49 minutes ago, econometrics said:
? I know. Believe me, I'm a positive person.
But spend some time on this thread, and you'll see this is a very real, growing issue:
Just watch for it after these Texas downpours we've been having. You'll be happy to catch it sooner vs. later, as I did. My headliner was never stained, etc. so the damage has been minimal... because I was watching for it and caught it when it started. ??
Thanks for the heads up and warning, I just had to be a smart ass haha, I'll be sure to keep an eye out, thanks for the link too!
Removed the air dam. Pfft, who needs that extra 1 mpg on the highway ?
 I still need to remove the clips, and I might end up putting some black paint on the 10mm bolts that you can still see if you get low enough.
Paid for my 2020 registration fee (sticker). Coulda been a nice modification for $572 [emoji1785]
26 minutes ago, jtymay92 said:
This is HIGH on my list! Where did you get them and how much? Was looking at the tailgate Sierra yesterday.... I’m a hater of chrome and want it all gone lol
I bought them off eBay.
Damn good looking truck! What’s the specs on lift wheels and tires?
It’s 7-10inch mcgaughys lift set at 9, wheel are 22x12s hardcore off-road, tires are 35X13.50R22
Fury country hunter M/T
Just had my factory wheels powder coated and tint applied to the front sides... it’s all coming together!
38 minutes ago, irkburgles said:
What did the PC on the wheels run you?
$450 total... same day (8:30am drop-off and 6pm pickup)... great service... great results!
Awesome, thx for posting pics I have been debating doing the same.
Definitely a work in progress.
So far:
2” Readylift level
Flowmaster FX exhaust
Blacked out the logos
Fabfour front bumper
Graphics
Rough Country light bar
Front marker lights
Blacked out exhaust tips
Edited by TXguy
So far:
2” Readylift level
Graphics
Front marker lights
I really like that bumoer, looks clean
So far:
2” Readylift level
Graphics
Front marker lights
Are those front markers a kit or individual led’s?
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
