Dropped it off for clearbra and tint
Ryan B.
What % tint you going with?
Whatever the rear window is he is going to match it.
Ryan B.
Have any of the Sierra owners done their own install of the kicker tailgate audio system? I've done lots of wiring projects to prior trucks (added 12-volt power to bed of my Canyon, installed towing mirrors with turn signal lights on my Canyon, etc). Wondering if its plug-n-play or if I need to add an accessory fuse block, run wires, drill, etc. Thanks.
Edited by Shawn O'Leary
Ryan B.
Love the color! How do you like the Side Steps? Seem sturdy and like they will hold up? Im debating on the 6" or going aftermarket.
They are they stock GM ones. Solid just like the steps on my 2010 were never had an issue great product
Perfect. Thanks!
On 5/18/2019 at 2:11 PM, BlackLS said:
New shoes.
Fuel Maverick 20 x 9 +1 (No spacers needed)
Nitto Ridge Grappler 305/55
No rubbing or trimming with a 1 1/2" Motofab Leveling Kit.
Do your in-channel vent visors affect the auto close of your windows?  I had AVS in-channel on my ‘16, and I couldn’t use the auto close feature. It would get close to closed and then reverse open (safety feature I assume).  I would have to stop it right before the visor and keep tapping it up till it closed.
Waiting to pickup from tint/clearbra and install these
Ryan B.
Ryan B.
I have a set in my room waiting for my truck to arrive as well. How is the shorty antenna?
    • same here , i have a 2020 first gen and the cost to repair these engines far excedes replacement
    • But Grumpy I did show several subdivisions that had homes starting in the 170K range. If you bought a Townhouse or Condo you could go cheaper. Same with a car 3000 dollars in the 70s translates to around 20K today. There are several models at that price. You actually get more for the money. In the 70s I drove a 3000$ car bought a 28K home and made 4.50 per hour. Thank goodness for overtime. Today I could buy a 170K house drive a 20K car and make 25 dollars an hour operating the same machine today. The difference the house, car, machine would be better and have AC. And I wouldn’t be taxed on overtime. And statistically your wife works too. Easing the burden. I thought we agreed to disagree. I brought receipts earlier, showing examples. I think you’re more stubborn than me. I was done with this debate.
