Where did you order these from? Easy install? They look great!
I got them in eBay oem gm I think it was about 59 dollars some guy had them I think they sell knock offs for about the same around 50 very easy to install just need plastic pry tools ebay has them for around 13 bucks thanks again
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F331860109320
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F324022717211
Got my 1.25" BORA spacers on today.  Perfect fit and pulls out the wheels just enough; more importantly moves the backside of the tire away from the upper control arms, as it was getting close after I put on the Rough Country leveling kit.
FYI the 1.25" fit with no trimming as the Trail Boss wheels have pockets behind them to fit the bit of lug bolts that is sticking out.
20200103_132938.thumb.jpg.ae858547f425f59325a358c044b60238.jpg20200103_171435.thumb.jpg.0d7bed5abbd802fb4fae21b163ea6f96.jpg
2 minutes ago, loud_pipes said:
Borla S-type catback exhaust (2020 GMC AT4 5.3L)
Bad ass isn't it.... Love the sound.  Which tips did you get?
8 hours ago, Ebrown1120 said:
33 inch tires and stock suspension but I have 1.5 motofab leveling kit for the front just need to learn how to install it
Are they the 275/60r20 ridge grapplers? If so, did you get the 116 load index? Or did you get the 123/120 load index? Thanks!
Changed out my running boards from chrome to black. These are a bit shorter but got them in Black and new in a box for $150! Had to do it.
Where'd you get them? Got a link?
Sent from my Pixel 3 XL using Tapatalk
2019 Sierra AT4
4” BDS Lift
35X12.5r20 Trail Grapplers
20X9 Mavericks +19 offset
Borla S-Type ExhaustECBB16F4-8387-4488-8247-F95C6DE6919D.thumb.jpeg.5277efa8da4661b160825ca62dc812ee.jpeg41DBD59D-9723-456C-B6D8-225E3F03B271.thumb.jpeg.e538c82343fe6ca75df23719339c06ab.jpegA8F6A562-57E1-4462-B472-8C6C2A9EE59F.thumb.jpeg.4ed3d3a2010e9797923046e7d471aa25.jpegAA77909C-CB4A-47DE-BDD2-016E62C8218B.thumb.jpeg.37be0ea7b2bad046ae647314bfc5020d.jpeg
1 hour ago, snork said:
Looks perfect
what %tint and brand?
Honestly I’m not sure man, I told my guy to just match up with the back and it came out super nice
would it be possible to ask your guy? was is a tint shop?
    • Welcome back! No, it definitely doesn't pass the sniff test. Even "ceasefire" needs an alternative definition these days.    $5.29 at Kroger today
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
    • 2024 Silverado 2500 HD LTZ grille no camera Parts list   84603331 84913656 84913657 84913654 84913655 84911567 84911568 85646092 85646093 85797921 85797922   11570637  x10-15   grille/bumper bolts 11546500  x10      grille clips 11571006  x10      push/retainer clips 11546454  x6       nut retainers 11611609  x6       M5 bolts 11610700  x6       molding/trim retainers
    • And use RA's 5% discount code if you buy from them.  google for the code, one is always available.
    • Just don't turn the steering wheel as much?
