You are 100% correct. They come with longer struts and do not correct the geometry
For that reason I'll keep mine the way it is.. the standard box truck is very close to level anyway.
If I did need a little extra height BDS makes a 2.5 coil over that has knuckles and full geo correction.1c2efb0197f232e532373b217e542131.jpg
Sent from my SM-N975W using Tapatalk
I know this is not the trail boss but it’s the trail boss lift by king. 3.0 internal bypass coilovers with 3.0 IBP rear shocks.
I would love to get some more information regarding the wheel and tire combination on this truck, I love the setup.FC23CF49-0F12-4D7A-AAED-E11D53D6379F.jpeg.3c66fbc87324aaebc1ea74c99dc0f19c.jpeg
On 7/15/2019 at 10:47 AM, Bizar said:
Zone has a 1.75" leveling kit. has anyone bought this kit? I'm thinking this is the lift i will go with.
http://zoneoffroad.com/1.75-Leveling-Kit-2019-Chevy-TrailBoss_and_Sierra-AT4/c1171
1.75" Leveling Kit
Here's some of the information.
  • 3-piece design with top mount spacer and 2 preload spacers to raise ride height without over-extending suspension during droop travel
  • Maintains ride quality and handling characteristics
  • Allows clearance for 33-34" tires
  • Includes Factory Protection Plus
Zone Offroad is now offering leveling kits specially designed for the 2019 Chevy Trail Boss and GMC AT4 trucks. Engineered to be more than just a "budget boost", these kits are designed to a higher standard to work within the parameters of the factory suspension and steering geometry to maximize its potential while allowing clearance for larger tires. As with all Zone Offroad lift kits, these new kits are backed by Factory Protection Plus for piece of mind wherever your adventures may take you. Factory Protection Plus includes Zone Offroad's Limited Lifetime Warranty, ESC system compliance and a 5-year 100,000-mile drivetrain warranty.
Important Notes!
  • 1. Strut compressor required for installation.
  • 2. Will not fit Adaptive Ride Control (ARC) equipped models.
  • 3. Tires wider than 295/ cannot be installed on factory wheels due to clearance issues to the steering knuckles.
  • 4. Welding required to install optional LCA steering stops.
  • 5. Complete 1.75" leveling recommended for AT4, Trail Boss suspension not as raked for the factory so installing without thin preload spacer will net 1-3/8" lift for a level stance.
Hope this information helps.
Did you end up going with the Zone kit? I just bought one and I'm wondering how it worked out for you?
On 8/19/2019 at 6:29 PM, CDub said:
Have you experienced any issues with this set up yet? I'm installing a zone kit in my TB next week and I'm just curious if you've ran into any issues with ball joints or rubbing ect?
  • 3 months later...
On 7/14/2019 at 7:10 AM, ETMC said:
Finished everything up. Had to make my appointment for the alignment next Friday due to shipment delays. 1.5 motofab & 35 12.50 18 Ridge Grapplers with 2" Bora spacers.
Could you tell me what your roof height is? I wanna know what before i go this route
On 10/9/2019 at 1:25 PM, MTBeerz said:
19 TrailBoss with Rough Country 1.5" leveling kit and 35x11.50r18 Toyo Open Country AT II
No wheel spacers and there is about a gnats ass of clearance but no rubbing
Very sharp... have you had any cv or ball joint angle issues ... can you post a pic or two of the angles ... I’m considering installing on my 2020 TB
No issues so far, the angles didn't look like they changed much at all and it's been about 10k miles with it installed. Feels fine offroad, no weird handling or noises though I try to keep it pretty slow and controlled (she ain't a beater). That being said, this was the only kit available when I bought it but if the kit with the corrected control arms was available at the time I'd have probably gotten that one instead. FYI the 35's only fit because they are 11.50 wide. Anything wider would definitely rub and cause issues.
Thanks for that very informative reply, I think anything over 1.5 inches(on these factory lifted trucks) may put the cv axles at its limits , the ready lift 1.75/ 2.00 corrects the upper ball joint issue (new control arms) but doesn’t correct the cv axles with a differential drop.. so the 1.5 RC level caught my attention due to the just right amount of lift .... I’m planing on going with 285/75/18’s which is a hair taller than a 35 and 11ish inches wide. Thanks again any pics of the angles would be highly appreciated.  RC gets a bad wrap the 17 Sierra I sold had a 7 inch RC lift (strut lift) and I had zero issues , a quality installer is key .
Edited by Jp sierra
Added a Motofab 1" spacer (CH-1LM-TB)  to my 2019 trailboss. after about 8 months passenger side upper ball joint separated.
Normal driving, couple railroad track crossings daily at speed that might have extended suspension.
Lucky i was going only about 25mph when it came apart. Going to go with better angle upper a-arms.
So is the general consensus to not level these trucks?
I replaced both upper control arms, Rough Country arms, the ball joint angle is way better.
so far so good !  I would recommend checking factory ball joints with lift once in a while especially if you hear any clunking.
Edited by ALLSTAR
info
Leveling kit for 2019 trailboss ball joint issues.
install a RC level kit on my trailboss it lasted 20,000km then the ball joint broke off the upper control arm at a slow speed. Very dangerous!
