On 1/29/2019 at 5:10 PM, robsieb said:
I believe I might have figured out a work around on this. I disabled the "Change with Buttons" option on the iPhone under Settings-Sounds & Haptics and tested it and the ringer volume remained where I had set it.
Does this prevent the ringer volume be being decreased if you need to go to a meeting and push the side button to lower the volume?
Yes, so you could only change the ringer volume in Settings-Sounds and change the slider volume there.
Or if you’re in a meeting the vibrate switch would still turn off the ringer sound.
4 hours ago, 2016 Sierra Owner said:
What iphone do you have? Maybe it's fixed on the newer versions.
It’s not. We’ve all tried that.
My 2019 has this issue. Even with the new v807 software they just rolled out.
However, when I had a 2020 LT loaner, I had no issues with my phone connecting, syncing contacts, volume, etc. Very weird.
I have same issue with 2019 GMC Sierra, ringtone iPhone XR lowers to nothing, have turned off change volume with buttons and issue persists.  Spent 1 1/2 hr with iPhone support and narrowed it down to settings within infotainment on GMC, got no such support from GMC.  Google indicates several with issue.
I wondering if this is just a issue with iOS or does Android have the same problem?
Tom
After reading through, it didn't look like anyone responded to you. I have Android and experience the same issues described by my Apple brethren with volume being adjusted on the phone through truck changes and notifications not coming through the phone. Scouring the internet didn't yield a fix either. Seems we are in a waiting cycle.
Sent from my Pixel 4 XL using Tapatalk
Finally had time to play with the phone and truck today. Mine seems to work fine! It does lower the volume on the phone while connected either by Bluetooth or the cable and in apple play. However once I disconnect it goes back to full volume.
Iphone X, latest updates and in settings I have the change ringer with side buttons off, This is on a 2020 AT4 with the latest updates also. Not sure this will help anyone but my experience.
The technology on the my 20 is so much different than my 18 that I just traded in.  The volume on the phone goes down and stays down after exiting truck which has caused me to miss many business calls! (Irritating)  It no longer reads my text messages to me while driving, instead have to look at phone unless of course I want to plug in for carplay.  Very dangerous looking at phone for text messages.  Wish I had known some of these things prior to buying, might have considered a different brand.  If anyone has a fix for these things please advise.  Thanks
I feel your pain about the text messages. GM removed that function with the 2020 models. Huge step backwards. I’ve called GM to complain but obviously did no good. Disappointing, especially since it’s as simple as a software update.
I experienced same issue of volume going down and staying down even after leaving the vehicle. Was missing phone calls and text messages. I followed the advice given in TSB # 19NA270 and no longer have this issue after turning off the "change with buttons" setting. I have an iphone xs with ios 13.3 and a newly purchased 2020 GMC Sierra. I too am very disappointed with GM for removing the text message feature from their infotainment system as was on my 2017 Sierra. With Apple car play plugged in one can get messages but it is ridiculous to be required to plug a phone in so one can receive text messages. And why GM still requires a cord for car play in 2020 is beyond belief. The phones have supported wireless car play for quite some time as well as many car manufactures. GM is way behind with their infotainment technology and needs to update their systems ASAP.
My earlier post regarding the volume being turned down on my Iphone after connecting with the infotainment system in my 2020 Sierra is no longer valid. The fix I employed from TSB # 19NA270  worked until my system updated to v148. Neither work around mentioned in the bulletin now fixes the problem. If anyone has found a solution, please post.
The way I see it GM is manipulating MY IPhone not their IPhone. GM through their internal app intentionally lowers my phone volume when I push the ignition switch to turn on the motor of the truck but when truck is turns off the app doesn't increase the volume back to its original setting and its caused me to miss several important calls.
If GM doesn't fix this issue and eliminate this function I'll be forced to execute a lawsuit against GM
And you will lose....
Tom
    • There was talk over the last couple of years that the contract to build these trucks between GM and International would not be renewed.  International moved production of all their other trucks besides the companion CV model out of the Springfield plant some time ago when they opened their San Antonio plant.  That left Springfield only building the Silverado Medium Duty, International CV Series, and some Express/Savanna long wheelbase cutaways.  International also put the plant up for sale some time ago.  This all answered my earlier question as to why GM and International did nothing with these trucks since they were introduced, as they had basically become a market 'placeholder' with a finite life.    The Silverado Medium Duty/International CV trucks were interesting combination of a GM powertrain, electrical system, and K2XX Silverado cab with an International chassis that was supposedly designed for a step-van type vehicle they never produced.  They were manufactured in International's Springfield plant along with the IH MV series initially.  When first introduced, there was much talk that the Silverado Medium Duty/CV would eventually get a gasoline engine option along with other upgrades and GM and IH would work on a class 6/7 joint venture truck.  This was before VW bought Navistar out, after that happened no more was said.  Draw your own conclusions...   About the time talk started that the GM/IH joint venture was not going to be renewed, rumors started that GM would develop a new line of medium duty trucks themselves.  The story is the new trucks will be part of the next generation HD's due in 2028, and will still feature a 'straight rail' chassis design that the current medium duty has.  GM views this as a desirable feature that differentiates their truck from the competition.  A gasoline engine option is also expected.  As the current Silverado Medium Duty remains in production until September 2026 and there is still a lot of inventory available do not expect any official word for some time.   I believe GM remains committed to their successful partnership with Isuzu, and all the LCF models will still be available from Chevy Commercial dealers.  Isuzu is on the cusp of opening a new large plant in South Carolina and there is also speculation that this may result in new product for both Isuzu and Chevy Commercial dealers.
    • drive the truck back to the dealer and complain that the button works.
    • I have a 2026 2500 HD Ultimate. My phone app says there’s a software update available. It’s something about improved battery management and something to do with the running boards. I follow the instructions for the update but the “Check for Updates” option is greyed out in my settings menu. Has anyone else seen this? How did you resolve it? The help message just says “see your dealer” if the download doesn’t work. I’m just trying to save a trip.
    • Fuel mileage?  That's all how you use your right foot.  Exhaust will give you sound.   Stock exhaust 5.3 is 2.75" diameter piping.     If the truck is nice and worth putting some $$ into it, I'd go for a Corsa catback.  I had one on my 2019 old body 5.3 and it was just perfect.  Zero drone, just driving around and cruising on the highway you'd think it was stock, but when you opened it up it was like a Camaro with the factory dual mode.  Corsa bumps their catback to 3in diameter.
