13 minutes ago, NotoriousGT350 said:
Installed a Lomax tonneau cover from Truck Alterations thanks to Luke Kyle there. Install took less than 20 minutes. It’s the matte finish and sits flush.
Looks good but your idea of "flush" and mine are different.
Did 2 things on my truck today.  First was the removal of scratches in the clear coat on my right rear door.  It was pretty much the whole door.  I'm getting pretty good at this.  Maybe I'll open a detail shop.
On second thought, NOPE.
Right after I finished with the bodywork I got back to modifying the Retrax XR rails to work with the GM Accessories sportbar.  All cutting is now complete.  Work has been checked and rechecked.  Time for a welder to close the open ends, then I'm going to hit it with some flat black paint.  I'm hoping to have this project completed by the end of the week.  Here's a pic of my progress.  Sorry it's not the best image.  Apparently my phone's camera lens is dirty.
Oh, I forgot to mention I order some stake pocket caps from Amazon last week.  They arrived today, so I put them in.  The pic reminded me that I did that today, too.
Edited by Transient
This is about over a week of some Meguair’s Ceramic Wax and we’ve had some rain, hail, and funnels here and there last few days.
Edited by NotoriousGT350
On 5/12/2021 at 1:14 PM, Houheffe said:
Installed mine red to match the red tailgate letters, z71 emblem, and red bowties and tow hooks
Where did you get the red emblems for the wheels?  I am looking for some black ones
I got them from Amazon, the page doesn't come up when I look through my orders. They were Bogar tech designs.
Added Bilstein 6112s with coils. Waiting on 5100 for the rear. Truck feels better especially when braking and turning. Setting 5 for a 2 inch lift. Left me with 1/2 inch higher in the rear. Once they settle I’m hoping for a 1 inch rake. 2020 elevation.
now I’m itching to put some 285/65/20 tires on and fill out the wheel wells!
I sat in my 20 RST for 10 min while it updated.  STRANDED for that 10 min which was really closer to 20 min by the time I was done.   My truck WOULD NOT start until this update was done.
Nice Chevy.  Good thing I was going on a run.
I've got a question about my 19 LTZ...I'd like to remove the grille and put the black bowtie on and maybe the RC LED grille lights. Only issue is I've got a Ranch Hand full bumper on the front and only about 3" of clearance, attached a pic for reference.
My question is do you think it's at all possible for me to get the grille off without removing the bumper?
Imo, yes, but you'll hate doing it.  However, you don't need to pull the whole grille out to swap bowties.  You just need to port the top out enough for you to get your arm in and be able to work in there.  Iirc, I didn't pull my grille out completely, but I think I had a bit more room than 3 inches to work with.
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
