67447F2F-0841-4F04-9BDE-885240772E69.thumb.jpeg.fa9c54b22e45eaf27e38511cdb37c6e7.jpegJust picked up my 2020 Denali Ultimate Diesel with standard bed this week. Was on a QC hold for almost 2 months at the plant while it was closed... and I still managed to get a CEL with 24 miles on it due to a kinked aux cooler line from the factory. Oh well, here she is!
Edited by fighting irish
Congrats and love the Standard bed look
Finally after months of looking....new wheels and tires.
  • Like 6
Nitto Ridge Grappler 295/55r20 on America Racing AR933 20x9 +18.
I traded in my 2009 Silverado 1500 this past Friday for a new to me 2019 Silverado LTZ 4x4 with the 6.2, with 19k miles. I'd been looking for a while, and comparison shopped till I was blue in the face. I was sad to see my '09 go. It was a great truck that I bought new during GM's bailout and served me well, but it was time.
So, here it is...I was ideally after the 5.3 simply because I didn't really "need" the 6.2, but no complaints here I assure you. f3954064ec774cdddd5462662291a2fb.jpg
Sent from my SM-G965U1 using Tapatalk
  • Like 4
I picked up my 2020 LTZ in Boise yesterday and had a great afternoon driving it 300 miles home.
  • Like 5
3 hours ago, wondergeekak said:
Just picked this up on Friday. Moved from the GMC Canyon. Got the Duramax in this one.
Great color! I like those steps and the fact it has the painted flares.
First Post.
Just bought this Sunday.  2019 Silverado RST. 9 miles! (5.3L, 2WD).
Edited by Lawsnook
  • Like 5
I've had mine for a month but just recently joined the forum. Leftover 2019 Silverado High Country with 6.2L and standard sized bed. I also traded in the stock 22s for OE black and chrome wheels. I also have put on a tonneau cover and AVS Aeroskin. I just debadged the high country on the fender and tailgate, along with the Silverado letters. Debating on keeping the 6.2L on the hood.
Edited by TNTSilverado
  • Like 4
Just did that yesterday! Took off everything except the 6.2L on the hood. First time debadging. Really like the look of it.
  • Like 5
Got the leveling kit on finally. Glad to be bigger than the Rams!!!15e7555c0dbacfe2f92e9f8ff388433e.jpg37ee2455511ef486d0ae29e0511b4092.jpg
Sent from my SM-G975U using Tapatalk
  • Like 4
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
