Ready Lift 2" SST for TB
17x9 Fuel Zephyr
315/70/17 AMP Terrain Pro A/T's.
NO rub at full lock going forward, only a bit of rubbing at full lock in reverse on the mud flap and juuuust a tad on the felt fender liner. Haven't gotten around to playing with spacers or doing any trimming, but I'm sure anyone with just a bit of experience would make light work of getting rid of the rubbing all together.
Stock suspension Trail Boss with 295/70r18 Falken Wildpeak tires and 1.5in BORA wheel spacers. Just the right amount of stance and lift in my opinion. No rubbing at all since I trimmed the front mud flaps and removed the little brackets hidden behind them.
Hi everyone, I've been looking for a clear answer to help make my decision, input is appreciated.
Purchased the RL leveling kit, havent installed it yet, my goal is to run Ridge Grappler 295/70/18 on my stock wheels.
Can this be done? I dont want to purchase the tires and find out they wont fit the UAC from RL.
Thank you
Thank you
It won’t fit with the stock rims unless you get spacers. The tires will rub on the RL UCAs. That’s why I had to change my wheels to fit 295/70/18
Curious, what size spacer? I’m running a 1-1/2” but my SST kit goes on in a few week. Looking at either those tires or a 35x11.50 or even a 12.50 if I can clear the UCA with no trimming or maybe the dumb mudflap mod.
To be sure it fits, RL recommends offset of 0 for rims and that’s what I have but if you want to keep the stock rims, then the offset difference is 26mm so about 1.02 inches wide. If you have a 1.5” wheel spacer now it should work.
That’s the math I was using but for some reason I kept doubting it. After it’s installed I’m going to try a set of 1” spacers I have as well and see how it sits and if there’s a rub or not
What size spacer would you need to run
A 285 75 r18 on stock wheels? Or does tire size not matter is all about the wheel?
Thank you
Thank you
According to the calculation, probably close to 0.2” less than the 295/70 tires since it’s .4” wider but take it into consideration that it might be exactly .2” if the wheel isn’t exactly at 0 offset. I would imagine a 1” wheel spacer would clear it with stock rims.
Nitto Ridge Grapplers 295/70/18 with 1.5 RC level up front.  Speedometer is off 3mph with the larger tires.  Ride is similar to stock Wranglers.
Are these more quiet than the duratracks
Thank you
1-1/2” seems to be the best bet with stock wheels.
This may be a dumb question, but I have seen people say they rub in reverse.  Why would you rub in reverse but not going forward?
They look good. Any future concern with the wheel spacers wearing out front end components? Wheel bearings?
I've wanted my wheels out like yours, but read spacers arent good?
Also, any problems with rocks hitting your body? My falken wildpeaks sling gravel like crazy
I think the reason is that in a forward motion it’s a smooth surface that the tire gradually makes contact with in reverse it’s a straight edged abrupt contact that the tire is grabbing on its first contact with the mud flap.
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