Mike,  Can you confirm if you replaced the upper control arms ?  or did the Factory control arm separate ?   Thanks
    • So after reading the reveal from Chevrolet, I kept asking myself...why did the trim levels change?   Here are the official ones:   Work Truck (WT): The quintessential fleet truck, built with durable, easy-to-clean interiors for commercial or utilitarian use. Custom: A stylish, road-oriented trim that adds a more refined appearance, standard dual exhaust, and modern exterior styling. Custom Trail Boss: An entry-level off-roader featuring a 2-inch factory suspension lift and 34-inch mud-terrain tires on a budget. Silverado: Serving as the new base consumer truck (replacing the previous LT trim), it comes standard with the Z71 off-road package when equipped with 4WD. Trail Boss: Steps up the off-road hardware with the 2-inch lift, 34-inch tires, monotube shocks, an exclusive off-road hood, and more premium interior options. ZR2: The flagship off-roader. It boasts 35-inch mud-terrain tires, Multimatic DSSV dampers, front and rear electronic lockers, forged carbon-fiber interior accents, and an available hardcore Bison Edition (co-developed with AEV). High Country: The pinnacle of luxury. It replaces bright chrome with modern satin chrome, 22-inch wheels, premium leather, real wood interior trim, a panoramic sunroof, and an exclusive front-passenger touchscreen. As others have stated, why would you want a Silverado - 'Silverado' - wth?? LT needs to remain!!!   Also, there will no longer be a dedicated Z71 model.  All 4x4 trucks will have the Z71 package. Carplay is also something that cannot be removed.  Hopefully it will remain.     I am excited about the 5.7L V8 (350 C.I.D.)  Old school Chevy power.  My only concern is whatever version of AFM/DFM cylinder deactivation.  Too bad that isn't an option a buyer can choose to have or not.   I will definitely be stopping by my local dealership when these trucks start showing up.
    • I haven't seen diesel for less than $5.30 anywhere in my area
    • The not as clean as one would assume theme with the new engine oil, that reminds me of comments over the years with mechanics not always being so on board with filling an oil filter, not from the center anyway due to that typically being the clean side of the filter, danger of some contaminant falling into the filter if not careful but the realization now that the oil may not be as pure as one had assumed it would surely be. Yes it would be possible to fill from the small holes but that means messing with something to prop open the anti drain back valve if the filter is so equipped and not damage that valve in the process. Me, I have hardly ever prefilled an engine oil filter however I have prefilled diesel fuel filters with a filter on a fuel bulk tank and for anyone that has messed with diesel engines with filters and units that have a limited or no way of priming them, putting on a dry filter is a bad day to say the least with those crappy systems. But anyway back to not so clean engine oil, indeed perhaps its not so bad after all that I have not made a practice of prefilling oil filters.    As Grumpy Bear commented on keeping things clean, that I really have to wonder what the typical practice is at a dealer or any other shop that changes engine oil, do they make sure to wipe or wash off the oil plug and certainly if it fell into some gunk or onto a dirty floor, or that they wiped the filter mounting flange and didn't go and use some dirty rag and end up adding dirt to the inside of the head of the filter mount. Or be careless in how they stored or handled the new filter and if they were bumping into items under the vehicle with the filter opening facing up and having dirt drop right into the filter and if so right into the threaded center that is on the clean side. The top side, did they clean away the built up gunk that may be around the filler before removing the cap or to be really careful at that point that something right close to the filler hole that was hidden under the caps flange won't fall into the engine. Or did they clean the funnel or was that just laying there covered in oil from the oil change before and dust kicked up from sweeping the floor stuck to the oil and now that will go running into the next persons engine due to just not cleaning the funnel as "they won't know anyway" attitude as that young guy is more worried about taking a break so he can go outside and smoke a joint. Just random points that came to mind when I think about what some hired personnel may do that the shop foreman has no idea of or perhaps the whole attitude of some shops may be "eh ... who cares, they will never know the difference anyway".
    • $3.69 for 87 octane.   $4.24 for Diesel in town.
    • On the subject of OLM, Gm's OLM tool may be more "informed" than others brands. I recall OLM's in mid-2000's Chrysler products literally counting down a set number of miles. That's all the OLM appeared to be.    I would actually expect GM to be able to explain the parameters that their OLM takes into account from a high level. No, I would not expect them to disclose their software coding or data analysis around their parameters.   So we're talking about two different topics, so to continue the subject on the other one, I'd be curious to know how much "standard particulate matter" in fresh oil is able to be filtered at first start by a fresh oil filter. How much particulate matter is enough to "matter"?   I.e. how much of a "lever" do we think this equates to (variability in particulate content, in fresh oils, between different makes/brands, some which filter less, and some that filter more).   We can say that more particles = more wear = shorter engine life as a logical statement and use that data with a little marketing to scare people into selecting a more refined/filtered oil. Using a similie, is this like deciding to forego two alcoholic drinks in a lifetime because we're worried about the potential impact on lifespan? Are there numbers which translate the ISO test results into a quantifiable increase in wear for a given engine/use case?
