the controls for fan and temp work fine, but I have no way of knowing what the temp is set to, other than to "feel" whether it's hot or cold.  I was told I need to replace the control module.  I found some on eBay, ranging in price from as low as $40 for "used", which may or may not fail soon after I install it, up to $300 for a "new" unit, which still has a "limited" warranty, probably not longer than a year or less.  You can take your chances, as others have, and replace the unit yourself.  Usually, there are either 3 or 4 connectors on the back, with a part #, which determines which module you need.  You just have to make sure that the module you're getting has the same part #.  Most of the ones I found were going for about $80 for mine.  Your model may vary.
Similar to the picture Daniel posted, one of the lights on my 2019 GMC Sierra Denali HD climate control panel doesn't work.  Of course, my truck is beyond the warranty period for this issue.  Has anyone successfully replaced the climate control panel themselves?
Can we say planned obsolescence? Can't replace a bulb and after a few years don't make the part or on perpetual backorder. Yea, give me some of that can of "Legal Thief".
On 10/18/2023 at 9:28 AM, Beverly Herlihy said:
I've heard you have to order and replace the HVAC control center. I'm going to order one for my 2018 Silverado. And see if that fixes might light problem. I will let you know if it works.
Any luck yet?
  • 6 months later...
Anyone that had this issue also have no air blowing through the vents at the same time? A bunch of the lights went out on my dash, like the pic above, but then my blower motor also only turns on for 3 seconds and then turns itself off. I can turn the heat on and feel warm air slowly coming through the vents.
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
