MotorTrend Silverado review
https://www.motortrend.com/cars/chevrolet/silverado-1500/2019/2019-chevrolet-silverado-first-test-review/
Same as GMC, disappointed in the interior.  I still think it's a upgrade over the K2 for sure, just a small upgrade.
Suprised they said the 5.3 had bad throttle response, I've heard good things about the 19s throttle response, especially in Sport mode.  What do the owners think?  How about gas pedal flex like the k2s?
0-60 in mid 6s, high 14 quarter mile for the 5.3 in "very hot conditions" sounds pretty dang good for the "slow pathetic 5.3".  Sounds like a dead heat for the 19 Ram which people think is pretty fast.  LOLOLOL.
Can anyone commend on the RST single speed transfer case being awd?  I don't think that's correct.   If you can select 2 or 4wd and the transfer case is locking front and rear that's still a 4wd, not awd.
single speed transfer case is not a RST thing... is a non - Z71 thing.   I just ordered a RST Z71 with duel speed case.
Yup, but why are they saying the single speed is awd, can you leave it in 4wd auto on dry pavement and it not drive a little goofy?  Mine have always binded a little in "auto".
I'm not convinced the single speed is awd, I think it's 4wd with no low
Selectable single speed transfer case.  Its not AWD.  2HI, 4HI, "Crawl Mode" and Neutral.
6.4 to 60 is 0.6 seconds faster than a K2 5.3 NHT A8 at 7.03, so 6.4 0-60 5.3/A8/3.23 vs 5.3/A8/3.42 plus a weight difference for T1.  http://news.pickuptrucks.com/2016/01/texas-truck-showdown-2016-acceleration.html
Also, 14.9 1/4 mile vs. 15.3.
I had no problems getting that 5.3/A8 T1 I drove to downshift, especially in Sport.
They were right on.  After driving and seeing these ,  their review was about right although I agree, the throttle response on the 5.3L is questionable .  I have heard others say how largely improved the 5.3L and 8spd combo is.
These new trucks are LIGHT.  They weighed a LOADED Denali at 5595.  The High Country was only 5450 and
the Trail Boss was only 5235 with the RST only 5178!  These were all 4x4's as well .  GM is right there with the all aluminum F150 in this respect now.  Mileage was very impressive on the highway for the 6.2L trucks in the Real mileage tests as well .
Acceleration numbers were slower than expected because they tested in VERY hot conditions apparently.
The Hemi powered rams are a bit quicker than the 5.3L GM trucks if you option them the same given the data so far.  The Ram FEELS better because of better trans calibration and throttle response as well .  Also, the new eTorq system on the Ram seemed to REALLY improve city mpg , as you would expect.  14.7 mpg for Hemi Ram vs. eTorq Hemi at 18.7.  doesn't do much of highway mileage though.
Regarding weight the GM trucks are  comparable to Ford models or lighter.  2015 F150 Platinum Eco Boost 4x4 weighed 5577 pounds when tested by Car and Driver.  Would be safe to assume that a loaded Sierra Denali with Carbon Pro Bed will be lighter.
Ram had been tested at high 14s and 6.1-6.5 to 60, 3.92 gears.
If the 5.3 is 6.4 seconds on a extremely hot day with 3.23 gears I'd say they're the same.  Not bad for the "weak" 5.3
400lbs less weight should knock off .4 of a second in the 1/4 mile all things being equal.  Glad to hear it. Hopefully real world gas mileage should improve as well.
I'm not sure where these numbers for weight are coming from but my 17 Silverado cc/sb 6.2 midnight 2LZ has a curb weight of 5503. But that doesn't count my side steps/mud flaps. I thought fords were closer to 4800 pounds. Assuming were talking about cc/sb. If the new denali weighs 5500 pounds, gm shaved weight and then put it back on with something else.
Sometimes weight are listed as dry, sometimes wet.  Fluids will make a huge difference.
You'd have to weigh your truck on scales to know what it really weighs.  I can gaurentee GM didn't lie about the weight, it's up to 450 on crew cabs.  They said, I believe, that's crew cab vs crew cab, V8 vs v8
Car mags generally use scales to weigh cars.
You can’t really go by the MFR ratings. SAE guidelines are vague, include standard equipment only, and engine fluids but no specification for fuel other than “nominal”.
Here's motor trends review of the 17 Silverado midnight edition. It has the 5.3/6spd, and not exactly the same options but their saying it weighs 5560. Not far from the 5503 that's on the dealers invoice.
https://www.motortrend.com/cars/chevrolet/silverado-1500/2017/2017-chevrolet-silverado-1500-z71-4wd-first-test-review/
Add Standard Bed which is i believe is about another 100-200lbs ? and its right around 5700 for both higher end models. One thing the FORD has that really heavy is the double moonroof.
You mean the Rollover Ejection Seat? :loser:
    • 3.59 Kroger’s in Montgomery Tx. 20 cents higher than most around here. Very unusual. Saturday they were 3.49.
    • Starting at 17 running parts for my father’s construction business to haul our equipment. Eventually doing shows, sales and training after purchase. I drove a minimum of 50K miles a year. Half hauling something. After retiring 30K miles a year to the last 2 years 15K miles a year. 2/3rds highway driving. The major contribution to fatigue for me is from anticipation and awareness. I just don’t relax. Too many idiots on the road. There’s two kinds. The group that never leave the left lane tied together afraid to let anyone in doing 80. They’re mostly on weekends. Then the left lane sleepers usually next to a tractor trailer not advancing. Eventually the tractor trailer will drift over the sleeper will wake up. The train moves and the tailgaters who are usually mad as hell. You definitely don’t want to mix with them. The tail wagging bumper puller’s with under powered trucks are holding the tractor trailer up. That bunch are dangerous. I usually pace ahead all that. Unless there’s a gap when I can chill and let the speeders pass. I tried all different types of driving. I stay to the right except to pass, it’s the law that’s getting in forced more now because of road rage. I was so happy when my wife didn’t want to do the camping life. I had enough of pulling for work. The family has a bus and fifth wheel. I haven’t driven either one since retiring. No thanks.
    • Yesterday a suggested youtube video thumbnail caught my attention so I watched through it and it was a bunch of short clips someone gathered together of people pulling trailers, a lot of them were bumper pull holiday trailers and a pickup or suv pulling it. a few fifth wheels as well, some motorhome crashes also. The tail wagging the dog theme was quite evident in numerous self inflicted accidents that took out vehicles around them sometimes in the process as the unit finally swung around and flipped over in the middle of the highway. Or the other classic which literally could be called "I forgot the trailer was back there" in passing another vehicle on a multi lane one way freeway and then cutting back in line before the back of the rv trailer had passed the front of the passed vehicle and often in front of a tractor trailer and that never ended well. Or the wide kick out swing of the rear of a long travel trailer as they have so much overhang behind the axles and the trailer smashes into the side of vehicles in the next lane over ( typically sharp turns in city driving ). It makes one leery for good reason to be near an RV trailer after watching a video like that and be it on the highway, in town, or at a gas station where that rear end comes swinging around due to the fuel station being so cramped and not intended for larger trailers. I wonder how many officers have heard those words though "I forgot it was back there" as they investigate the accident LOL.
    • $5.10 for regular at the Kroger   It's been 6 months... is this the "new normal" ?
    • Just because a person can buy a travel trailer or a motorhome doesn't mean they can drive it properly. My observation during my RVing years.
