14 minutes ago, ryan030389 said:
Out of curiosity i was just looking at my rear window, Says E2 on there. Seems like most guys have E5 and E9
Does anyone know what the “E” stands for
I have an E2, was repaired 6 weeks ago, no issues yet
Here is the part number on my replacement window that just failed again. 91fa4a503a69e6673fc66aab7510758c.jpg
Sent from my SM-G975U using Tapatalk
we need to file a class action lawsuit to GM and the dealership for shipping defective product to the market with out testing it knowing there has been a manufacturing issue.  We can also turn this into a health hazard issue as the leak will create mold and when mold starts growing in your truck from the leak it can be toxic and a huge health hazard.  I don't know about you but I'm making payments on a 50K dollar truck that I cant drive because they are taking forever to fix it.  We need to all go after GM in a big way.
I'd be happy just walking away from the truck and getting a Ford or Toyota...
I’m really happy with my truck so far. I hope this leak doesn’t happen again and drive me to the point where you and a few others are at... Been a GMC/Chevy fan for awhile now.
Seems like they gave you the wrong replacement window.  Almost everyone else has been getting Fayuo 43R—0000072
ive been leak free for a month with this window.  We will see
i haven’t noted any popping noises from roof / spoiler like I did with old Fayuo window
I was leak free for 6 months after the replacement.
For me, the window problem sucks, yes. But what pisses me off to no end is the incompetence of the dealers. When I get my truck back, it should be in the same if not better shape then when I dropped it off. My truck with 1000 miles on it looks like it’s a year old on the interior with everything they’ve damaged.
Based on my non scientific Google research the E number and 43r numbers have to do with Europe safety standards. The important things are manufacturer fuyao vs Vitro, and model number which is M7035 (original design on my 2019 leaker) and M1235 (new design on my 2020 that also leaked and was replaced with a like M1235 that hasn't leaked YET)
Sent from my Pixel 4 using Tapatalk
let's go after these guys.  GMC and the dealerships are not dealing with our headache and stress to put us in this hardship so they need to pay the price.
I got my truck on the 15th and it has the M1235 window in it. It hasn't leaked yet but after reading through this I am nervous about it. We all have spent big money on our trucks and this is unacceptable.
3 minutes ago, Brandon Adams said:
Class action suits really only benefit the lawyers as they get most of the money from the suit.
True but it will force GMC and the dealers to take action immediately and it might make it easier for us to get out of these vehicles or into a new one with less of a headache
In the long run not worth the time and effort. I (stupidly) after having a 2014 with the vibration issues (it had 0 other issues and was a great truck fit and finish wise) bought a 2019 that doesn’t shake, but has a ton of other problems.
I made some fixes myself to the window and if they don’t work, I’m going to get rid of mine for sure. I had a trade in offer for exactly what I paid for it so going to cut my losses and give another mfg my business. I realize the grass isn’t always greener but would rather not give GM the time of day at this point.
    rayredbone
    rayredbone
  • Who's Online   2 Members, 0 Anonymous, 552 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
