8 minutes ago, thundar56007 said:
What size lift  and size tires you got?  and is that a 7ft or 8ft garage door?
7" lift with 35/12.50/20 tires.  Dealer put some cheap mud tires on it.  I'm gonna get as much as I can out of them then go with Nitto and maybe even some all terrains.
On 6/11/2020 at 9:39 AM, Electrobri said:
Wow that is a shine. Did you put something on that?
Sorry for the lack of responses guys, I've been on vacation. ?️
Thanks! I use Adam's Buttery Wax every other wash, I think this was not too long after its last wax. Really recommend it if you don't have a garage for applying wax because you can actually apply it in direct sunlight on a warm day and its still super easy to buff off.
Also, the vehicle parked in the garage was a 2016 Ford Police Interceptor Utility, you can just make out the push bar and silver/white chevrons on the bumper - and now you know my day job.
What size wheels and tires did you put on there? Any lift or leveling kit on it?
ReadyLift SST +2, adds two inches on top of the factory 2”. Total of 4” lift. Atturo Blade XT 305/55-20 (33 x 12.5) on 20 x 9 Moto Metal MO970 wheels with 0 offset.
  • Thanks 1
I’m trying to figure out exactly what will fit on mine without a lift for now. I’ve looked through so many pages on here with no real concrete answer. Looking at putting on 20x10 -12 but not sure if it’ll rub so may have to go with 20x9 -12 on my Bridgestone duelers for now. Then later upgrading to 275/65-20 terra grapps G2. Eventually I thought about getting the ready lift 1.75 when I upgrade the tires.
Somewhat new to the forum and excited about my new 2020 AT4 Duramax.  So far loving the new truck.  This is my first GM product after owning Toyotas my entire life.  Couldn't be happier and hoping its as dependable as a Toyota.
Mods -
285/75/17 Nitto Trail Grapplers
17x9 Icon Rebels w/ 0 offset
Removed Rear 2" block to level truck
Next Mods -
Gloss Black Paint
- Grill
- Emblems
- Fog Surrounds
Powder Coat TailPipes Gloss Black
Edited by Benzo1
Wrong Tire/Wheel Name - Nitto Ridge Grappler on Icon Rebound
  • Like 7
2020 Summit White Elevation
Swapped out the black wheels/tires for a set of 18” AT4s.
Added a leveling kit
Added Katzkin leather
Added spray in bed liner.
The only things left I’d like to add are Rough Country HD2 step bars and a black low profile toolbox.
I like it clean and simple!
Edited by maconmatt
minor formatting edit
  • Like 9
My high country and a friends AT4 at a baseball tourney
Ryan B.
  • Like 3
Just my opinion,  but just didn't care for the the grill and over all huge  front end of the GMC is why I went Chevy
Hello, been following the forum for awhile but this is my first post. Bought a new 2019 GMC Sierra Elevation 6 months ago. 8000km so far, love this truck. Wondering how everyone’s 3m vinyl on emblems is holding up, i used a buddies cheap wrap and the edges all peeled up within a day or so. Want to order better stuff if the small lip on the letters is holding the 3m vinyl.
- RC 2 inch upper strut level
- 25% tint on front windows
- Truxedo LoPro cover
Need better photos yet, lots more mods to do.
Ryan B.
I like your matching set :)
Here's mine:
  • Like 4
On 6/20/2020 at 9:46 AM, Cpl_Punishment said:
I thought all Canadians were born as friendly people ?
Here's mine:
Great looking Camaro!!!!
On 6/4/2020 at 8:30 PM, ausomecasey said:
Nice! You get the tri or quad fold? Let us know how you like the cover...
I’ve had the cover on for a few weeks now and live it. Had a few small leaks in the corners but weather stripping helped. I’ll never buy another soft bedcover again. 4738000F-BDB2-414D-9789-BA8B8B6F9973.thumb.jpeg.089a6fe96bb27259ffa37543ae010a1c.jpeg
I got tired of being the only nice guy around.
  • Haha 1
    AidenVorpagel
    AidenVorpagel
  • Who's Online   4 Members, 0 Anonymous, 614 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
