Just got this 2020 LT Trail Boss.  Traded in my 2016 LT All Star edition.  Missing a few of the accessories but over all pretty happy with this truck...  Now for the mods.
First thing I got was the Borla S-type cat back with dual gloss black tips.  Really wanted the ATAK, like on my 2016, but I guess Borla couldn't get the sound and performance they wanted.  Added the truxedo pro x15 and BD trims red outline with black inside letter inserts.  Thinking about the redline style lettering for the silverado and LT.  Still a long ways to go but the journey is just starting.
  • Like 5
6 minutes ago, C Squared Trail Boss said:
How do you like the AEM CAI?  Trying to figure out which one I want to go with.
I actually have the Cold Air Induction brand. Very well made but hard to tell if it made any difference. I did the Borla Stype and intake at the same time.
Got the Stype in the market for the intake now.  Looking at aFe, roto-fab and volant.  Cold air induction was in there but I think you just helped me with that one.  Thanks!
Picked up a 2020 Silverado LTZ. 6.2 with tech package, max tow package and LTZ premium package. She is awesome
so far.
  • Like 4
13 hours ago, firefighter907 said:
Very nice!!
Thank you! I've since added 5" black step rails, hood deflector, and tonneau cover. I love my truck.
On 5/8/2020 at 11:57 AM, Inside Man said:
My Sons 2020 RWD RST on the move: 3 inch SuperLift 295/70/18 on Stock Trail Boss wheels.
That looks like Gorman? Very nice truck and Picture. Do you know if its open ?
I fed my truck some some steroids!  6 inch lift & 35x12.50's on some 22's.  I threw in a picture of when it was stock at the end for comparison.
Edited by Pyroman_28
  • Like 5
Good morning all!  I get to pick this beauty up in 3 hours and cannot wait!  Thanks for having me here.
  • Like 7
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
