Working on all the upgrades and it’s back at the dealer now having the fabtech leveling kit added to the fabtech stealth 3in lift that’s currently on it. Running 35’s on fuel 20x9’s. I’ve added led highs and lows along with DTL LEDs above the tow hooks which are tapped into the headlamp fuse block, hard tonneau cover from GM, 5% ceramic tint all around, entire windshield tinted at 35% with 5% strip, and I’m waiting on the off road steps to come in so if anyone would be interested in the chrome ones currently on mine I’ll make a good deal on them I live in SC.
  • Like 10
I see you have the tow mirrors like mine. Does your truck have the max tow pkg.? I'm loving the "no more blind spots" but it does warrant a little more care entering and exiting garages.
Sent from my Pixel 3a XL using Tapatalk
Wow that front end really is a drastic improvement over the stock.  What can you do to improve the ass end?
From this...to this. Pretty happy on the deal I got. Rough Country leveling kit, 295/70/18 Nitto G2 Grapplers and AMP Research steps. Love how the new design rides in comparison to the 2017 that I had.
Edited by 99mo
Listed the wrong leveling kit.
  • Like 3
Look's good - maybe a light bar behind the grill ?? But that's me.
Finally after 3 weeks of waiting on parts I got my 6inch Fabtech installed. Bought the Opt7 grille kit and installed it directly behind the Chevrolet letters. I’m working on fabricating a close out panel to mount behind the letters to block the light from shining into the entire grille so that only the letters light up. If anyone is looking for a great lighting kit then get the opt7. I can turn the lights on from as far away as in my house with the remote and the quality is ten times better than the other China made crap sold on Amazon.
  • Like 3
    ChristopherDobson
    ChristopherDobson
  • Who's Online   1 Member, 0 Anonymous, 1,253 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
