mfbearded Posted October 7, 2018 Posted October 7, 2018 anyone level a trail boss yet. pictures ? only kit i see is the rough country but it says it wont work on the trailboss. fundamentally i dont see why it wouldnt work.
NWI Denali Posted October 7, 2018 Posted October 7, 2018 I thought that was the whole point of a trail boss- doesnt it come oem with a 2" leveling kit? 2
mfbearded Posted October 7, 2018 Author Posted October 7, 2018 from what i read it come with a 2 inch lift...from and rear...therefor the rake is still present
SuthrnZ71 Posted October 7, 2018 Posted October 7, 2018 I think I read or heard it’s a 2 inch front and a block or spacer lift in rear? Not sure how much in rear maybe an inch?
AJMBLAZER Posted October 7, 2018 Posted October 7, 2018 I noticed in another thread the listed parts for the Trailboss’s lift don’t include arms or any steering parts. Basically it is a leveling lift. Probably means that putting a 2” level on top of it would have your arms WAY out of whack.
silveradonationfan15 Posted October 7, 2018 Posted October 7, 2018 1 hour ago, AJMBLAZER said: I noticed in another thread the listed parts for the Trailboss’s lift don’t include arms or any steering parts. Basically it is a leveling lift. Probably means that putting a 2” level on top of it would have your arms WAY out of whack. the trailboss 2 lift is used thru another set of front shocks, you need to take apart the strut and install another, something how the bilistien 5100 adjustable shocks are.
silveradonationfan15 Posted October 7, 2018 Posted October 7, 2018 And that is a leveled trailboss with 35" tires 7
AJMBLAZER Posted October 7, 2018 Posted October 7, 2018 28 minutes ago, silveradonationfan15 said: the trailboss 2 lift is used thru another set of front shocks, you need to take apart the strut and install another, something how the bilistien 5100 adjustable shocks are. Right...but that doesn’t do anything about the increased angles the ball joints and steering are operating at. 2” level is probably okay...4”...highly doubtful.
silveradonationfan15 Posted October 7, 2018 Posted October 7, 2018 34 minutes ago, AJMBLAZER said: Right...but that doesn’t do anything about the increased angles the ball joints and steering are operating at. 2” level is probably okay...4”...highly doubtful. There is a few more components that isn't shown, such as bump stops front and rear..
AJMBLAZER Posted October 7, 2018 Posted October 7, 2018 None of the parts shown will fix the ball joint or steering angles.
mfbearded Posted October 8, 2018 Author Posted October 8, 2018 5 hours ago, silveradonationfan15 said: And that is a leveled trailboss with 35" tires what did u do ?
cr250Silverado Posted October 8, 2018 Posted October 8, 2018 19 hours ago, AJMBLAZER said: None of the parts shown will fix the ball joint or steering angles. I agree after looking at the parts list. This appears to be a leveling kit with more parts, but still just a level kit. Axle shafts, steering, and control arm angles are not addressed. I’d take a true lift kit over this package. With that said, this is better than nothing for those wanting a new truck with a slight lift while keeping their warranty. 1
Sierra Dan Posted October 8, 2018 Posted October 8, 2018 20 hours ago, silveradonationfan15 said: There is a few more components that isn't shown, such as bump stops front and rear.. This Kit pictured is the Factory GM 2" kit that the Trail Boss and AT4 already come equipped with.
AJMBLAZER Posted October 8, 2018 Posted October 8, 2018 1 hour ago, cr250Silverado said: I agree after looking at the parts list. This appears to be a leveling kit with more parts, but still just a level kit. Axle shafts, steering, and control arm angles are not addressed. I’d take a true lift kit over this package. With that said, this is better than nothing for those wanting a new truck with a slight lift while keeping their warranty. It does actually have new CV axle shafts. Not sure if they are higher angle capable or something?
