14 hours ago, Ravenkeeper said:
I had one similar to that, but it fell apart after 2 years.  Besides, I like having the second cupholder for whoever is in the truck with me, or for my fries in one and drink in the other.
Sorry for your bad luck on that one...had this one for almost 3 years now without incident, maybe it depends on which of the "clones" one buys...definitely a lot of similar ones out there.
Just saw this, reminded me of how I did my phone mount a couple years ago, still love the location and works great.
That's the way that I did mine in my '15 LTZ.  Loved it, took some work, but was "easy."  They used a 6' cord to the glovebox USB, but I ran mine to the center console box, 10' cord.
I have a suction mounted iOttie on the front of the cup holder on the center console. Doesn’t interfere with using the cup holder and is right about where my hand is while I drive.
On 9/23/2019 at 2:57 PM, Vulcan762 said:
Just wanted to share my cheap cell phone mount. I have a 2014 GMC Sierra 1500 Denali with the removable / relocatable cup holders. The face of the cup holder assembly is smooth and is a good place to mount a suction cup phone holder base like the one I bought from Amazon for a whopping $7.99. And the surprise is that the mount adjusts for height/length and tilt/angle. Seems very stable and holds tight. Best $8 I've spent in a long time.
Link to mount
https://www.amazon.com/gp/product/B07F462SXM/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
This is by far my favorite option for my "new" 2015 Sierra. No Android car play or whatever you call it, so I need some sort of mount for nav. I tried a vent mount but the vertical vents leave it too wiggly. The Proclip stuff looks like it is sure to damage the dash over time, or too futsy to retrofit something with wireles charging to it. I will try one of these suction cup mounts, and if the joints are loose I'll put a drop of superglue in each once I find the positiopn I like. Buying the highest rated one on amazon at the moment with wireless charging:
https://www.amazon.com/Wireless-Charger-Dashboard-Windshield-Compatible/dp/B07ZJ5WDPG/ref=sr_1_5?keywords=wireless+car+mount+suction&qid=1573610931&sr=8-5
I do wish I could figure out something to mount it higher (like where the dash mounted proclip goes) without having cords running all over or mounting to the windshield. If I could find a cheap replacement dash, I'd buy it, throw it in the garage and drill away on the one in the truck to get it perfect.
Don’t be scared by the price of the mount I used for my install. It’s been like 8,000 miles and it’s still rock solid. It’s gone up a $1 in price but still....9 bucks. Lol
  • Haha 1
Can't beat that price! I may even be able to get one of my current wireless chargers to work on it as they appear to share the same ball style mount, but not 100% sure about that so I'll just spend the big bucks and get the one that will give me wireless charging capabilities :D
I’ve got an iottie mounted on my windshield in the left hand corner. It doesn’t obstruct the view for me at all. It is a wireless charging one, so I have my cable ran down the A pillar and hardwired in. I also have a tablet mount in my one cup holder. I did the second cup holder mod shortly after getting the truck so I still have 3 empty cup holders available. I use my iPad mini for navigation since the factory GM navigation blows balls.
23 hours ago, matrixx611 said:
Where can you buy the phone holder?
from proclip
I just got the iottie easy one touch wireless 2.  Could you tell me how you hardwired a usb cable to the fuse block?  Use something like this? Amazon.com: Pruveeo Dash Cam Hardwire Kit, Mini USB Hard Wire Kit for Dashcam Parking Mode and Motion Detection, Surveillance with 2 Fuse Tap Cable 12V-30V to 5V: Home Audio & Theater
Ah good looking out on the mini usb, glad I hadn't ordered one yet.  10amp fuse suffice to protect it I imagine?
    TopBo
    TopBo
  • Who's Online   7 Members, 0 Anonymous, 723 Guests (See full list)
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
    • Is it an optical illusion in the pic or is the truck really squatting that much horribly?
