On 12/21/2019 at 6:53 PM, Andrew F said:
Here is a video of a warm start and revs
Thanks man , think I'm going with the black widow widowmaker.  Appreciate the help. Sounds good.
52 minutes ago, Flatblack83 said:
Removed the tow hooks, cut the opening, re used the foam and bolted the mounts on. Had to drill 2 extra 1/2 inch holes.
I like it, what mounts did you use? Link?
Prepped and plasti-dipped my stock chrome steps. Now the fiancé can get in and out of the truck a little easier.
This will do until I get AMP’s.
20 minutes ago, Flatblack83 said:
Here is the link, I'm not into the goofy expensive hooks they sell. I just used regular hooks. I ordered the isolator lit for the rings. Its soft washers and a boot for the ring to quiet them.
https://amistyling.com/demon-brackets-chevy-19-silverado-1500-19-gmc-sierra-1500
Thanks I’ve seen those AMI ones, they are affiliated with Rough Country. So were they not a direct bolt on product? You mentioned you had to drill 2 new holes.
Associated with readylift, that's where the shipment came from.  The stock tow hooks have a thru bolt and a short one. I had to drill one side of the hole and add a bolt.  No big deal actually.
Yes, AMI and ReadyLift are sister companies.  Neither are affiliated with Rough Country.
Finally was able to wash the salt off and put on the aircraft coating. I’ve had her for a little over a month and wasn’t able to put the coating on before because I had to buy it, lol. Seeing all the salt covering it was driving me crazy so even though it’s only 40 degrees out I washed and applied the coating... I feel better now :)
On 12/22/2019 at 12:50 PM, Texasdeere said:
Wound up doing the same thing with mine, plus a fancy new gas cap!
that is so weird, may gas is reversed....meaning its on right side and closed off DEF is on left
Aircraft coating?
2020 custom trail boss added led reverse , tag lights and headlights h11 and 9005 led bulbs also added 1” riser spacers for driver seat
    DLZ
    DLZ
  • Who's Online   2 Members, 0 Anonymous, 588 Guests (See full list)
