Posted this on the other thread but was wanting to get some more opinions here. Will take some pictures soon when I get a chance.
Hardwired the dash cam to passenger side garage door button fuse today. It took several tries but finally got the garage door button to work but had some static over the radio and the parking assist button would flash on and then off while sitting in the truck with it off. I don't like any of that of course but wanted to get some opinions.
Stayed outta trouble
Snow storm round 1 appx 4-5” (driveway was previously shoveled before I went to bed) with 2-4 more coming tonight
Are they worth it? They look great and are likely next on my list.
Edit: sorry see the other thread now [emoji51]
Man I really wish somebody would come out with something for the GMC’s....might jus have to make something a little custom down the road if it doesn’t happen.
New to the forum. 2019 rst northsky blue.  No pics of mods yet but today I got my front windows tinted 20% to match the rears along with a 20% brow. And removed the **** dealer sticker from the tailgate.
Also went on a bit of a spending spree...oops. purchased a gator soft roll up tonneau cover and black oem running boards. I've always used truxedo lo pro soft roll ups on my previous trucks, but a coworker has a gator on his truck and the quality appeared comparable so for less than half the cost I figured to give it a whirl.
Had a muffler and flapper delete done yesterday. I have all the resonator screens open. Love the sound!
  • Like 3
Not today but last night I installed the gator etc soft roll up tonneau cover. I'm quite happy actually with the quality of it for the price being under $200 (of course its brand new so time will tell how it holds up).
Not the best pic as this is from last night and it was freezing cold.
I have been debating on getting a full system,  just new muffler and delete flapper and cover screens or muffler delete like you, could u post a warm start with some revs when you get a chance pretty please?
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
